TACHO and FLYDAT
Patrick Tunney
PostPosted: Mon Mar 07, 2022 11:40 am    Post subject: TACHO and FLYDAT Reply with quote
Hi
I am not having much success with pairing a Flydat and a Aviasport / Rotax tacho.
The Flydat records correct RPM but the Tacho reads half of the Flydat.
If i disconnect the Flydat the Tacho reads correct.
Has anybody else experienced this issue or is there a special way to wire the pair together.
I have read all guides and understand the need for a resistor but i dont think i am at that point.
I would be interested to hear from any user that has both the Flydat and a Tacho
Pat
n7188u
PostPosted: Mon Mar 07, 2022 4:51 pm    Post subject: Re: TACHO and FLYDAT Reply with quote
I know you are talking about a different unit but I was told I couldn’t have both my new mgl ems-1 and the rotax tach at the same time (per mgl). So left the rotax tach connector and wiring untouched and ran a new wire and connector for the mgl. That way, if I’m traveling, I can swap if the mgl fails (not in the air of course). I guess I could have a switch but too lazy to do that.
Still, if anyone knows how to have both working I’m all ears. Probably just an impedance issue.
Chris
