craneplanes
Posted: Fri Nov 19, 2021 10:35 am Post subject: Flaps Deflection |
Galen (or anyone with a TR-4),
Would you mind measuring the difference in degrees between your flaps in the up position and full down position? I am looking for the degrees of deflection for setting my full flaps.
If you don’t have a handy tool already, you can download a BubbleLevel app for your cell phone that is very accurate.
Any help would be very much appreciated.
-Doug Crane
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
dadmeyers1951(at)gmail.co Guest
Posted: Fri Nov 19, 2021 11:19 am Post subject: Flaps Deflection |
I will try. We need to do that anyway; it seems our full down position must be close to 40 degrees. We are thinking about adding a mid position as full down seems to be too much; it gets squirrelly close to ground effect.Glenn Meyers
N343BS.
On Fri, Nov 19, 2021, 12:36 PM Doug Crane <craneplanes(at)gmail.com (craneplanes(at)gmail.com)> wrote:
-Doug Crane
GalinHdz
Posted: Fri Nov 19, 2021 11:50 am Post subject: Flaps Deflection |
I have 12 and 24 degrees of flaps. Some have 12, 24 and 32 degrees.
On Fri, Nov 19, 2021 at 1:36 PM Doug Crane <craneplanes(at)gmail.com (craneplanes(at)gmail.com)> wrote:
-Doug Crane
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Fri Nov 19, 2021 3:47 pm Post subject: Flaps Deflection |
Glenn
I have electric flaps with a 12,24,36 degree stop. Rarely ever use the 36 full settings.
Bob Reed
Quote: | On Nov 19, 2021, at 1:20 PM, Glenn <dadmeyers1951(at)gmail.com> wrote:
N343BS.
-Doug Crane
Posted: Fri Nov 19, 2021 4:58 pm Post subject: Flaps Deflection |
That's sounds about right based on what Galin said. Ours are manual. I
think we need to add the center notch. First notch is a little light and
full seems a bit much.
On Fri, Nov 19, 2021, 5:50 PM Robert Reed <robertr237(at)att.net> wrote:
[quote] Glenn
full settings.
Bob Reed
GalinHdz
Posted: Sat Nov 20, 2021 4:54 am Post subject: Flaps Deflection |
FWIW, I always take off with zero flaps. Once you have flown some hours on yours, you will find what works best for you.
BTW, I also have manual flaps very similar to a Piper Cherokee.
On Fri, Nov 19, 2021 at 9:53 PM Doug Crane <craneplanes(at)gmail.com (craneplanes(at)gmail.com)> wrote:
Quote: | Thank you for the responses. And do you guys takeoff with any flaps?
-Doug Crane
On Fri, Nov 19, 2021 at 18:59 Glenn <dadmeyers1951(at)gmail.com (dadmeyers1951(at)gmail.com)> wrote:
Quote: | That's sounds about right based on what Galin said. Ours are manual. I think we need to add the center notch. First notch is a little light and full seems a bit much.
On Fri, Nov 19, 2021, 5:50 PM Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
Bob Reed
Quote: | On Nov 19, 2021, at 1:20 PM, Glenn <dadmeyers1951(at)gmail.com (dadmeyers1951(at)gmail.com)> wrote:
N343BS.
-Doug Crane
Posted: Sat Nov 20, 2021 6:05 am Post subject: Flaps Deflection |
I have two partners in our plane and we are hangared on a grass field. I usually take off with one notch of flaps if anyone more than myself. It seems to get me in ground effect quicker.Glenn
On Sat, Nov 20, 2021, 6:55 AM Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
Quote: | FWIW, I always take off with zero flaps. Once you have flown some hours on yours, you will find what works best for you.
-Doug Crane
Bob Reed
N343BS.
-Doug Crane
craneplanes
Posted: Sat Nov 20, 2021 6:20 am Post subject: Flaps Deflection |
Perfect info. Thanks everybody.
I sent my engine out to be rebuilt (basically sat for 7-8-years) and should get it back by Christmas. Finishing up rebuilding the doors. Next is rigging the flight controls (hence the questions). I hope to be flying by late spring! Check out the KIS FaceBook page for pics and status.
-Doug
On Sat, Nov 20, 2021 at 08:09 Glenn <dadmeyers1951(at)gmail.com (dadmeyers1951(at)gmail.com)> wrote:
Quote: | I have two partners in our plane and we are hangared on a grass field. I usually take off with one notch of flaps if anyone more than myself. It seems to get me in ground effect quicker.Glenn
-Doug Crane
Bob Reed
N343BS.
-Doug Crane
smsweitzer81(at)gmail.com Guest
Posted: Sat Nov 20, 2021 8:08 am Post subject: Flaps Deflection |
Please remove me from these emails.Thank you,
Sam
On Sat, Nov 20, 2021, 8:20 AM Doug Crane <craneplanes(at)gmail.com (craneplanes(at)gmail.com)> wrote:
-Doug
-Doug Crane
Bob Reed
N343BS.
-Doug Crane
GalinHdz
Posted: Sat Nov 20, 2021 11:18 am Post subject: Flaps Deflection |
The few times I have taken off from grass, I also used 1 notch (12 degrees) of flaps to get into ground effect quicker.
On Sat, Nov 20, 2021 at 9:09 AM Glenn <dadmeyers1951(at)gmail.com (dadmeyers1951(at)gmail.com)> wrote:
-Doug Crane
Bob Reed
N343BS.
-Doug Crane
You are on the Kis List. You have to unsubscribe.
On Sat, Nov 20, 2021, 10:12 AM Sam Sweitzer <smsweitzer81(at)gmail.com (smsweitzer81(at)gmail.com)> wrote:
Quote: | Please remove me from these emails.Thank you,
Sam
-Doug
-Doug Crane
Bob Reed
N343BS.
-Doug Crane
GalinHdz
Posted: Sat Nov 20, 2021 11:19 am Post subject: Flaps Deflection |
That has to be done by MATRONICS. Nobody on this list can do that.
On Sat, Nov 20, 2021 at 11:12 AM Sam Sweitzer <smsweitzer81(at)gmail.com (smsweitzer81(at)gmail.com)> wrote:
Sam
-Doug
-Doug Crane
Bob Reed
N343BS.
-Doug Crane
GalinHdz
Posted: Sat Nov 20, 2021 11:21 am Post subject: Flaps Deflection |
KIS Facebook page? What about those of us that don't have, and don't want,
a Facebook account?
On Sat, Nov 20, 2021 at 2:19 PM Glenn <dadmeyers1951(at)gmail.com> wrote:
[quote] You are on the Kis List. You have to unsubscribe.
On Sat, Nov 20, 2021, 10:12 AM Sam Sweitzer <smsweitzer81(at)gmail.com>
> Thank you,
> Sam
>> -Doug
>>> Glenn
>>> On Sat, Nov 20, 2021, 6:55 AM Galin Hernandez <galinhdz(at)gmail.com>
>>>> On Fri, Nov 19, 2021 at 9:53 PM Doug Crane <craneplanes(at)gmail.com>
>>>>> -Doug Crane
>>>>> On Fri, Nov 19, 2021 at 18:59 Glenn <dadmeyers1951(at)gmail.com> wrote:
