dlm34077(at)gmail.com Guest
Posted: Tue May 17, 2022 8:47 am Post subject: CB tip |
When installing individual circuit breakers, try using 8-32 3/8" cap screws. When it comes time to change the breaker a cap screw can be easily accessed by an allen wrench whereas the phillips head screws require pressure to remove. Likewise when reinserting the CBs a cap screw can be held in place at the end by an allen wrench with a trace of fuel lube.
Tim Olson
Posted: Tue May 17, 2022 9:23 am Post subject: CB tip |
I like that tip! Too many times I've been under the panel with a
phillips or worse yet, slotted screw to go on a breaker or switch.
If they make short 8/32 brass cap screws that may be perfect.
You've given me something to search for.
Thanks!
On 5/17/2022 11:46 AM, dlm wrote:
Quote: | When installing individual circuit breakers, try using 8-32 3/8" cap screws. When it comes time to change the breaker a cap screw can be easily accessed by an allen wrench whereas the phillips head screws require pressure to remove. Likewise when reinserting the CBs a cap screw can be held in place at the end by an allen wrench with a trace of fuel lube.
Ceengland
Posted: Tue May 17, 2022 9:38 am Post subject: CB tip |
I wonder if they'll work to mount a fuse block. Of course, I've never had to change a fuse block, but still...
Charlie
On 5/17/2022 12:23 PM, Tim Olson wrote:
Quote: | I like that tip! Too many times I've been under the panel with a
Thanks!
_________________ Charlie |
Lenny Iszak
Posted: Tue May 17, 2022 9:53 am Post subject: CB tip |
Great idea!
These would work:
https://www.mcmaster.com/93465A192/
https://www.mcmaster.com/97715A142/
I like the second one better, it has more contact surface with the terminal.
Lenny
On May 17, 2022 at 1:23:01 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
Thanks!
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
m.r.92129(at)gmail.com Guest
Posted: Tue May 17, 2022 11:36 am Post subject: CB tip |
How about McMaster part no:
97715A141/Martin
Quote: | On May 17, 2022, at 10:23 AM, Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> wrote:
I like that tip! Too many times I've been under the panel with a phillips or worse yet, slotted screw to go on a breaker or switch. If they make short 8/32 brass cap screws that may be perfect. You've given me something to search for. Thanks! Tim On 5/17/2022 11:46 AM, dlm wrote:
