Nylon #2 Phillips Screw Driver Bits...?
Site Admin
PostPosted: Tue Jan 03, 2023 4:09 pm    Post subject: Nylon #2 Phillips Screw Driver Bits...? Reply with quote
Hi Fellow RV Builders,
After 12 years since the test-flight, I finally got my RV-8 painted! Cascade Customs and Design in Bend Oregon did an outrageously awesome job! She is a beaut!
I had them put all new cad-plated screw hardware back in after painting. I decided that gold hardware against the red, just didn’t look as finished as I’d hoped. So, I counted all the screws and had them paint the appropriate number of screws plus some spares with the intent of swapping all the unpainted with painted.
The problem is the standard steel Phillips screw driver bits seems to chip the paint in the screw pretty easily.
I thought that I’ve seen #2 Phillips NYLON screw driver tips somewhere a while back? But I can’t seem to find them now? Does anyone have a lead on Nylon #2 bits?
RV-8 N998RV “Ruby Vixen”
https://youtu.be/57ihMKzMojE
 Filesize:  52.15 KB
 Viewed:  21164 Time(s)
 Filesize:  24.99 KB
chaskuss(at)yahoo.com
PostPosted: Tue Jan 03, 2023 4:26 pm    Post subject: Nylon #2 Phillips Screw Driver Bits...? Reply with quote
Matt,
Nylon won't be strong enough to turn those screws in nut plates. You might want to consider replacing the A/C Phillips head screws with Torx head screws [SS or Cad] from a supplier like MSC Direct or McMaster-Carr
On Tuesday, January 3, 2023, 07:15:17 PM EST, Matt Dralle <dralle(at)matronics.com> wrote:
[img]cid:uERRhBOBbyp956bwAa5E[/img]
[img]cid:j8woHe86sypbvIekbprD[/img]
 Filesize:  52.15 KB
 Viewed:  21161 Time(s)
 Filesize:  24.99 KB
eduardocrestahill(at)hotm
PostPosted: Tue Jan 03, 2023 5:00 pm    Post subject: Nylon #2 Phillips Screw Driver Bits...? Reply with quote
Perhaps a plastic screwdriver toy (Amazon)
De: owner-rv8-list-server(at)matronics.com <owner-rv8-list-server(at)matronics.com> en nombre de Matt Dralle <dralle(at)matronics.com>
Enviado: martes, 3 de enero de 2023 21:08
Para: rv-list(at)matronics.com <rv-list(at)matronics.com>; rv8-list(at)matronics.com <rv8-list(at)matronics.com>; rv7-list(at)matronics.com <rv7-list(at)matronics.com>
Asunto: Nylon #2 Phillips Screw Driver Bits...?
I had them put all new cad-plated screw hardware back in after painting. I decided that gold hardware against the red, just didnt look as finished as Id hoped. So, I counted all the screws and had them paint the appropriate number of screws plus some spares with the intent of swapping all the unpainted with painted.
I thought that Ive seen #2 Phillips NYLON screw driver tips somewhere a while back? But I cant seem to find them now? Does anyone have a lead on Nylon #2 bits?
RV-8 N998RV Ruby Vixen
 Filesize:  52.15 KB
 Filesize:  24.99 KB
vshimsl(at)live.com
PostPosted: Fri Jan 06, 2023 2:21 pm    Post subject: Nylon #2 Phillips Screw Driver Bits...? Reply with quote
Just cover the screws with round circles of vinyl wrap (use big hole paper punch) after inserted and torqued down. With a hair dryer, the vinyl will shrink wrap into screw and be indistinguishable from paint. And when you need to remove them, the vinyl will (should) peel out easily. Or be bold. Polish, dip heads in polyurethane (very optional) and call it a design element. Nylon screws will just break off where you can't get at them.
RV8-N8432
From: owner-rv8-list-server(at)matronics.com <owner-rv8-list-server(at)matronics.com> on behalf of Charles Kuss <chaskuss(at)yahoo.com>
Sent: Tuesday, January 3, 2023 4:26 PM
To: rv8-list(at)matronics.com <rv8-list(at)matronics.com>
Subject: Re: Nylon #2 Phillips Screw Driver Bits...?
Matt,
 Filesize:  52.15 KB
 Viewed:  21148 Time(s)
 Filesize:  24.99 KB
