		dsavarese(at)elmore.rr.co Guest
				 Posted: Thu Jul 27, 2006 6:02 am    Post subject: Air leak psssssssss |
				You will need to check your landing gear actuators.  One of them most likely
 is leaking.  First try using the rear gear selector.  Make sure BOTH slide
 locks are to the right just to be safe.  In the following order; turn off
 the main air valve; put the rear gear handle in the DOWN position; put the
 front gear handle in the NEUTRAL position; turn on the main air valve and
 see if you still hear the leak.  My bet is you will.  If yes, turn off the
 main air valve; put the FRONT gear handle DOWN and then put the REAR gear
 handle in NEUTRAL (in other words, back to normal).  Since the gear is down
 and you hear the leak through the gear handle you should be able to
 check/find which actuator is leaking by removing the flexible line on the UP
 side of the actuator.  The up side is the easy one to get to because it is
 at the bottom end of the actuator where the shaft comes out.  The flexible
 line is connected to the a 90 degree elbow.
 With the front gear handle in the DOWN position, remove the UP side flexible
 line, then turn on the main air valve.  Put your finger over the hole on the
 90 degree elbow.  If the actuator is leaking you will feel the air coming
 out of the elbow.  The air is leaking from the DOWN side (connections at
 shuttle valve) past the internal seals and out the UP side which flows back
 through and exhausts through the gear handle.  In normal operation that's
 why you hear the "hiss" when you move the gear handle from DOWN to UP and UP
 to DOWN.  The opposite side pressure in the actuator has to exhaust
 somewhere and that is through the gear handle.  Hopefully this makes sense.
 Good luck.
 Dennis
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rvfltd(at)televar.com Guest
				 Posted: Thu Jul 27, 2006 10:27 am    Post subject: Air leak psssssssss |
				The big trick is having the correct tool to remove the end caps.  I have all
 the o/h parts for the main and nose actuators of the CJ6, but do not know
 about interchangeability with the 52.  Let me know if I can help.
 Always Yakin,
 Doug Sapp
				 Posted: Thu Jul 27, 2006 11:27 am    Post subject: Air leak psssssssss |
				They are not difficult to physically replace.  But reassembling the actuator
 for the first time is always a challenge.  I'd recommend you ship them off
 to Carl and Jill Hays in Kingman, AZ  and have them overhaul the bad one or
 give it to someone who is familiar with disassembly and reassembly.  Carl
 and Jill have the actuator seal kits.  928-681-4400
 Dennis
		wade154(at)frontiernet.ne Guest
				 Posted: Thu Jul 27, 2006 5:00 pm    Post subject: Air leak psssssssss |
				only in the down position that you can tell?  I had a bad seal in the nose
 piston that gave that scenario, my leak would stop if neutral was selected.
 lucky for me the steel balls held the gear down every time. I suppose a bad
 seal in any of the pistons would do it.
 Bill Wade
 N4450Y
				 Posted: Thu Jul 27, 2006 5:16 pm    Post subject: Air leak psssssssss |
				You are correct Bill.  Any leaking actuator will give the same symptom.
 Dennis
				 Posted: Fri Jul 28, 2006 6:13 am    Post subject: Air leak psssssssss |
				Nope!  Since this is your first time disassembling them, once you get the
 shaft out of the cylinder, take a couple of good photos as you proceed with
 the removal of the seals etc. so you know precisely how it goes back
 together.  Just a suggestion.
 Dennis
				 Posted: Mon Jul 31, 2006 4:23 am    Post subject: Air leak psssssssss |
				Mark,
 When you felt the air leaking out the elbow you should have just bit the
 bullet and pulled the actuator and overhauled it.  The problem will not
 disappear and you may be in for a real problem if the landing gear does not
 fully extend to down and locked.  Far more expensive and time consuming than
 overhauling an actuator.
 Dennis
				 Posted: Mon Jul 31, 2006 9:28 am    Post subject: Air leak psssssssss |
				Flir,
 Most of us put the machine oil in the main and Aux air tank when we take
 the tank off to dry it out/drain it during our annuals. If it is at the 5
 yr time frame then the tanks are sent for hydro testing. With the actuators
 off, you can instill machine oil in the cylinders but that only helps the
 individual unit mainly.
 I am not the expert on this, but Dennis, Doug Sapp, Carl Hayes, and Cliff
 Coy to name a few here are the maintance garu's! I learn by watch
 Dennis...sometimes not to well.
 Hope that helps some. By the way, does the me262pilot in your email address
 mean that you also fly the Messerschmitt 262 or  Me to sick to pilot? Heey
 Heey. Assuming Me 262 mean the jet..what's it like to fly?
 Viperdoc
  	  | Quote: | 	 		   [Original Message]
  To: <yak-list(at)matronics.com>
  Date: 7/31/2006 9:47:06 AM
  Subject: Re: Air leak psssssssss
  Dennis,
  Ok that’s all well and fine but…. the book says to add oil every 100
 hours or so….. How do you get the oil there??? It won’t make it thru
 the system by shooting it in with the scuba set up. I will assume that oil
 needs to be shot into both fittings (top and bottom) for this to be
 achieved. Is this correct? I planned on resealing both cylinders anyway but
 was more concerned with getting the oil there to keep from trashing the new
 seals. Apparently sitting damages the seals. Hopefully the cylinders are
 not built like the rest of the plane. LOL
				 Posted: Mon Jul 31, 2006 3:25 pm    Post subject: Air leak psssssssss |
				You can add oil to both sides of the actuators by removing the both the UP
 and DOWN flexible lines and putting machine oil in the flexible line and
 refitting it to the actuator.
 Dennis
				 Posted: Mon Jul 31, 2006 5:57 pm    Post subject: Air leak psssssssss |
				Flight Surgeon.
 Doc
  Date: 7/31/2006 3:38:07 PM
  Well thats cool and.... I wish I could say the same but....... I'm stuck
 fixing an old Russian tool shed that I'm flyin..... You a 16 Pilot????
