Posted: Mon Jun 21, 2021 8:24 am Post subject: Is there a switch configuration that will do this? |
| Quote: | This switch with addition of two
diodes and the resistor cited above can be configured
to accomplish the switching functions you requested.
See attached: |
P.S. those 'loose' components present a small
packaging problem. I think I'd fabricate an
assembly-under-heat-shrink of the three compoents
with wires coming out each end.
Use 1/2" dual wall heat shrink . . . that's
how I packaged a few hundred crowbar ov management
modules.
Your finished assembly will be about 1-1/2 inches
long and 3/8" in diameter. It would tie nicely
into an adjacent wire bundle. I've got all the
materials in stock. I could build one up for you.
out of that stuff?"
