What did you do with your Europa this week, 1/10 - 1/17
h&jeuropa
PostPosted: Tue Jan 11, 2022 1:00 pm    Post subject: What did you do with your Europa this week, 1/10 - 1/17 Reply with quote
Starting thread for this week. Bitter cold and a foot of snow in Michigan. Sunny but no flying!
Jim
wdaniell.longport(at)gmai
PostPosted: Wed Jan 12, 2022 1:12 pm    Post subject: What did you do with your Europa this week, 1/10 - 1/17 Reply with quote
In Florida we have had a rare weather situation - last weekend was not a perfect flying weekend.
Recently I have changed the bushings and all the hoses in front of the firewall.  In the process I installed a thermostat because I have the unusual condition of an engine which runs too cold - oil temps down to 55C in winter (florida winter min 65F).  The thermostat has definitely cured this issue and the oil temp sits between 85-110C.
I also installed a bandc voltage regulator with built in OVP protection.  This is a nice looking unit and now my voltage is steady at 14.3.  Better yet I have removed the separate OVP and relay because the bandC unit has OVP built in.  This also appears to have cured the occasional runaway amp reading - amps running up to 70A and then shutting down the dynon instrument.
I also installed a new brush unit in my airmaster.
My old style front wheel had a loose bearing and was a bit wobbly.  Regreased and tightened up everything.
Next task to change all the hoses aft of the firewall.
it never ends does it?
William Daniell
LONGPORT
+1 786 878 0246
On Tue, Jan 11, 2022 at 4:05 PM h&amp;jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
--> Europa-List message posted by: "h&amp;jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
Jim
http://forums.matronics.com/viewtopic.php?p=505665#505665
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
