phcpilot
Posted: Wed Sep 29, 2021 4:57 am Post subject: Kolb-List Digest: 5 Msgs - 09/28/21 |
That's excellent, Rich.
The cost to fix the problem is all of .8 hp.
I'm more than willing to give up that to have no thrust issues.
thanks
On Wed., Sep. 29, 2021, 2:40 a.m. Kolb-List Digest Server, <kolb-list(at)matronics.com (kolb-list(at)matronics.com)> wrote:
| Quote: | *
Today's complete Kolb-List Digest can also be found in either of the
of the Kolb-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2021-09-28&Archive=Kolb
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2021-09-28&Archive=Kolb
Kolb-List Digest Archive
Total Messages Posted Tue 09/28/21: 5
Today's Message Index:
1. 04:24 AM - Re: Reducing power on take off versus thrust line. (Richard Halstrick)
2. 05:24 AM - Re: Kolb-List Digest: 1 Msgs - 09/26/21 (Peter Cowan)
3. 05:47 AM - Thrustline again. (Peter Cowan)
4. 06:48 AM - Re: Thrustline again. (John Hauck)
5. 12:13 PM - Re: Re: Kolb-List Digest: 1 Msgs - 09/26/21 (Rick Neilsen)
________________________________ Message 1 _____________________________________
Time: 04:24:20 AM PST US
From: Richard Halstrick <rhalstrick(at)gmail.com (rhalstrick(at)gmail.com)>
Subject: Re: Reducing power on take off versus thrust line.
The changes pitch force produced by the engine in an airplane is a result
of the distance ABOVE or BELOW the CG of the plane. Engines mounted above
the CG of the airplane produce a moment (twisting force) opposite to the
force produced by the elevator and airplanes with low mounted engines (jets
with engines under the wings) produce a force that compliments the elevator
The moment produced is just the perpendicular component of thrust to the CG
multiplied by the distance from the CG. Tilting an engine up 6 degrees
when it is located above and behind the CG will aggravate the situation by
increasing the lever arm of the thrust to the CG. Tilting it down 6 degrees
will decrease the moment by decreasing the forward component of thrust by
the cosine of the angle (6 degrees would be about 1%).
I=99m new to this forum and in the spirit of full disclosure, I do no
t own a
Kolb aircraft and have never rode in one. I ordered a Twinstar last year
and hope to start building it this month when I receive it from the factory
Rich Halstrick
________________________________ Message 2 _____________________________________
Time: 05:24:54 AM PST US
From: Peter Cowan <cowan.phc(at)gmail.com (cowan.phc(at)gmail.com)>
Subject: Re: Kolb-List Digest: 1 Msgs - 09/26/21
Rick, I get your point about forces at the tail having more leverage than
forces closer to the wings. I don't know how this would compare from an
efficiency point of view. I am not an aero engineer either. But I go back
and forth between pushers and tractors and I'd kind of like to have planes
that fly similarly. So I want a plane where power on makes you go up and
power off lets you go down and it seems to be easy to get that with down
thrust.
If you were into model airplanes you remember that the first thing you'd do
is trim the plane to glide nicely. Then adjust the engine thrust. That's
about what I'm doing.
p
On Mon., Sep. 27, 2021, 2:40 a.m. Kolb-List Digest Server, <
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 21-09-26&Archive=Kolb
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 21-09-26&Archive=Kolb
> Total Messages Posted Sun 09/26/21: 1
> 1. 11:25 AM - Re: Reducing power on take off versus thrust line.
> (Rick Neilsen)
> Time: 11:25:41 AM PST US
> From: Rick Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)>
> Food for thought. Setting the engine/prop thrust line so that any of it is
> pushing the plane down on a Kolb just doesn't seem to make the best use of
> available thrust. Kolb airplanes have a high thrust line in relation to the
> center of drag. You talk about setting about 6 degrees up thrust so that it
> reduces the pitch down effect of adding power. The amount of thrust
> necessary to push the tail down by the prop thrust must be huge. The prop
> is a short distance or leverage arm behind the center of lift. The elevator
> is a considerably longer leverage arm length behind the center of lift so
> the amount of down force required to cause a pitch up or just counter the
> prop thrust is much less. Seems like you would have reduced forward thrust
> and the wings would have to work harder to counter the added downforce and
> in doing so added drag.
> A new pilot needs to adjust to the pitching forces with power changes. It
> is just the way Kolbs fly. My first VW engine mount had a very high thrust
> line. My 72 inch prop had a 7 inch clearance above the boom tube. I
> couldn't go to full power until I got some speed where I had enough
> elevator power to keep from pitching over on the nose. The second mount
> lowered the trust line by 6 inches and that made a huge difference but I
> still have to adjust to pitch force changes.
> As usual my advice is worth what you paid for it.
> Rick Neilsen
> Redrive VW Powered MKIIIC
> On Fri, Sep 24, 2021 at 11:55 AM John Hauck <jhauck36(at)outlook.com (jhauck36(at)outlook.com)> wrote:
> > Don=99t think I said I was OK with reducing power on takeoff, but i
> t did get
> > me out of trouble on my first take off on my very short air strip. Never
> > had to reduce power to takeoff after the first one. Just pull the stick
> > back further.
> > Well, I think you misunderstood my initial explanation of my experience
> > with my =9Cfirst=9D take off after changing out an 80 for a 1
> 00 hp rotax. I
> > think I explained something about =9Cmuscle memory=9D. I had
> more than 2,000
> > hours flying in front of an 80 hp on my MKIII.
> > My second takeoff and another 1,600 hours in front of the 100 hp engine
> > never proved to be as problem. Actually, never thought about it again.
> It
> > too became muscle memory.
> > I don=99t think the =9Cpitch down=9D as power comes up
> is rocket science. It=99s
> > like pushing on a lever. You can help overcome it in several ways. I
> > changed angle of attack of my horizontal stabiliizers and came up with an
> > effective and simple forced pitch trim system. But on takeoff, just pull
> > the stick back a little more.
> > Again, my first take off after engine swap caught me by surprise, but not
> > again.
> > Over the 36 years and about 6,000 hours building, experimenting, and
> > flying Kolb aircraft, I have a pretty good idea how they work. I may hav
> e
> > a difficult time explaining that to someone who has little or no experien
> ce
> > flying Kolbs, but I try. Sorry you all did not understand what I was
> > trying to mumble.
> > john h
> > Titus, Alabama =93 Kolb Factory Pilot for Homer Kolb, Bruce Chesnut
> , and
> > Bryan Melborn, Retired
> > *From:* owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:
> > owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] *On Behalf Of *Peter Cowan
> > *Sent:* Friday, September 24, 2021 9:53 AM
> > *To:* kolb-list(at)matronics.com (kolb-list(at)matronics.com)
> > *Subject:* Reducing power on take off versus thrust line.
> > This topic came up some months back and there was quite a good analysis o
> f
> > the forces involved so I was surprised when John mentioned that after goi
> ng
> > to his higher horsepower engine he seemed to be okay with having to reduc
> e
> > power to complete a normal take off.
> > Surely this is a condition that is abnormal and one we would not want to
> > have in our aircraft, especially if it is avoidable. And it is!
> > I was experimenting with this myself last March and subsequently notes
> > from Boyd young and Richard Swiderski in April did a pretty good job of
> > analyzing the forces involved.
> > I had recently purchased a Beaver pusher that was designed for a 503 or
> > 582 but had a 912 80 in it. Both the owner and the builder had experience
> d
> > this problem of requiring power reduction in order to rotate and their
> > conclusion was, like Johns, that it was just excess power doing it and
> > there was no alternative. Both suggested I should just go back to lower
> > power.
> > This came as a surprise and a challenge to me. Like the previous posters
> > who provided a sound analysis of the forces involved, I finally discovere
> d,
> > with the primary source being a model airplane design site, that providin
> g
> > upthrust on a high, aft mounted engine was exactly the reverse of what wa
> s
> > required.
> > My one circuit flight with this additional positive thrustline was almost
> > more than I could handle in terms of requiring a huge amount of back
> > pressure to stay airborne. A more positive thrustline actully produced DO
> WN
> > THRUST.
> > After learning how things actually worked and putting in close to minus
> > six degrees down on the thrustline, the plane has become a jem in handlin
> g
> > with full power all through the takeoff roll AND NO STICK FORCE change
> > going from low-power to high-power and back in level flight.
> > I do plan to add a little more down in order to get a nose UP on power
> > application and improve the trim it needs now.
> > Please tell me if I am missing something.
> > Peter
________________________________ Message 3 _____________________________________
Time: 05:47:36 AM PST US
Subject: Thrustline again.
One last thought on this is that the 503 powered Kolb that I had flew just
fine. And I would bet a 503 Beaver/Skywatch would be the same. But if I'm
going to go wild with power, why not use some of that power to keep the
trim inline and retain reasonable flight characteristics?
On Tue., Sep. 28, 2021, 2:40 a.m. Kolb-List Digest Server, <
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 21-09-27&Archive=Kolb
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 21-09-27&Archive=Kolb
> Total Messages Posted Mon 09/27/21: 0
________________________________ Message 4 _____________________________________
Time: 06:48:54 AM PST US
From: John Hauck <jhauck36(at)outlook.com (jhauck36(at)outlook.com)>
Subject: RE: Thrustline again.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________________________________ Message 5 _____________________________________
Time: 12:13:14 PM PST US
Subject: Re: Re: Kolb-List Digest: 1 Msgs - 09/26/21
Pete
I'm not an engineer of any kind and I really don't want to beat this issue
to death.
There are some basic design elements that make airplanes fly. We can tinker
with airplane designs to get what we want but there are usually negative
trade-offs and sometimes... the effect is beneficial. My Kolb MKIIIC has
super visibility, which is mostly why I built mine. The only trade-off is
the pitch changes with power changes. Homer originally designed a lower
engine mount with a higher boom tube and I assume it had less pitch changes
with power changes. If it was so simple as to pitch the thrust line up then
we all would be flying ours that way. The performance hit with having the
prop thrust push the tail down is too much for most of us. I don't see any
safety issues so whatever makes you happy go for it.
Your model airplane comparison is fine when you have so much extra power
that you can climb vertically and need neutral stability necessary for the
control system.
Also someone one else talked about the cause being CG related. The first
Kolb airplanes had their engines behind the CG but the thrust line was
closer to the center of drag which didn't have the pitch down with power
increases. It was the change to higher thrust line models that now have the
pitch changes. I think the newer designs have the engine further forward
and closer to the CG.
Again worth what you paid for it.
Rick Neilsen
1st Redrive VW Powered MKIIIC
On Tue, Sep 28, 2021 at 8:28 AM Peter Cowan <cowan.phc(at)gmail.com (cowan.phc(at)gmail.com)> wrote:
> thrust.
> do is trim the plane to glide nicely. Then adjust the engine thrust. That's
> p
>> HTML Version:
>> Text Version:
>> (Rick Neilsen)
>> the
>> it
>> elevator
>> Rick Neilsen
>> t did get
>> Never
>> > back further.
>> 00 hp rotax. I
>> more than 2,000
>> again.
>> It
>> an
>> pull
>> not
>> > again.
>> hav
>> e
>> experien
>> ce
>> > trying to mumble.
>> > john h
>> , and
>> o
>> f
>> goi
>> ng
>> reduc
>> e
>> to
>> experience
>> d
>> > power.
>> posters
>> discovere
>> d,
>> providin
>> g
>> wa
>> s
>> > required.
>> almost
>> DO
>> WN
>> > THRUST.
>> handlin
>> g
>> > Peter
>> -List" rel="noreferrer noreferrer" target="_blank">
>> http://www.matronics.com/Navigator?Kolb-List
>> FORUMS -
>> eferrer noreferrer" target="_blank">http://forums.matronics.com
>> WIKI -
>> errer noreferrer" target="_blank">http://wiki.matronics.com
>> b Site -
>> -Matt Dralle, List Admin.
>> http://www.matronics.com/contribution
-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Kolb-List
phcpilot
Posted: Wed Sep 29, 2021 5:24 am Post subject: Kolb-List Digest: 5 Msgs - 09/28/21 |
Wait a second!
My penalty for fixing the problem by changing the thrust line is LESS THAN 1%.
The problem must be fixed: the plane has to be pointed in the right direction. If we don't use engine thrust, we have to use elevator thrust as Rick pointed out and that costs too.
It sure looks like thrust fix is the way to go.
p
jhauck
Posted: Wed Sep 29, 2021 7:45 am Post subject: Kolb-List Digest: 5 Msgs - 09/28/21 |
Glad you got you adverse pitch problem solved. What kind of aircraft did you say you were flying?
How many hours have you flown since you solved the thrust problem?
Now, I understand, you have zero pitch changes when changing power settings? No need for pitch trim. That is great.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Peter Cowan
Sent: Wednesday, September 29, 2021 8:24 AM
Subject: Kolb-List: Re: Kolb-List Digest: 5 Msgs - 09/28/21
Wait a second!
p
rhalstrick(at)gmail.com Guest
Posted: Thu Sep 30, 2021 7:53 am Post subject: Kolb-List Digest: 5 Msgs - 09/28/21 |
I need to correct my previous email somewhat. The loss of forward thrust of about 1% is correct which does result in a smaller moment about the CG. But the loss is not wasted. The vertical component of the thrust (-6 deg) puts about 10% of the thrust downward which produces a moment in the opposite direction of the moment caused by the engine being above the CG assuming the engine is behind the CG. To know if it completely cancels the moment caused by the engine being above the CG you need to find the location of the CG ( both horizontal and vertical) or go fly the plane and see how it feels. The latter being more fun. I use the term 'thrust' and not horsepower. They are related but not the same. Thrust is a unit of force and hp is a unit of work which is force x speed.
On Wed, Sep 29, 2021 at 8:59 AM Peter Cowan <cowan.phc(at)gmail.com (cowan.phc(at)gmail.com)> wrote:
| Quote: | That's excellent, Rich.
thanks
| Quote: | *
HTML Version:
Text Version:
t own a
Rich Halstrick
thrust.
p
> HTML Version:
> Text Version:
> (Rick Neilsen)
> Rick Neilsen
> t did get
> > back further.
> 00 hp rotax. I
> more than 2,000
> It
> > again.
> e
> ce
> > trying to mumble.
> > john h
> , and
> f
> ng
> e
> d
> > power.
> d,
> g
> s
> > required.
> WN
> > THRUST.
> g
> > Peter
> HTML Version:
> Text Version:
DQoNCg0KDQo
Pete
to death.
control system.
Rick Neilsen
> thrust.
> p
>> HTML Version:
>> Text Version:
>> (Rick Neilsen)
>> the
>> it
>> elevator
>> Rick Neilsen
>> t did get
>> Never
>> > back further.
>> 00 hp rotax. I
>> more than 2,000
>> again.
>> It
>> an
>> pull
>> not
>> > again.
>> hav
>> e
>> experien
>> ce
>> > trying to mumble.
>> > john h
>> , and
>> o
>> f
>> goi
>> ng
>> reduc
>> e
>> to
>> experience
>> d
>> > power.
>> posters
>> discovere
>> d,
>> providin
>> g
>> wa
>> s
>> > required.
>> almost
>> DO
>> WN
>> > THRUST.
>> handlin
>> g
>> > Peter
>> FORUMS -
>> WIKI -
>> b Site -
