		jkuehn(at)mountaintime.my Guest
				 Posted: Wed Jul 26, 2006 7:16 pm    Post subject: Static RPM - 912UL |
				I had my 912 UL set at 5000 static, and I noticed some oil burn and
 sooty spark plugs.  I called Lockwood, the USA Rotax importer, and their
 very capable tech support told me to run this engine at 5500 RPM
 static.  Anything less, he said, was like pulling a huge trailer with a
 Volkswagen. I was lugging the engine, he said.   At 4500 you are only
 getting maybe 60 horsepower.  I set the prop flatter, to achieve the
 5500 static RPM and the difference in take-off power is dramatic.  It
 jumps right off.  I think you have to just be attentive to throttle
 setting in cruise.  You may need that power sometime!  If you set your
 static RPM that low you are cheating yourself out of horsepower, and
 this could even be a safety issue.  I am flying a Sky Ranger which is
 not very "clean" so I do not have the over speed problem.  I think your
 airplane is perhaps cleaner, and therefore you can overspeed the
 engine.  There are always trade-offs!  Mine maxes out in cruise at just
 about 5800, and climbs at about 60 MPH at 5500, with the nose nice and high!
 Jack
 sonny wrote:
 Hello,
 I have a Pulsar XP with a Rotax 912UL.  When I first bought the plane it had a GSC 2-blade prop but I switched it to a 3-blade carbon fiber prop (made by the same company as Kiev props).  After installing the new prop, I initially set the static RPM for 5200 like the old prop, however on takeoff I nearly over sped the engine when I started to level out.  I believe it was set at 22 degrees or so (it was a long time ago).  So I tried several different settings to get the max in-flight RPM of about 5700.
 OK, here's the downside: My static RPM is about 4400.  During takeoff it still accelerates quickly...the RPMs are usually around 4800 - 4900 on climb out.  I would much rather prefer the RPMs to be in the higher range to maximize takeoff power, but so far I haven't noticed a problem with the lower RPMs.
 My questions are, do any of you have your static RPMs set this low?  Does anyone think it's a problem that they're that low?  I'm getting ready to move from sea-level to an airport that's at about 4000 ft.  Should I set the static to be around 4800 RPMs and be careful not to over speed the engine at cruise?  I don't like this idea as it's easy to get distracted, and Rotax recommends tearing the engine down in the event of an over speed.  Any recommendations or advice is welcome.  Thanks.
 Best regards,
 Sonny W.
 Pulsar XP  N912SS
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Thom Riddle
				 Posted: Thu Jul 27, 2006 3:21 am    Post subject: Static RPM - 912UL |
				Sonny,
 It is all a compromise. Think of a fixed pitch (or ground adjustable)
 prop sort of like a single speed transmission in your car. If your
 drive in low gear (low pitch) you can accelerate and climb hills like
 crazy but your top speed is very limited. If you drive off in top gear,
 the engine will lug and you will accelerate and climb hills slowly. In
 some intermediate gear you will have a compromise between acceleration
 and cruise speed. If you are driving a dune buggy then the top speed is
 not important but if you are driving a faster car on the Autobahn, then
 cruise speed is important. Same with airplanes with fixed pitch props.
 The "proper" static rpm depends mostly on two things, one of which is
 how fast your airplane is. The other is  whether you want the best
 cruise performance, best climb performance or a compromise between the
 two. Lockwood's flat statement about static rpm  of 5,500 rpm is
 nonsense and does not take into account either of these two very
 important variables.
 I fly an Allegro 2000 with the 912UL (80 hp) engine and three blade
 Woodcomp composite prop. Our prop is set for best cruise (5,500 rpm
 with wide open throttle in straight and level flight) at density
 altitudes below about 7,000'.  Under these conditions our Allegro
 reaches a top speed of 126 mph TAS which is about 15-16 mph over our
 normal cruise speed at 75% power. WIth the prop set like this it gets
 about 4,950 rpm static (no wind, which is important) and has decent
 climb performance. If we reduced the pitch so that the static rpm was a
 little higher, the climb would improve but we would not be able to fly
 with wide open throttle in straight and level flight without exceeding
 the 5,500 rpm max. cruise rpm and our normal cruise speed of 110 mph
 would require a little higher rpm and a bit more fuel consumption.
 However, we would be able  to get 5,500 rpm at higher altitudes.
 Your airplane is a bit  faster than the Allegro and a lot faster than a
 SkyRanger. The faster the airplane, the lower the static rpm (higher
 the pitch) must be to reach best cruise speed in S&L flight. So I think
 if you set your static rpm for initial flight at around 4,900-5,000 rpm
 (no wind) then this will be a compromise setting that is good enough
 for the first flight. If you ultimately want the prop to be set at best
 cruise at low DAs then adjust the prop so that you get 5,500 rpm with
 wide open throttle at low DA. Since you are moving to a higher
 elevation airport, the best cruise pitch will probably be just a little
 less (higher static rpm) than at sea level. If you want better climb
 then the static rpm no more than 100 rpm for each test until you find
 the ideal pitch for your most  common flight profile. Good luck.
 Thom in Buffalo
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		NYTerminat(at)aol.com Guest
				 Posted: Thu Jul 27, 2006 1:23 pm    Post subject: Static RPM - 912UL |
				Sound like you would be a great candidate for an in flight adjustable pitch  prop.
   Bob  Spudis
 N701ZX
 CH701/912S
  In a message dated 7/27/2006 7:22:33 A.M. Eastern Daylight Time,  jtriddle(at)adelphia.net writes:
		ami(at)MCFADYEAN.FREESERV Guest
				 Posted: Thu Jul 27, 2006 2:19 pm    Post subject: Static RPM - 912UL |
				My climb out rpm is 4800.  How can this be "lugging" the engine when it
 develops maximum torque and is at its maximum efficiency at hits point?!
 But this is with the ULS engine that has a surfeit of power. If your
 airframe is a bit marginal on 80hp then this may not work for you.
 By happy coincidence, the prop setting that allows this also results in
 5800rpm at Vne (Europa, 172mph), but who wants to hold Vne for more than 5
 minutes.
 Another factor to consider is balanced field performance (i.e. being able to
 take off in a similar distance to the distance it takes to land). What's the
 point of not being able to land back where you took off from? Or worse, vice
 versa!
 Duncan McF.
		lostpilot28
  Joined: 26 Jul 2006 Posts: 7 Location: Southern California
				I agree...now if I could just find one that was inexpensive.
  Sonny W.
		dave(at)cfisher.com Guest
				 Posted: Thu Jul 27, 2006 2:57 pm    Post subject: Static RPM - 912UL |
				Duncan,
 At 4800 rpm are you WOT ? If so you are infact lugging your engine.
 http://www.rotec.com/engines/4sf.htm
 How do you figure this ?   <<develops maximum torque and is at its maximum
 Dave
		Thom Riddle
				 Posted: Fri Jul 28, 2006 4:27 am    Post subject: Static RPM - 912UL |
				Sonny,
 I had a GSC in-flight adjustable prop on my old Titan Tornado and it
 was great. I believe the cost is around $1,400. It is mechanically
 adjusted with a vernier control just like that of a constant speed
 prop, but without the governor. In my opinion it is better than the IVO
 electric adjustable in common use in the USA.  If you are interested,
 there website is
 http://www.ultralightprops.com/gta_inflight_adjustable_props/
 adjustprops.htm
 I don't have one on the Allegro because we want to keep it legal S-LSA.
 Thom in Buffalo
Buffalo, NY (9G0)
- Anonymous |
				 Posted: Fri Jul 28, 2006 7:35 am    Post subject: Static RPM - 912UL |
				Thom,
 I had not seen the GSC props.  They look really good, and the in-flight
 adjustable looks simple and elegant.  I am not altogether happy with my
 Ivo three blade for a couple of reasons:  first there is no good
 provision for leading edge protection, the stainless steel tape they
 recommend does not stay put for long.  The prop itself does not appear
 very presicely made and I can't get away from the feeling that I would
 have a smoother running setup with something else.  The adjustment
 mechanism is easy and effective, but I would trade that for higher
 quality, and I am tempted by the in-flight adjustable feature for all
 the reasons we have heard in these pages.  There is another good looking
 prop that is relatively new.  Check out:
 http://www.tampabayaerosport.com/propellers.html
 <http://www.tampabayaerosport.com/propellers.html>
 Does anyone have experience with this setup?
 Jack
		Thom Riddle
				 Posted: Fri Jul 28, 2006 9:59 am    Post subject: Re: Static RPM - 912UL |
				Jack,
 One (main) reason I liked the GSC vs. all the electric operated props is that it is mechanical and you tell by the number of turns on the knob exactly where you are in pitch. There is no gauge nor need for one. The electric props, at least the ones I've seen, have brush wear issues and you cannot tell exactly where you are in the pitch range.
 Also, the prop is very well  built and rugged. Mine had the Maple blades (light weight) with a leading edge insert of some sort of black material that was harder than all the rocks and stones that hit. With the pusher configuration, the main gear tends to pick up stones and throw them into the prop. My prop showed no damage after 6 years and three hundred hours of use. If you prefer, they can also fit Warp Drive blades to their prop hub.
 I know it sounds like I'm selling the GSC but I'm just pilot who has had very good results with the product.
Buffalo, NY (9G0)
- Anonymous |
