Alternator Field Failure?
farmrjohn
PostPosted: Sun Jan 02, 2022 5:37 pm    Post subject: Alternator Field Failure? Reply with quote
I have an O200 with a TCM 633661 alternator and Zeftronics R15V00 Rev. A regulator. On my last flight charging to the bus/battery stopped. After replacing the regulator with a know good one and still no charging I started to follow the Zeftronic installation/trouble shooting instructions. Checking the resistance for the field resulted in infinite resistance from the field terminal to ground whereas the instructions indicated 3.5-6 ohm is normal resistance. I'm assuming this would indicate a break in the field wiring and hence no charging or could the problem be something else?. If so, is this repairable? Are there alternative alternators (certificated airplane) if replacement is necessary? Thanks, John
PostPosted: Sun Jan 02, 2022 7:20 pm    Post subject: Alternator Field Failure? Reply with quote
At 07:37 PM 1/2/2022, you wrote:
--> AeroElectric-List message posted by: "farmrjohn" <faithvineyard(at)yahoo.com>
There are carbon brushes that ride on slip
rings to conduct output from the regulator to
the moving field coil. These are a service-life
limited part . . . they wear out.
Since this is a TC aircraft, regs require
service by a 'qualified' facility. But if
you're adventuresome, you could disassemble
it for inspection and see what the brushes
look like.
A spec-rebuilt alternator is breathtakingly
expensive . . . over $1500
out of that stuff?"
PostPosted: Mon Jan 03, 2022 12:04 pm    Post subject: Alternator Field Failure? Reply with quote
What kind of airplane? How is it used?
out of that stuff?"
skywagon185(at)gmail.com
PostPosted: Mon Jan 03, 2022 1:41 pm    Post subject: Alternator Field Failure? Reply with quote
Hmmm....Isn't that TCM alternator essentially a Ford unit ...??.
I believe standard Ford parts will fix most anything in the unit.,
I also suspect that if you took it to any alternator shop and said it was out of your boat or tractor, that they would go through it, test and replace parts for a fraction of the cost.
D
On Sun, Jan 2, 2022 at 7:22 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "farmrjohn" <faithvineyard(at)yahoo.com (faithvineyard(at)yahoo.com)>
  look like.
  out of that stuff?"
PostPosted: Mon Jan 03, 2022 4:00 pm    Post subject: Alternator Field Failure? Reply with quote
At 03:40 PM 1/3/2022, you wrote:
Hmmm....
I believe standard Ford parts will fix most anything in the unit.,Â
That works sometimes . . . problem is that the front
end bell obviously mates with an aircraft engine.
Some folks have claimed that the engine was on
an airboat. Or simply took bad parts from the
afflicted device down to the local service facility
in search of 'matches'.
Some years ago a reader found the Lester number
for a stock automotive alternator with the same
internal guts as his TCM alternator. It was cheaper
to buy a reman alternator over the counter to
part out than to buy holy-watered parts.
If the alternator in question DOES have worn
out brushes, you may find suitable matches
at an overhaul shop. Bearings are no big deal
either . . . easily sourced from lots of places.
out of that stuff?"
farmrjohn
PostPosted: Mon Jan 03, 2022 6:52 pm    Post subject: Re: Alternator Field Failure? Reply with quote
Thanks all. My mechanic will be at the hangar on Wednesday. The engine/alternator are on an Alon A2. Is it necessary to pull the left magneto to remove the alternator? I think we have a lead on a shop for an IRAN vs. replacement, although I wouldn't mind a lighter weight unit to save a pound or two. John
farmrjohn
PostPosted: Mon Jan 03, 2022 8:13 pm    Post subject: Re: Alternator Field Failure? Reply with quote
As an alternative it looks like Plane Power has an alternative via STC SA10921SC using the ER14-50 alternator. That comes with its own regulator. Would the Zeftronic R15V00 Rev. A work?
WebPage-3.pdf
 Filename:  WebPage-3.pdf
 Filesize:  2.83 MB
 Downloaded:  428 Time(s)
PostPosted: Tue Jan 04, 2022 9:31 am    Post subject: Alternator Field Failure? Reply with quote
Yes
out of that stuff?"
