		jindoguy(at)gmail.com Guest
				 Posted: Fri Jul 28, 2006 8:00 am    Post subject: Control positioning during ground handling |
				I've been having a discussion off list with another Kolb flyer about control positioning while taxing. I remarked that I never taxi without the stick full forward and the ailerons set to "dive away from the wind" in a cross and down wind condition. He does the opposite, but hadn't really given it much thought, and suggested bringing the discussion to the list for a general poll.
 Rick Girard
 "Ya'll drop on in"
 takes on a whole new meaning
 when you live at the airport.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Russ Kinne
				 Posted: Fri Jul 28, 2006 10:30 am    Post subject: Control positioning during ground handling |
				Rick
 When I was in training my CFI told me "Stick all the way back all the
 time you're on the ground'
 So I did.
 Until in a strong gusty wind, taxiing after landing, a gust hit me
 and suddenly I was 5 feet in the air and rapidly going over
 backwards! -- (Cessna 170) an attention-getter to be sure. I caught
 it, no damage, but then realized that was very poor advice
 Stick should be FORWARD in any kind of headwind -- then  a gust will
 simply lif the tail.
 It's a simple concept -- put the stick INTO the wind if it's from the
 front, and AWAY from the wind if it's from anywhere aft. It positions
 the aelirons correctly too, to avoid lifting a wing.
 This will keep you out of trouble. This kind of trouble, anyway.
 Russ Kinne
 On Jul 28, 2006, at 11:58 AM, Richard Girard wrote:
  	  | Quote: | 	 		   I've been having a discussion off list with another Kolb flyer
  Rick Girard
  "Ya'll drop on in"
		planecrazzzy Guest
				 Posted: Fri Jul 28, 2006 12:33 pm    Post subject: Re: Control positioning during ground handling |
				Here's a "saying" that I was taught and it's easy to remember....
  Wind Behind - "Blows the stick"
 Headwind -  "Pull back , stick into wind"
  This was a GREAT "saying" for "ME" , otherwise I had to think about it too
 much.....
                                  Gotta Fly...
                                                  Mike in MN
 PS "saying" was told to me by a long time Pilot & instructor at Stanton
 Airport, His name is Hank... ( he's got a Purty Cub )
		dcreech3(at)hotmail.com Guest
				 Posted: Fri Jul 28, 2006 5:39 pm    Post subject: Control positioning during ground handling |
				Or: "CLIMB TOWARD THE WIND; DIVE AWAY FROM IT."  Putting this mantra into
 effect will result in best positioning of both elevator and ailerons. For
 practice, it's an interesting exercise to taxi in a circle while maintaining
 the proper stick position all the way around.  For example, if you start
 with a quartering left headwind, the stick will be in the left rear corner
 (you're "climbing toward" the wind.)  As you turn to the left, the stick
 moves laterally to the right and ends up in the right rear corner, as the
 relative wind moves across the nose to the right.  As you continue the turn,
 the stick then moves on a diagonal, through the center position as the wind
 crosses the beam, reaching the forward left corner as the wind becomes a
 quartering right tailwind. (You're "diving away" from the wind now).
 Continuing the turn, the stick moves sideways to the forward right corner as
 the wind reaches the left side of the tail, and then finally back on the
 opposite diagonal as the wind comes around the wingtip to the left side of
 the nose again.  So the stick pattern is an "X" connected by sideways
 movements at the top and bottom.  A little hard to describe, but easy to
 visualize and remember once you've done it.
 Of course, no Kolb driver ever forgets the special significance of the
 relationship between elevator and throttle position!
 Lee
 Firestar II
  	  | Quote: | 	 		  From: "planecrazzzy" <planecrazzzy(at)yahoo.com>
 Reply-To: kolb-list(at)matronics.com
 Subject: Re: Control positioning during ground handling
 Date: Fri, 28 Jul 2006 13:33:16 -0700
 too
 much.....
                                   Gotta Fly...
                                                   Mike in MN
 http://forums.matronics.com/viewtopic.php?p=50397#50397
				 Posted: Fri Jul 28, 2006 6:15 pm    Post subject: Control positioning during ground handling |
				Kolbers,
 Place a little yarn on the windshield so you are not surprised by wind
 direction. Always hold the stick into the wind.  If the wind is from the
 left, hold the stick to the left to side slip into the wind.  If the wind is
 from the front, hold the stick to the front to prevent climbing.  If the
 wind is from the tail hold the stick back to prevent the wind from raising
 the tail.  And use combinations for quartering winds.
 Jack B. Hart FF004
 Winchester, IN
		a58r(at)verizon.net Guest
				 Posted: Fri Jul 28, 2006 7:16 pm    Post subject: Control positioning during ground handling |
				Looking at an old  '53 Cessna 172 Pilots' Handbook, I see the exact
 stick procedure that is presented in these mgs. As I was taught in
 '40, use the stick like a potato masher: mash it around in all four
 quadrants, according to the wind's direction vs plane.
 regards,
 Bob N.
		APilot(at)webtv.net Guest
				 Posted: Fri Jul 28, 2006 8:55 pm    Post subject: Control positioning during ground handling |
				So far, I have not found fault in anything that Wolfgang mentioned in
 his classic book "Stick and Rudder".  Have always tried to put the yoke
 or stick where he recommends in all kinds of wind situations.  Works
 every time......so far.  One thing that I have noticed is that some
 pilots do not understand the yaw control offered by the ailerons when
 the wheels are on the ground.  The early Kitfoxes had smaller rudders
 and the factory went to bigger rudders rather than trying to educate all
 of the various pilots of the advantages of proper aileron control when
 the rudder does not do the job.
		Dave Bigelow
  Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
				 Posted: Sat Jul 29, 2006 1:18 am    Post subject: Re: Control positioning during ground handling |
				"I've been having a discussion off list with another Kolb flyer about control positioning while taxing"
 Wind forward of wingtips - stick into wind (tail dragger and tricycle Gear).
 Wind aft of wingtips - forward stick away from wind (tail dragger).
 Wind aft of wingtips - aft stick away from wind (tricycle gear).
 It's intuitive and obvious with the wind forward of the wing tips.  Once it is aft of the wingtips, you need to picture the control surface positions - you'll see why then.
  _________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
				 Posted: Sat Jul 29, 2006 2:25 am    Post subject: Control positioning during ground handling |
				At 02:18 AM 7/29/06 -0700, you wrote:
 Dave,
 This is not good advice for a Kolb. Propeller air flow does not influence
 the horizontal stabilizer but the wind does.  You want to hold the tail
 down or stick back when taxiing downwind, especially in grass.  With a
 high thrust line, it is very easy to put the FireFly on its nose in grass
 with the wind coming from behind.
 Jack B. Hart FF004
 Winchester, IN
		jimhefner
				 Posted: Sat Jul 29, 2006 4:53 am    Post subject: Re: Control positioning during ground handling |
				What Jack says might be ok for grass but I wouldn't advise stick back with wind behind... elevators up... if it's blowing very hard.  That could get you on your nose on pavement, especially since Kolb's don't have a lot of weight on the tail wheel with front gear set back more than normal.  I always follow the normal stick positioning in wind with my FF and have never had a problem, but I haven't flown much from grass strips, so what Jack says might be valid for there, I don't know.
  _________________ Jim Hefner
Tucson, AZ
Do Not Archive |
		Dave Bigelow
				 Posted: Sun Jul 30, 2006 1:36 am    Post subject: Re: Control positioning during ground handling |
				 	  | Quote: | 	 		  This is not good advice for a Kolb. Propeller air flow does not influence
 down or stick back when taxiing downwind, especially in grass.  |
 Jack,
 Think about where the elevator is with stick back - it's up.  With the wind behind, that will lift the tail (tail dragger), which is not what you want.
 I imagine it would take at least 20 knots of tail wind to lift the tail in this manner if the stick were full back.  We are probably "knit picking" the subject to death, since it would be pretty unusual to be taxiing a Kolb downwind in 20 + knots of wind.  I believe the aileron position is more important.  Letting the wind get under a wing and lift it is a real disaster.
Kamuela, Hawaii
FS2, HKS 700E |
				 Posted: Sun Jul 30, 2006 3:52 am    Post subject: Control positioning during ground handling |
				At 02:36 AM 7/30/06 -0700, you wrote:
 Jack,
 Dave Bigelow
 Kamuela, Hawaii
 FS2, Rotax 503 DCDI
 Dave,
 Think of the horizontal stabilizer and elevator as an air foil.  If the elevator is up, the air foil shape is flat across the top and curved on the bottom, just the opposite of the wing.  So if the wind comes from the front or rear it passes over the up elevator and the lift vector on the tail is going to be down.
 At I22 it is not uncommon to taxi in winds of 20+ mph.
 Jack B. Hart FF004
 Winchester, IN
		jimh474(at)earthlink.net Guest
				 Posted: Sun Jul 30, 2006 4:09 am    Post subject: Control positioning during ground handling |
				Jack;
  I think you got your Ox in the Yoke a wee bit  backwards. If the elevator is up and the wind is coming from the rear, the wind  will lift the tail. If the wind is coming from the front, the wind will push the  tail down.
  Jim Hauck
 On 7/30/2006 8:59:16 AM, kolb-list(at)matronics.com (kolb-list(at)matronics.com) wrote:
 [quote]  --> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
  >--> Kolb-List  message posted by: "Dave Bigelow" <up_country(at)hotmail.com (up_country(at)hotmail.com)>
  influence
  >Jack,
  >Dave Bigelow
   >Kamuela, Hawaii
  >FS2, Rotax 503 DCDI
  Dave,
				 Posted: Sun Jul 30, 2006 5:59 am    Post subject: Control positioning during ground handling |
				Well, I've got to say, I'm surprised by the responces to this informal poll. I didn't weigh in, except to state the difference of opinion between myself and the Kolber I was chatting with, so I'll put my 2 cents worth in.
  There is no difference in control positioning when taxiing a tricycle gear airplane or a taildragger, none.
 Lift is about Newton's third law of motion and Bernoulli is just a fancy way of explaining how air that was forced up to go over the wing is then pulled downward from whence Newton takes over again.
 Holding the elevator up when going downwind IS a good way to end up ass over tea kettle. Wind hitting a raised elevator will be forced downward and the tail goes where?
 Now, as to keeping the stick forward while taxiing upwind, this is a Kolb (or any other pusher taildragger) exclusive. There's no prop out front to hit the ground. If I were in a Cub, say, I'd change my way of thinking, but I'm not. In the gusty prairie winds, I'd much rather fly the tail should it come up than try to get a stalled tail to exercise control over a rising wing.
 With the stick forward, I roll on throttle with my left hand, ease in right rudder to counter P factor and gyroscopic precession of the prop disk itself, and begin a smooth pull back on the stick as the tail rises. I don't have to practice my butter churning technique with the stick this way, every motion is in one direction.
 For those of you wondering how a MK III driver advances the throttle with his left hand, it's simple. PIC seating on mine is on the right.
 Rick Girard
 "Ya'll drop on in"
		planecrazzzy Guest
				 Posted: Sun Jul 30, 2006 6:10 am    Post subject: Re: Control positioning during ground handling |
				So your saying....You really didn't want an "answer"....
  Just a reason to get up on the Soap Box.....
  Kinda like Fishing....Just threw out some bait.....
                      Gotta start building another plane,
        Mike in MN
				 Posted: Sun Jul 30, 2006 8:19 am    Post subject: Control positioning during ground handling |
				Ah, another great response from Baja Canada.
 On 7/30/06, planecrazzzy <planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)> wrote: [quote]--> Kolb-List message posted by: "planecrazzzy" < planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)>
        Mike in MN
		Arksey(at)aol.com Guest
				 Posted: Sun Jul 30, 2006 8:39 am    Post subject: Control positioning during ground handling |
				Thanks  Jim,
     I was becoming confused...I learned to fly in a  J-3 and we were taught to keep the stick forward when taxiing downwind  and  back when taxiing into the wind....common sense tells me that will keep the tail  on the ground. sorry Jack to not agree with you...but friends we shall  be....
  Jim Swan   Michigan
  will soon be flying a firestar
  no not archive
				 Posted: Sun Jul 30, 2006 8:52 am    Post subject: Control positioning during ground handling |
				At 08:08 AM 7/30/06 -0400, you wrote:
  	  | Quote: | 	 		     Jack;   I think you got your Ox in
 down.   Jim HauckOn 7/30/2006 8:59:16
 Jim,
 There is a very easy way to prove/disprove what I have written.
 Take your plane out and face it down wind.  Chock the main gear.  Put a tie
 down stake in the ground next to the tail wheel spring.  Tie a rope to the
 tie down stake and to the tail wheel spring.  Leave about two feet of slack
 so the tail can come up off the ground.  Get in and crank and warm up the
 engine.  Hold the stick back against the stop.  Slowly advance the throttle
 and notice the rpm the tail starts to leave the ground.  Then repeat the
 process with the stick forward against the stop.  The position of the stick
 that requires the highest rpm to lift the tail is the most favorable for
 downwind taxiing.
 Also, since there seems to be some confusion about this, I modified my
 FireFly setup drawing with the elevator in the up position.   It shows the
 FireFly on the ground in the taxiing position and it can be seen at:
 http://www.thirdshift.com/jack/firefly/elevup.jpg
 If the wind flow is horizontal to the ground, it does not matter if the wind
 is up or down wind as it passes over the horizontal stabilizer and elevator
 assembly.  In both cases the air must travel further to pass below the
 assembly than the air that passes above it.  This will place down load on
 the tail.
 Jack B. Hart FF004
 Winchester, IN
		planecrazzzy Guest
				 Posted: Sun Jul 30, 2006 9:13 am    Post subject: Re: Control positioning during ground handling |
				I just stated the facts  WITHOUT calling anybody "names"
     Thanks for the reply...
  So what the hell is Baja Canada.....Never mind, I don't care....
           Gotta Fly...
                           Mike in MN
 [quote="jindoguy(at)gmail.com"]Ah, another great response from Baja Canada.
 On 7/30/06, planecrazzzy <planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)> wrote:  	  | Quote: | 	 		  --> Kolb-List message posted by: "planecrazzzy" < planecrazzzy(at)yahoo.com (planecrazzzy(at)yahoo.com)>
 ???????????????????? Gotta start building another plane,
 ??????????????????????????????????????????????????????????????????????Mike in MN
 when you live at the airport. |
		biglar
