		Paul Eckenroth
				 Posted: Mon Sep 19, 2022 12:19 pm    Post subject: AC current reading for Revmaster engine |
				I have described previously the problems with my Revmaster engine and the destruction of it's stator.  As I am slowly reassembling my firewall forward I've incorporated a DC current sensor and various temperature sensors trying to create an early warning system to catch a over temp and over current episode before the stator is again burned up.  It occurred to me that rather than focusing on the DC current I should be monitoring AC before it is modified by the voltage regulator.  My GRT current sensor can be used for AC or DC but the GRT EIS cannot process the AC generated signal. So, my question: can I modify the signal from the sensor so that the EIS can give me a reading. Thanks for your help.
 Paul
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Mon Sep 19, 2022 4:16 pm    Post subject: Re: AC current reading for Revmaster engine |
				Measuring the AC current will only provide an indirect indication of high
 temperature, which can damage the stator windings.  You are better off
 measuring the stator temperature directly using thermocouples or
 thermistors or whatever is compatible with the GRT.  High AC current is not
 necessarily a problem unless it leads to high temperature.
  _________________ Joe Gores |
		N509RV(at)eckenroth.com Guest
				 Posted: Thu Sep 22, 2022 7:16 am    Post subject: AC current reading for Revmaster engine |
				Joe
 The Revmaster engine has a definite problem dealing with heat in the stator and since the heat in the stator is varied by the current generated, I figured that the AC current would be a good thing to monitor to try and anticipate the damaging heat.  Checking the DC current after the voltage regulator would not be as indicative since there would be some loss in the regulator and if the regulator is the shunt type DC current would not represent what the stator is actually producing.  I do have thermocouples in the stator but the GRT EIS cannot read a thermocouple except as an EGT or CHT input. I was hoping that some circuitry existed that would make the AC current readable by a DC meter.
 Paul
 On Mon, Sep 19, 2022 at 8:18 PM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
  	  | Quote: | 	 		  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
  Joe Gores
  http://forums.matronics.com/viewtopic.php?p=507910#507910
  ="noreferrer" target="_blank">https://matronics.com/contribution
		yellowduckduo(at)gmail.co Guest
				 Posted: Thu Sep 22, 2022 8:39 am    Post subject: AC current reading for Revmaster engine |
				I have devised such circuitry for real time vibration monitoring and
 such but it takes a little tinkering.  The signal is 2.5 volts at zero
 current and you use a "perfect" diode to rectify that signal that is
 alternating around the 2.5 level and then add a capacitor and resistor
 to ground to filter it. The tinkering comes from the fact that voltage
 drop through conventional diodes is a deal breaker.  So I use an op amp
 or instrumentation amplifier to essentially be a perfect rectifier.  Add
 a variable resistor to adjust the gain of the circuit for calibration.
 Cost is under $5. You can offset the result by 2.5 volts (with an op
 amp) if you want zero output at zero current but if memory serves I
 think you can adjust the EIS input offset parameter to skip the voltage
 offsetting step.
 However do you really have a shunt type regulator?  I have proven that
 some commonly believed shunt regulators are not shunt regulators just be
 monitoring their temperature.  Does it heat up or cool down with higher
 load is a good enough answer for me. If it is not a shunting unit then
 there is little point in measuring the ac current.  Regardless I agree
 that the temperature of the stator combined with dc output current would
 be enough information to satisfy me.
 I find that the real value of monitoring such data is to record the
 serial output from my GRT EIS4000.  I use an arduino to record to an sd
 card and look at it later but as I recall a laptop also works for short
 term monitoring.
 Ken
 On 22-Sep.-22 11:16 a.m., Paul Eckenroth wrote:
  	  | Quote: | 	 		   Joe
  a DC meter.
  Paul
      of high
      off
      current is not
      Joe Gores
      Electric-List" rel="noreferrer"
      target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
				 Posted: Thu Sep 22, 2022 9:19 am    Post subject: Re: AC current reading for Revmaster engine |
				Ken offers good advice about monitoring the voltage regulator temperature
 to determine if the regulator is the shunt type or not.  If the voltage
 regulator is NOT the shunt type (most likely), then there is no sense in going
 to the trouble of measuring the AC current when monitoring the DC current
 will give the same information.  If the voltage regulator temperature goes up
 with increasing load, then the regulator is NOT the shunt type.  Even if the
 regulator IS the shunt type, then it wouldn't do any good to measure the AC
 current because it would always be at maximum regardless of the DC load
 and you couldn't do anything about it anyway.  So the best thing to do is to
 determine if the voltage regulator is the shunt type, and if it is, then replace
 it with a switching type.
   If you are determined to measure the AC current, then the easiest way is to
 temporarily use a multimeter with a current clamp.  It is possible to design
 and build a circuit to measure the AC current and display it on your GRT.  But
 why do that when it is not necessary?
		dj_theis
				 Posted: Fri Sep 23, 2022 4:43 am    Post subject: Re: AC current reading for Revmaster engine |
				 	  | Quote: | 	 		  |  Checking the DC current after the voltage regulator would not be as indicative since there would be some loss in the regulator and if the regulator is the shunt type DC current would not represent what the stator is actually producing.  |
 I’ve measured and analyzed the Revmaster charge system numerous ways.  The OEM regulator is NOT a shunt regulator.  Trying to measure the AC current will provide absolutely no advantage (unless you are replacing the original regulator with a shunt,…). A shunt regulator will effectively double the heating of the worst case charging (the original regulator is a half wave, not a full wave).  I would strongly advocate using the original equipment regulator. And definitely not installing a shunt regulator.
 This charge system has (at least) 4 flaws.  1) low air flow/cooling. 2) erroneous stator design with magnetically saturated laminates.  3) no resin coating infusion on the windings 4) low air flow/cooling.
 I injected DC current from a lab supply through the stator winding on the bench and measured the rise in temperature of the surface of the stator wire and the center laminate steel.  I’ve concluded that continuous DC at 15 amps with an ambient temperature of 100 F will not create a temperature rise that is damaging (steady state of below 140 F).  I can forward the temperature curves if anyone is interested.
 Increasing air flow is job 1, wrt cooling this stator.  Impregnating the wiring is an improvement that I advocate but do not have data on it.  My direct conversation with the stator wire manufacturer, and their recommendation suggests to me it would be an improvement.   I can share the method of impregnating the stator wiring that I’m using with the “web”, but I’m reluctant to advertise this until I can verify there is no damage to the ignition coils.  I’ve tested impregnation on the stator coils but the locally mounted ignition coil wire is different (much smaller and from an unknown supplier).
 Hope this helps,
 Dan
  _________________ Dan Theis
Scratch building Sonex #1362
Revmaster Alternator problem solved. |
				 Posted: Sun Sep 25, 2022 5:23 am    Post subject: AC current reading for Revmaster engine |
				Thanks to Joe, Ken, and Dan for your comments.  I will be monitoring the temps of the stator coils and the voltage regulator.  The voltage regulator I will use will be the "John Deere type which I've been told is the switching type.  I have been told by Revmaster that their regulator is the shunt type.  Unfortunately there seems to be no way of knowing for sure beforehand what type of regulator a specific unit is.  That information is not included in any descriptions.  I have enlarged the ventilation areas in the case and will direct blast air directly to the stator.  I'll return the plane to service soon and see what happens.  This is hardly the ideal situation when completing an airplane.  Thanks again.
 Paul
 On Fri, Sep 23, 2022 at 8:45 AM dj_theis <djtheis58(at)gmail.com (djtheis58(at)gmail.com)> wrote:
  	  | Quote: | 	 		  --> AeroElectric-List message posted by: "dj_theis" <djtheis58(at)gmail.com (djtheis58(at)gmail.com)>
  Hope this helps,
  Dan
  Dan Theis
  Still working on the Revmaster Alternator improvement
  http://forums.matronics.com/viewtopic.php?p=507925#507925
