CS prop system
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List
sjbeaver(at)gmail.com
PostPosted: Mon Dec 20, 2021 7:57 am    Post subject: CS prop system Reply with quote
I have a great deal of reference information on LOM engines and props, but I can find nothing at all about the constant speed prop adaptor shown in the picture below. I assume the gold part contains high pressure seals and passes oil into the crankshaft, then through the aluminum turning and into the prop.
Does anyone have any information on this assembly? I need to convert the engine to a fixed pitch wooden prop and a drawing would help me do that with more confidence.
THanks, Steve-- Stephen BeaverTel: 614-937 4189
[img]cid:nIA9oXul2LhsD6ovRYFl[/img]
- The Matronics Lom-List Email Forum -
http://www.matronics.com/Navigator?Lom-List
 Filesize:  220.76 KB
 Viewed:  15635 Time(s)
PostPosted: Tue Dec 21, 2021 5:31 am    Post subject: CS prop system Reply with quote
Thank you Mike,
My challenge is how to remove the prop hub and the gold colored seal assembly. There appear to be no drawings available for that. The problem with working on props is that without a drawing is that you can't tell whether something isn't supposed to come off that way or just needs a bigger hammer Smile Steve-- Stephen BeaverTel: 614-937 4189
On Dec 20, 2021, at 22:54, <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> wrote:
I have attached scans from my prop manual for a V451 and apologise for the poor quality but that is all that I have.
If I can assist you further do not hesitate to ask
Hope this helps you
Keep well
From: owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com) <owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com)> On Behalf Of sjbeaverSent: December 20, 2021 7:57 AMTo: Lom-List Digest Server <lom-list(at)matronics.com (lom-list(at)matronics.com)>Subject: CS prop system
THanks,
<image001.jpg>
<LOM PROP 1.jpg><LOM PROP 2.jpg>
PostPosted: Tue Dec 21, 2021 9:27 am    Post subject: CS prop system Reply with quote
Yes, I see the problem now Forgot that my engine arrived with the gold coloured hub attached
If you do get it off what will you replace it with?
Keep well
On Dec 21, 2021, at 5:31 AM, sjbeaver <sjbeaver(at)gmail.com> wrote:
Thank you Mike,
Hope this helps you
Keep well
THanks,
<image001.jpg>
PostPosted: Tue Dec 21, 2021 9:28 am    Post subject: CS prop system Reply with quote
The forward nose bearing case from a 332A or AK Steve-- Stephen BeaverTel: 614-937 4189
On Dec 21, 2021, at 12:27, mike Pienaar <mikepienaar09(at)gmail.com (mikepienaar09(at)gmail.com)> wrote:
Keep well
Mike Sent from my iPhone
On Dec 21, 2021, at 5:31 AM, sjbeaver <sjbeaver(at)gmail.com (sjbeaver(at)gmail.com)> wrote:Thank you Mike,
Hope this helps you
Keep well
THanks,
<image001.jpg>
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lom-List All times are GMT - 8 Hours
