Stall in a side slip
Goto page Previous  1, 2
Float Flyr
PostPosted: Sat Jul 29, 2006 5:45 am    Post subject: Stall in a side slip Reply with quote
Spins shouldn't be a problem especially if you have altitude on your side.
Just remember to correct with rudder NOT AILERON. At least you have
experienced a spin... A lot of trainers today don't even let a student
experience a spin because it isn't in the flight test. As if the guys who
wrote the flight test considered the repercussions of removing the spin form
the test.
My first spin was totally thrilling!! When the screen filled with ground
spinning at a fibulas rate of knots... Wow! I wouldn't have been able to
correct it on the first occurrence. I would have been to busy with bodily
fluids to do much of anything.
Now because of the spin training that I had if I did an accidental spin
today I would just be upset with myself at letting it happen. As I said
altitude is your friend if you have enough altitude on approach then you can
sort things out for a nice landing.... But.... You always have to be ready
for ground squalls and wind shears etc.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sat Jul 29, 2006 5:53 am    Post subject: Stall in a side slip Reply with quote
I haven't seen an engine yet that can't quit unexpectedly. Four stroke, two
stroke or turbine. Take a queue from the Boy Scouts...."Be Prepared"!!
I read a good one some time back about a fellow who was told to take a 360
while a B52 was doing a precautionary landing with an engine out.
His answer to the tower was he would do the 360 because there is nothing
quite like the dreaded seven engine landing /;^}
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Michel
PostPosted: Sat Jul 29, 2006 12:52 pm    Post subject: Stall in a side slip Reply with quote
On Jul 29, 2006, at 3:15 PM, Colin Durey wrote:
Most gliders have "dive brakes" or "speed brakes" (spoilers)
Indeed, Colin. But since I don't have speed brakes on my Kitfox, I use
sideslipping.
incidentally when my son took his Utralight license, last year on my
Kitfox, after he flew his first solo, I asked him how it was, having
still in mind my own terrific experience. "Ok," he answered.
- "What? Just ok?"
- "Yes, it was much more exiting when I flew solo in a glider (as you
say yourself, Colin) 15 years ago, knowing I had only one chance to
land the bird."
My son had about 50 hours on the club's Blanik and I was a few time up
with him, as my only glider experience.
When I started with the Kitfox, three years ago, I became interested by
a fact: In Norway, your normal insurance doesn't cover you for sports
like diving, parachuting, mountains climbing and ... ultralight flying.
But it does for glider flying, which is considered as safe as ...
sitting in your garden or shopping. So, it became clear to me that if I
wanted to fly safe, I had to fly ... like a glider pilot, always be
ready to be in gliding distance to a safe landing.
By all means, after some qualified training, continue to do engine
failure, stall, spin, and side-slip practice, but do it up high where
you've got time to recover, and plan every approach early and well.
Well, stalls and spins are not necessary for safe flying, Colin. But,
IMHO, to be able to do precision landing with no engine, is safety
training. If I, or my son, ever loose engine power, I want us to do the
right thing without hesitation. As opposed to sailing, in aviation any
fraction of a second can make the difference between life and death.
But as for sailing, I know I need to have a plan. And when I fly, I try
to note any place I could land on because I think that, if the engine
starts to go wrong, it is better to land safely on something that is
right under me, than to try to make it to an airfield that may be
beyond a forest, a mountain, a stretch of water. The action then is to
eyeball that emergency field, and fly the plane for a safe landing, as
trained for, almost as a reflex. Wouldn't you agree?
Michel
Kitfox 3 - Jabiru 2200
Guy Buchanan
PostPosted: Sat Jul 29, 2006 12:58 pm    Post subject: Stall in a side slip Reply with quote
At 12:51 AM 7/29/2006, you wrote:
But, has any of you stalled voluntary, at high altitude, in a forward
slip? I could try myself but I'd rather ask the list first because ...
I don't want to end in a spin!
It doesn't matter what you call it, stalling cross controlled results in
the trailing wing stalled, and the leading wing not. (It's actually worse
than what we do for a normal spin entry, because the trailing wing aileron
is down, which increases that wing's angle of attack.) This can result in a
variety of things, depending on subsequent control input, but typically
results in a spin. (Steady state control input.) Yes, if you get too slow
during your slip to final you will spin, with predictable results.
There is no reason, however, that you should get slow during a slip.
Remember that drag varies with the square of the velocity. If you want to
bleed LOTS of energy, get draggy and go FAST. (Meaning: point it down with
the power off.) Though I'm sure it's possible to slip all the way to the
ground, with a dramatic flare at the end, you will, by definition, have to
carry more speed into that flare than if you stabilized at just above stall
on your approach. (Slipping stall speed is higher.) The higher speed will
make your subsequent float and ground roll longer. Ideally the slip is only
used to lower the aircraft to the intended glide slope. I have, like you,
done weak slips all the way to the ground, thereby increasing the angle of
the glide slope, but the preferred method for increasing the angle of glide
slope is to go slower. I've done it by slip when there were people behind
me who wouldn't appreciate my 50 knot approach speed. Usually I slip hard
until I get to the proper glide slope, then straighten and continue a
conventional stabilized approach.
The big question with short field operations is what gust factor you use.
It's possible to land a Cessna 152 at about 45 knots, however, if the wind
velocity decreases by five knots as you enter your flare, guess what? You
just stalled. It makes for one hell of a short roll-out, but you have to
leave the field by truck! Our Kitfox's are the same. I suppose you could
make an approach at 45 MIAS, and drop like the proverbial rock, but it's
just too easy to have a 5 knot wind variation on the deck ruin your whole
day. I suppose it depends on how desperate you are. I'm guessing it's
better to land at 55 MIAS and hit the trees at 25 than stall on approach at 45.
Do yourself a favor Michel. Go find an aerobatic aircraft and instructor.
I'm not implying you need the education! Do it because it's one hell of a
lot of fun, teaches you how to really control your aircraft, and answers
all these questions. In a Decathlon you can do practically anything, get
wildly out of shape, then recover and fly away casually. It's a great
feeling. Budget about 10 hours.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Michel
PostPosted: Sat Jul 29, 2006 1:45 pm    Post subject: Stall in a side slip Reply with quote
On Jul 29, 2006, at 10:52 PM, Guy Buchanan wrote:
It's actually worse than what we do for a normal spin entry, because
the trailing wing aileron is down, which increases that wing's angle
of attack.
Hang on because I am not following, Guy.
When I do a side slip on final (with engine on or not) I always do it
with left stick and right rudder so that, from the left-hand seat, I
get a better view of the runway. My right wing is high, my left is low.
Which is the trailing one? The right wing?
I think I read (as I write in my previous email) that a stall and slip
was less dangerous than a stall and skid. Do you mean it is the
opposite?
Of course, when I side slip, it is well above stall speed, adjusting
for turbulence. It usually happens like this: I am on final, feel how I
will land if I keep the attitude and speed, then I may feel I need to
sink faster to land on the mark. If I put the nose down, I'll increase
speed and will float far down the runway, so I put the nose down but
reduce the speed increase by side slipping. I would always get the ball
in the center before I need to lift the nose again. But I'd like to
know how dangerous it is.
instructor.
I intent to, Guy. I even know the pilot and the Bellanca plane that can
do that. But ... I am a husband, a father, a grand-father, an employee
and ... time, you know! Plus that the pilot is mostly at a nearby
airfield and only visits us occasionally.
Michel
mike
PostPosted: Sat Jul 29, 2006 4:40 pm    Post subject: Re: Stall in a side slip Reply with quote
When I do a forward slip, I reduce to the proper airspeed, generally 60 then I'll slip twards the cross wind if there is one, if not, always a right rudder slip. Now, I have slipped all the way down to 5 ft off the runway, in fact, when I did my check ride a few years ago, the examiner told me to demonstrate a slip to land, I slipped and cut out at 20ft from the runway, he said, I told you to slip to landing, so we did it again, this time I waited until about 5 ft. off the ground, recovered and flaired to land at the same time, his response, good one. I think it's very important to slip into the wind, think about it, we do the same cross control for cross wind correction, if you always slip with left wing down and you have the cross coming from the right, I feel this can bring desaster.
Guy Buchanan
PostPosted: Sun Jul 30, 2006 7:17 am    Post subject: Stall in a side slip Reply with quote
Yes.
opposite?
The reason a skid is worse IN A TURN is because in a stabilized turn the
inside wing is slower than the outside wing. Thus the inside wing ALWAYS
has a higher angle of attack than the outside. Now it gets a little
complex. When you skid or slip an aircraft with dihedral, the leading
wing's angle of attack increases, and the following wing's angle of attack
decreases, all along the length of the dihedral. (This is why you can turn
with rudder only.) In a skid, with rudder into the turn, the outside wing's
angle of attack increases. To prevent roll to the inside you apply outside,
(cross-controlled,) aileron. In a typical aircraft with a short, attached,
aileron out near the wing tip, this means the angle of attack over the
inside aileron is higher than that just inboard of the aileron and MUCH
higher than that of the opposite wing. Therefore the flow over the inside
aileron stalls first, resulting in a terrific rolling moment to the inside.
If the skid is extreme enough to actually blanket some of the inside wing
then the cross-control must be increased to offset the reduction in
effective area. The situation is reversed in a slip. With outside rudder
you lift the outside wing with aileron, increasing the local angle of
attack, but the outside wing has a lower angle of attack to begin with
because it's going faster. Therefore the slip can be considered "safer"
than the skid. (Note, however, you CAN spin out of a slipped turn, it just
takes a little more work. You flip over the top rather than dropping to the
inside giving you a little more time, as I think Dave already mentioned.)
With our flaperons I'm not sure we run the risks that normal ailerons do,
since our flaperons are really fully flying "wings". I don't know whether
we roll because we change the angle of attack of the wing, or if we roll
because our "little wings" push the "big wings" around. If the latter, we
may be much less sensitive to slip / skid spins. (Unless the flaperon stalls.)
The other way a slip or skid can ruin your day is more dynamic. If you
begin a sharp turn with your wings very close to the critical angle of
attack and then kick in an abrupt dose of inside rudder to tighten the turn
the inside wing slows dramatically, increasing its angle of attack. As it
begins to drop due to the resulting decrease in lift, (remember lift is
proportional to the velocity squared,) the angle of attack increases still
more resulting in a stall of that wing. (If it hasn't stalled already.) You
snap into a spin even before you've had time to react with any
cross-control aileron. (Of course, any aileron you might apply merely
exacerbates the problem.) I think gliders are particularly prone to this
type of skid-spin because of their long spans.
Clear as mud?
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
morid(at)northland.lib.mi
PostPosted: Sun Jul 30, 2006 11:39 am    Post subject: Stall in a side slip Reply with quote
Great explanation Guy. Thanks!
Deke
MichaelGibbs(at)cox.net
PostPosted: Sun Jul 30, 2006 12:55 pm    Post subject: Stall in a side slip Reply with quote
Michel sez:
slip was less dangerous than a stall and skid. Do you mean it is the
opposite?
Michel, my friend, do not kid yourself. Any time the rudder and
ailerons are badly uncoordinated and the aircraft stalls you are
setting yourself up for a spin. There is no such thing as a "less
dangerous" spin or a "less dangerous" way to impact the ground with
the aircraft essentially out of control. When the airplane stalls,
that powerful Kitfox rudder will be doing it's job out there and the
plane will roll to the side the rudder is on.
The weekend before my accident I was up practicing stalls and spins.
My Model IV was a very docile spinner--it would usually just fly out
of the spin in less than one turn unless I aggressively held the
stick full back and the rudder full into the spin. Even then I could
not get a full turn to the left under any conditions.
Spins are not something to fear, they are something to be well
understood and, in my opinion, practiced and perfected. I believe
that had I not been sharp on stall/spin recovery at the time of my
accident, things would have been much worse. By the time the
airplane hit the ground, we were recovered from the stall and
climbing out again (too bad the terrain was climbing even faster!).
I never use flaps on landing! It is, IMHO useless. I only use flaps
to get fast out of a long, wet grass short field and that's all.
I don't know how the Model III compares with the Model IV, but my IV
was a wonderful performer with the flaps down. A half-flap takeoff
gave me the shortest ground rolls and the steepest climb-outs for
those short field situations, while full flaps on landing provided an
extra measure of drag and very low touch-down speeds. With full
flaps and a little effort, I could touch down before the numbers and
turn off into the run-up area on the local field's short runway!
Of course, my 'fox had a nose wheel and the flaperons were rigged for
22 degrees of full deflection. Your mileage will vary, of course.
About spins, I have done two, with my instructor, enough for me to
understand that it is forbidden and that I will probably never be
able to recover from one.
I'm sure that's not true, Michel. Others may disagree but I find
spin recovery easier than planting a perfect 3 point landing in a
tail dragger. Many light airplanes, such as the Cessna 152, will
simply fly out of a spin if you let go of the controls (this leaves
you in a descending spiral that will still require some pilot action
to return to straight and level flight). My Model IV was like
that--let go of the controls and she would just start flying again.
As for slips, I've seen a lot of interesting theories advanced on the
list this last week. Not that the difference matters much, but a
side slip is what you do to maintain your ground track when a wind is
trying to push you left or right of the runway. A forward slip is
what you do when you are high on final approach and need to get down
faster. You aren't slipping to one side of your ground track, you
are slipping forward along it. What would you call a day when both
happen? I have no idea.
Just my two cents worth.
Mike G.
N728KF
janderson412(at)hotmail.c
PostPosted: Sun Jul 30, 2006 1:58 pm    Post subject: Stall in a side slip Reply with quote
Out of interest Mike, would you be will to share the details of your accident, for learning purposes. John A.
Reply-To:��kitfox-list(at)matronics.com
Subject:��Re: Stall in a side slip
Date:��Sun, 30 Jul 2006 13:52:48 -0700
--> Kitfox-List message posted by: Michael Gibbs <MichaelGibbs(at)cox.net>
Michel sez:
opposite?
Michel, my friend, do not kid yourself.��Any time the rudder and ailerons are badly uncoordinated and the aircraft stalls you are setting yourself up for a spin.��There is no such thing as a "less dangerous" spin or a "less dangerous" way to impact the ground with the aircraft essentially out of control.��When the airplane stalls, that powerful Kitfox rudder will be doing it's job out there and the plane will roll to the side the rudder is on.
The weekend before my accident I was up practicing stalls and spins. My Model IV was a very docile spinner--it would usually just fly out of the spin in less than one turn unless I aggressively held the stick full back and the rudder full into the spin.��Even then I could not get a full turn to the left under any conditions.
Spins are not something to fear, they are something to be well understood and, in my opinion, practiced and perfected.��I believe that had I not been sharp on stall/spin recovery at the time of my accident, things would have been much worse.��By the time the airplane hit the ground, we were recovered from the stall and climbing out again (too bad the terrain was climbing even faster!).
I don't know how the Model III compares with the Model IV, but my IV was a wonderful performer with the flaps down.��A half-flap takeoff gave me the shortest ground rolls and the steepest climb-outs for those short field situations, while full flaps on landing provided an extra measure of drag and very low touch-down speeds.��With full flaps and a little effort, I could touch down before the numbers and turn off into the run-up area on the local field's short runway!
Of course, my 'fox had a nose wheel and the flaperons were rigged for 22 degrees of full deflection.��Your mileage will vary, of course.
I'm sure that's not true, Michel.��Others may disagree but I find spin recovery easier than planting a perfect 3 point landing in a tail dragger.��Many light airplanes, such as the Cessna 152, will simply fly out of a spin if you let go of the controls (this leaves you in a descending spiral that will still require some pilot action to return to straight and level flight).��My Model IV was like that--let go of the controls and she would just start flying again.
As for slips, I've seen a lot of interesting theories advanced on the list this last week.��Not that the difference matters much, but a side slip is what you do to maintain your ground track when a wind is trying to push you left or right of
colind
PostPosted: Sun Jul 30, 2006 6:14 pm    Post subject: Stall in a side slip Reply with quote
Micahel,
I did most of my early gliding training in a Blanik, over South-East
Queensland (Australia). Its a great aircraft to learn in as it is very
forgiving to novice pilots. All the same, 80 - 90kts cross-country without
an engine is not bad, eh? I still remember the puzzled radio call from a
152 pilot after we passed him at 9000ft one day. One memorable glider we
flew(?) was the Kookaburra. It was wood and fabric construction and it had
an open cockpit... you really knew you were flying. Unfortunately, it had
a glide angle only slightly better than a streamlined brick, so flights
tended to be fairly short. We could get 1200-1500 ft off the end of the
wire in it, but the nearest regular source of lift was about 1 mile from
the end of the strip so, on marginal days, you had to be good to get there
with enough height so that if you couldn't "get away", you could get back
to the strip with a comfortable margin.
I have only one problem with what you said in your reply, namely:
"Well, stalls and spins are not necessary for safe flying, Colin. But,
training."
The second part - yes... the first part, absolutely NO!
A key principle of pilot training, in this part of the world at least, is
that pilots need to be proficient in all aspects of flight control, and
competent in recognising and responding to anything which might cause a
danger to the continued safe operation of the aircraft. Your second remark
aligns with that concept. Up until 1985, Abinitio pilot training here
included incipient stalls, full stalls, incipient spins and full spins.
After that time, for a few years, full stalls and spins were not part of
training. As a result, there was a whole bracket of pilots who had not
experienced a fully developed stall or spin, and thus had no experience in
recovering from them. I recall flying with a young lady who had recently
obtained her PPL. We flew to the training area near Brisbane and I asked
her to do a stall. When she got to the point of the pre-stall buffeting,
she lowered the nose and applied power. After a sarcastic remark from me,
I asked her to do another stall... same procedure. I then proceeded to put
the aircraft into a full stall and told her to do the recovery. She
couldn't. Despite her ashen face, we went on to spins. Same thing with the
spin. Interestingly, on approach back into Archerfield, she came in high
(probably a little shaken from what had happened), and proceeded to do a
perfectly good side-slip to lose height.
After about 5 or 6 years, full stalls and spins were re-included in pilot
training. While I don't have any official data to refer to, the anecdotal
evidence is that the number of un-intended stall/spin incidents increased
significantly during that period, and persisted for a while thereafter.
The problem was that, these pilots never really understood what a fully
developed stall or spin was like, and did not go through the actual entry
sequence and process of recover and thus have true experience. While an
explanation of the process, "complete with pictures", was provided, the
truth really is that "Showing is better than telling".
Close to ground manouvers, ie: landing and take-off, are when un-intended
stall/spin incidents are most likely to occur, and usually have the most
dramatic (tragic) outcomes. Slipping (forward, inward, outward, or
whichever way) on approach is a flight condition which puts you close to
the edge of the safe flight envelope. Practical experience in how the
aircraft feels, responds, and is tending to act, is vital for a pilot to
be able to manage the continued safe operation of the aircraft.
Especially, to be able to predict, and respond quickly and correctly to
what happens, or, is about to happen.
Practicing, on a regular basis, engine failure (on t/o and landing), steep
decents, stalls, spins, and side/forward slips, etc, etc, are all, I
believe, vital for for every pilot. After all, "Practice makes perfect"
(well, nearly). Just do the practice in a way (ie: in a location and at an
altitude) that is least likely to cause a major problem if things don't go
the way you planned. Practice engine outs and side-slips in the circuit
every once in a while. However, don't make it a habit to use side-slips as
a standard approach procedure, nor make high approaches standard, which
will set you up to do side-slips.
I hope I haven't rambled on too much for you, its just that this is a
subject particularly close to me. I really envy the great scenery you fly
over Michael, and have enjoyed looking at the photos you have posted. I
hope to have my 'Fox in the air in the next couple of months, so will be
able to send you some of the area around here. I would love to come and
visit one day.
Colin Durey
Sydney - Australia
+61-418-677073 (M)
+61-2-945466162 (F)
sideslipping.
- "What? Just ok?"
land the bird."
Michel
Colin Durey
Sydney
+61-418-677073
Graeme Toft
PostPosted: Sun Jul 30, 2006 7:03 pm    Post subject: Stall in a side slip Reply with quote
There good points you make Colin and unfortunately for today's pilots coming
through the RAAust, those skills of recovery from unusual attitudes will
most likely never be learnt. Its unfortunate that other than stalls, the
basic spins, stall turns, wing overs etc are illegal in our aircraft. We all
know that structurally most will take them in their stride but for a person
to hold a pilots license and yet never experience those basic manuovourses
is a real shame. As you rightly pointed out, how many of the pilots who lost
there lives in the mid 80's would be alive today if these basics skills had
be taught to them. A sedate stall can very quickly turn into something we
generally try to avoid and it is inexcusable for people to be unprepared for
such an event.
Graeme ---
msm_9949(at)yahoo.com
PostPosted: Mon Jul 31, 2006 8:50 am    Post subject: Stall in a side slip Reply with quote
So clear I've�developed a headache. Wink
Guy Buchanan <bnn(at)nethere.com> wrote:
[quote]--> Kitfox-List message posted by: Guy Buchanan
Yes.
opposite?
Clear as mud?
Guy Buchanan
Page 2 of 2
