deanpichon(at)msn.com Guest
Posted: Sun Jul 30, 2006 4:39 am Post subject: Recommendations for Iridium plugs? |
I'd like to replace my Champion plugs with something that is less suseptable
to fouling. I don't know whether I should go with just a new set Champions,
or perhaps Iridiium plugs or another type. Any recommendation from Listers
would be most appreciated. I'm flying a -4 with an IO-360 with Lasar
ingnition.
Dean
Bolton, MA
Posted: Sun Jul 30, 2006 4:54 am Post subject: Recommendations for Iridium plugs? |
This is sure to start another mogas war, but here goes anyway. I use
mogas in my Pitts (O-360-A4-A) so don't have the fouling problem. The
cure on lesser engines is the REM 37BY, but I don't know if they'll fit
in the O-360. They were designed specifically to target the lead
fouling problem in the O-235s. I'm assuming that your fouling problem
is lead, and not oil!
The other cure is to lean the crap out of the engine at all times .....
from startup to shutdown. At any altitude. I know, that's not what
Lycoming recommends, so don't waste the bandwidth busting my chops.
Leaning agressively, like mogas, has worked for me and has for years.
Linn
Dean Pichon wrote:
suseptable to fouling. I don't know whether I should go with just a
new set Champions, or perhaps Iridiium plugs or another type. Any
recommendation from Listers would be most appreciated. I'm flying a
-4 with an IO-360 with Lasar ingnition.
Dean
Bolton, MA
http://wiki.matronics.com
rv8ch
Posted: Sun Jul 30, 2006 7:45 am Post subject: Recommendations for Iridium plugs? |
| Quote: | The other cure is to lean the crap out of the engine at all times .....
Excellent suggestions assuming the cause is lead fouling. Another
one that has worked for a lot of people is to use a lead scavenger
like Decalin TCP Plus.
http://www.decalinchemicals.com/
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Vanremog(at)aol.com Guest
Posted: Sun Jul 30, 2006 8:24 am Post subject: Recommendations for Iridium plugs? |
In a message dated 7/30/2006 5:41:37 A.M. Pacific Daylight Time, deanpichon(at)msn.com writes:
| Quote: | I'd like to replace my Champion plugs with something that is less susceptible
or perhaps Iridium plugs or another type. |
Just switch to the REM37BY.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA)
In a message dated 7/30/2006 5:58:51 A.M. Pacific Daylight Time, pitts_pilot(at)bellsouth.net writes:
| Quote: | The
in the O-360. |
I can tell you they work fine in my O-360.
az_gila
pbesing(at)yahoo.com Guest
Posted: Sun Jul 30, 2006 9:19 am Post subject: Recommendations for Iridium plugs? |
Gary, any idea how these would work with a magneto ignition? My IO-360 on my -4 fouls the bottom plugs really easily, and have to be cleaned every oil change in order keep them running well.
Paul Besing
Vanremog(at)aol.com wrote:
| Quote: | In a message dated 7/30/2006 5:41:37 A.M. Pacific Daylight Time, deanpichon(at)msn.com writes:
See the all-new, redesigned Yahoo.com. [url=http://us.rd.yahoo.com/evt=40762/*http://www.yahoo.com/preview] Check it out.[/url]
dan(at)rvproject.com Guest
Posted: Sun Jul 30, 2006 9:45 am Post subject: Recommendations for Iridium plugs? |
They ought to work just fine with mags. I run UREM37BY plugs with my Slick mag on my IO-360-A1B6. Bottom plugs. I have yet to experience a fouled plug in more than 1000 hours.
Granted, I have a Lightspeed Plasma II firing the top plugs, which must help...but at least the UREM37BY plugs on the bottom haven't had any issues.
)_( Dan
RV-7 N714D (1021 hours)
http://www.rvproject.com
Posted: Sun Jul 30, 2006 11:44 am Post subject: Recommendations for Iridium plugs? |
Best place to get them? Anything special that needs to be done for the gap?
Paul Besing
Dan Checkoway <dan(at)rvproject.com> wrote:
[quote] They ought to work just fine with mags. I run UREM37BY plugs with my Slick mag on my IO-360-A1B6. Bottom plugs. I have yet to experience a fouled plug in more than 1000 hours.
)_( Dan
az_gila
Posted: Sun Jul 30, 2006 1:52 pm Post subject: Recommendations for Iridium plugs? |
Sky Geek was cheapest last I checked.
http://www.rvproject.com/pricewatch.html
)_( Dan
az_gila
Posted: Sun Jul 30, 2006 3:29 pm Post subject: Recommendations for Iridium plugs? |
In a message dated 7/30/2006 10:20:50 A.M. Pacific Daylight Time, pbesing(at)yahoo.com writes:
| Quote: | Gary, any idea how these would work with a magneto ignition? My IO-360 on my -4 fouls the bottom plugs really easily, and have to be cleaned every oil change in order keep them running well.
Paul-
I am running the REM37BY plugs with standard Slick Mags. Just gap them for .019" and they still won't foul like the old REM38E or REM40E massives.
Charles Heathco
Posted: Mon Jul 31, 2006 2:49 pm Post subject: Recommendations for Iridium plugs? |
May have all info you need. I have Irridiums I put0 in year ago, I burn mostly mogas, so cant say much about lead exept that when I0 do burn some out of my left "takeoff" tank I have no fouling. They stay clean as0 a whislte all the time. They are expensive. Charlie0 Heathco
