Regulator location
dj_theis
PostPosted: Fri Sep 23, 2022 5:37 am    Post subject: Regulator location Reply with quote
I’ve been trading emails with another builder and they asked my thoughts on the location of the ship’s voltage regulator. “What are the pros and cons to mounting the regulator on the occupant side of the firewall.”
My thoughts are below but I think this is a question better served by this forum than my opinion.
Pros:
Likely cooler environment (although you might not appreciate the added heat in the summer).
Cons:
Harder to find blast air for cooling
The high voltage AC wires are routed through a longer path (65 VAC open circuit)
I’ve never seen this done on certified aircraft or land vehicles. (Maybe not a good reason but something to consider)
If they do go up in smoke you will be breathing that smoke.
Can the forum comment additionally?
Dan
Dan Theis
Scratch building Sonex #1362
Revmaster Alternator problem solved.
art(at)zemon.name
PostPosted: Fri Sep 23, 2022 6:00 am    Post subject: Regulator location Reply with quote
Dan,
I installed B&C Aero regulators. The installation instructions specifically state that they are to be installed on the cockpit side of the firewall, not in the engine compartment.
    -- Art Z.
On Fri, Sep 23, 2022 at 8:49 AM dj_theis <djtheis58(at)gmail.com (djtheis58(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "dj_theis" <djtheis58(at)gmail.com (djtheis58(at)gmail.com)>
Pros:
Cons:
Dan
My blog: CheerfulCurmudgeon.com
“We are all visitors to this time, this place. Our purpose here is to observe, to learn, to grow, to love ... and then we return home.” -- Queen Elizabeth II
PostPosted: Sat Sep 24, 2022 7:11 am    Post subject: Regulator location Reply with quote
Cons:
I've never seen this done on certified aircraft or land vehicles.
Actually, regulators for the B36 and B55
airplanes are behind co-pilot side of
instrument panel.
I recalled having a photo of that installation.
Dug around in the 'archives'. Found a 640x480
image captured by the very first digital camera
I owned . . . paid about $600 for it as I
recall. It would shoot about 20 images onto
a 3-1/2" floppy. Anyhow, found the picture.
The lighting was too poor to produce a useful
image. Image sensors have come a long way
baby!
Don't think there was a driving concern
for regulator location other than cost
of ownership. Under the hood was the
obvious for optimal expense and ease
of maintenance. Of course, regulators
nowadays are built right into the alternators.
Rectifier/regulators are a special breed
given their internally generated heat.
So lacking environmental DATA (numbers)
for a proposed location, one might want
to err on the side of caution.
out of that stuff?"
