peterz(at)zutrasoft.com Guest
Posted: Thu Sep 15, 2022 12:54 pm Post subject: Europa-List: Re: Wing Pin “Play†|
Are you referring to the W26C/W26A assembly? With loctite?? I doubt it, but am thoroughly confused about what you are glueing together.
On my plane, the W26C/W26A/Pip-pin assembly is causing the forward/backward wingtip slop, due to tolerance clearance stack-up.
Cheers and thx,
PeteZ
On Thu, Sep 15, 2022 at 4:48 PM JDA <johndavidamos(at)gmail.com (johndavidamos(at)gmail.com)> wrote:
| Quote: | --> Europa-List message posted by: "JDA" <johndavidamos(at)gmail.com (johndavidamos(at)gmail.com)>
Update to my wobbly rear wing pin issue (the metal pin on the wing root behind the main spar)... It was "rocking" slightly within its thread. MOD 52 and MOD 74 had been carried out. I spoke to Andy Draper who deduced that the Loctite had either failed, or insufficient had originally been applied. He said that it was probably not significant structurally but might be a fretting issue. He recommended applying a "wicking" loctite to the thread which should penetrate by capillary action - rig before it sets!
http://forums.matronics.com/viewtopic.php?p=507889#507889
="noreferrer" target="_blank">https://matronics.com/contribution
