		dj45
				 Posted: Thu Jul 27, 2006 4:18 pm    Post subject: Firewall rivets |
				I'm working on an 801 and can't figure out if all rivets on the firewall are AS5 or just part of them. An update says "change A5 to AS5" but there aren't enough to do the whole firewall. and what I do have (50) go in other places
 I don't have a problem with running down to Fastenall and getting more SS rivets, I would just like to know what is the correct way to do this.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dj45
				 Posted: Thu Jul 27, 2006 4:21 pm    Post subject: Re: Firewall rivets |
				Sorry for the duplicat question. I didn't know the first one went thru.
		NYTerminat(at)aol.com Guest
				 Posted: Thu Jul 27, 2006 4:28 pm    Post subject: Firewall rivets |
				I would call Zenith to be sure. The DeltaHawk produces how many HP?
  In a message dated 7/27/2006 8:21:55 P.M. Eastern Daylight Time,  dj45(at)modempool.com writes:
   	  | Quote: | 	 		  I'm    working on an 801 and can't figure out if all rivets on the firewall are AS5    or just part of them. An update says "change A5 to AS5" but there aren't    enough to do the whole firewall. and what I do have (50) go in other    places
				 Posted: Thu Jul 27, 2006 8:41 pm    Post subject: Firewall rivets |
				I would suggest using only stainless rivets on the firewall of any
 airplane.  Aluminum rivets will melt quickly in an engine compartment
 fire while the stainless rivets will withstand any temperature you
 are likely to get.  The stainless rivets are also quite a bit
 stronger than similar sized aluminum rivets since they are steel.
 I guess a good rule of thumb is if the firewall is steel then you
 should use steel hardware and parts on it.
 Good luck,
 Paul
 XL fuselage
 At 05:18 PM 7/27/2006, you wrote:
 http://forums.matronics.com/viewtopic.php?p=50219#50219
 Paul Mulwitz
 32013 NE Dial Road
 Camas, WA 98607
		dj45
				 Posted: Fri Jul 28, 2006 3:29 am    Post subject: Re: Firewall rivets |
				It puts out 180 hp. They have a rather informative web site. I have spent a lot of time on this choice. I belive it is the way to go for what we want to use the plane for
		Float Flyr
				 Posted: Fri Jul 28, 2006 6:37 am    Post subject: Firewall rivets |
				If your fire wall is stainless steel then any rivets, nuts or washers
 attached to it should also be stainless to reduce the occurrence of
 dissimilar metal corrosion.
 I agree with Paul.... Get the stainless rivets.
 Noel
  Good luck,
  Paul
  XL fuselage
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		ggower_99(at)yahoo.com Guest
		pacificpainting(at)comcas Guest
				 Posted: Fri Jul 28, 2006 12:15 pm    Post subject: Firewall rivets |
				What's the story on the Delta Hawk diesel? I looked  on their website to find a price. Anyone know how much it is?
  Dave in Salem
  801 without an engine yet, but not ready  anyway.
  [quote]   ---
		dj45
				 Posted: Fri Jul 28, 2006 3:06 pm    Post subject: Re: Firewall rivets |
				Thanks for the input. I ordered SS rivets today. Makes sense to me, if I had just stoped to think about it.
 As for the other post, I would be more than happy to give you the extra rivets if you need the extra HP :>)
		VideoFlyer(at)aol.com Guest
				 Posted: Fri Jul 28, 2006 3:35 pm    Post subject: Firewall rivets |
				<<<<<If your fire wall is stainless steel then any rivets, nuts or washers
 dissimilar metal corrosion.>>>
  The firewall is steel...either galvanized or stainless.  But the "L" braces and the channels are aluminum.  Aren't those dissimilar metals?  What's the difference between aluminum rivets in stainless steel...and stainless rivets in aluminum?
  Dave
				 Posted: Fri Jul 28, 2006 10:41 pm    Post subject: Firewall rivets |
				There has been some posts about this "discimilar metals"  danger of corrosion... It beguin when I told the list about the SS firewall we built for my 701...
 I cant remember what the final results of this tread were... Probably the plane will fall apart because of corrosion in 250 years
 Just in case, to be on the safe side,  I put some Zinc Chromate in a little cup and  wetted each  rivet in the firewall before installing and pulling, also double checked that we  painted the touching parts with plenty ZC,
 Hope it holds the next  25 plus years I think I will be able to continue flying...
 Saludos
 Gary Gower
 Flying from Chapala, Mexico.
 701 912S
 601 XL in progress...
 VideoFlyer(at)aol.com wrote: 	  | Quote: | 	 		      <<<<<If your fire wall is stainless steel then any rivets, nuts or washers
  Dave
		Float Flyr
				 Posted: Sat Jul 29, 2006 5:00 am    Post subject: Firewall rivets |
				250 yr???  Probably  depends on how much humidity the plane has to endure.  Dissimilar metals  will live together in the absence of water/humidity.  Electrolytic salts  will also speed up the process.
  If you have to use dissimilar  rivets etc. then the idea of using zinc chromate and/or sealant around the  rivets as they are being pulled is a good one.
 Noel [quote]
Kitfox III-A
		dredmoody(at)cox.net Guest
				 Posted: Sat Jul 29, 2006 6:48 am    Post subject: Firewall rivets |
				I believe the accepted procedure is to prime the contacting surfaces,  particularly with dissimilar metals (which includes different alloys of the same  basic metal). If that is an accepted practice as is dipping rivets in Zinc Oxide  or Zinc Cromate primer at the time of insertion, then I'd guess the issue was  adequately covered.
  Anyone have other or additional ideas or hints?
  Ed Moody II
  Rayne, LA
  601XL / 2nd wing
   	  | Quote: | 	 		     The firewall is steel...either galvanized or stainless.  But the "L"    braces and the channels are aluminum.  Aren't those dissimilar    metals?  What's the difference between aluminum rivets in stainless    steel...and stainless rivets in aluminum?
    Dave
		zman601xl(at)verizon.net Guest
				 Posted: Sat Jul 29, 2006 3:58 pm    Post subject: Firewall rivets |
				I believe the accepted procedure is to prime the contacting surfaces, particularly with dissimilar metals (which includes different alloys of the same basic metal). If that is an accepted practice as is dipping rivets in Zinc Oxide or Zinc Cromate primer at the time of insertion, then I'd guess the issue was adequately covered. Anyone have other or additional ideas or hints? Ed Moody IIRayne, LA601XL / 2nd wing  The firewall is steel...either galvanized or stainless.  But the "L"  braces and the channels are aluminum.  Aren't those dissimilar   metals?  What's the difference between aluminum rivets in stainless   steel...and stainless rivets in aluminum?     Dave
 Dave:
 You have some good questions.I'm working on my firewall now.I've been wondering about the rivets we use on the firewall.The firewall is fire resistant galvanized,but the rivets securing the various braces are alum.Won't they melt if you have a fire?Also,are the rivet heads on the firewall side?Zenith says(generally)that the rivet head should go on the thinner side.A couple of the "l" angles on the back are thinner than the firewall.Hopefully we will get  guidance from some of the guys that have already been down this road.
 Bob Haring(Zman601xl)
				 Posted: Sat Jul 29, 2006 4:43 pm    Post subject: Firewall rivets |
				Dave,
 I used aluminum rivets in a stainless firewall with aluminum skin and
 longerons because it's sound.  The temps that would melt the rivets
 would otherwise melt
 the airframe as quickly.  The surfaces were zinc chromated, but if I
 were to put corroding parts together, I'd rather not see it on the
 outside of my skins.
 With a header tank, its likely the heat would be greater inside anyway,
 eh?  Strength wise, the aluminum rivets have done the job well for my
 601.
 Larry McFarland at www.macsmachine.com
 zman601xl(at)verizon.net wrote:
		Float Flyr
				 Posted: Sun Jul 30, 2006 3:39 am    Post subject: Firewall rivets |
				Isn't it true that the stainless steel will corrode at a slower rate than
 aluminium it is in contact with?   That would make SS rivets more appealing
 to me...remember we are only discussing a hand full of rivets in a key
 location not the whole structure.
 Noel
 [quote] --
Kitfox III-A
				 Posted: Sun Jul 30, 2006 6:55 am    Post subject: Firewall rivets |
				Noel,
 I think you can go either way without much worry.  The concern is mostly
 if you need to leave the surface unpainted (appearance)
 or whether you intend to finish off the aircraft. If you corrosion
 proof, there isn't much of either material decision that can go wrong.
 Larry McFarland
 Noel Loveys wrote:
 Noel
