Mod help please
daaza22
PostPosted: Wed Jan 18, 2023 4:01 am    Post subject: Mod help please Reply with quote
Hi Everybody
We are at the stage of the build where we are getting the paperwork in order .
But I am struggling to find any info on Mods 13,17,25,28,37,and 39 .
My Europa is a Classic (kit 47) Mono .I am a member of the club and registerted with the Europa and cannot find any info.
So if anyone can help with info that would be great .
Cheers Darren
spcialeffects
PostPosted: Wed Jan 18, 2023 6:23 am    Post subject: Re: Mod help please Reply with quote
Hi Darren
Click the link below and that shows the last 3 mods you want.
https://www.theeuropaclub.org/building/europa-mods-and-sbs/europa-mods
I have print outs from the club site from about 10 years ago which has all the obsolete mods applicable to the early classics. If you email me at spcialeffects(at)aol.com I can send you photos of them
Frank X, G-STUE
Burrilla
PostPosted: Wed Jan 18, 2023 6:58 am    Post subject: Mod help please Reply with quote
This is what I have on file that may help. I’ve also copied them to Bob Hitchcock for possible inclusion on the Europa Club website.
Alan Burrill
On 18 Jan 2023, at 12:01, daaza22 <royledarren(at)gmail.com> wrote:
Hi Everybody
Cheers Darren
http://forums.matronics.com/viewtopic.php?p=509963#509963
Mod_39.pdf
 Filename:  Mod_39.pdf
 Filesize:  15.42 KB
 Downloaded:  518 Time(s)
Factory_Mods.PDF
 Filename:  Factory_Mods.PDF
 Filesize:  108.58 KB
 Downloaded:  544 Time(s)
Early_Mods.doc
 Filename:  Early_Mods.doc
 Filesize:  54 KB
 Downloaded:  579 Time(s)
Mod_28.pdf
 Filename:  Mod_28.pdf
 Filesize:  28.75 KB
 Downloaded:  550 Time(s)
Mod_37.pdf
 Filename:  Mod_37.pdf
 Filesize:  60.27 KB
daaza22
PostPosted: Wed Jan 18, 2023 7:29 am    Post subject: Re: Mod help please Reply with quote
Alan Burrill
On 18 Jan 2023, at 12:01, daaza22 <royledarren> wrote:
Hi Everybody
Cheers Darren
thanks very much these are such a big help
cheers Darren
daaza22
PostPosted: Wed Jan 18, 2023 7:32 am    Post subject: Re: Mod help please Reply with quote
thanks very much Burrilla this helps alot
cheers Darren
Hitchflight
PostPosted: Wed Jan 18, 2023 7:53 am    Post subject: Re: Mod help please Reply with quote
Hi Alan, Darren & Frank
Thanks for this.
The Mods chapter on the website is really controlled by our Mods Specialist; Clive Sutton. I assist clerically with approved uplifts to our website. I can see we’ve removed certain Mods from the website many years ago and marked them obsolete for some reason. Noting this was before Clive’s tenure. Always good to hear of errors or omissions.
Happy you have resolved.
Thanks Alan for the attachments.
I’ll check with Clive ( clivesutton(at)theeuropaclub.org ) to see if they should go back on or be supplied individually with a narrative.
Trust that makes sense.
daaza22
PostPosted: Wed Jan 18, 2023 8:22 am    Post subject: Re: Mod help please Reply with quote
thanks to the help so far ,I now only need help with Mod 17 and 25.
cheers
JonathanMilbank
PostPosted: Wed Jan 18, 2023 12:21 pm    Post subject: Re: Mod help please Reply with quote
Mods 17 and 25 attached.
 Filesize:  192.82 KB
 Viewed:  8961 Time(s)
 Filesize:  346.52 KB
 Filesize:  302.39 KB
daaza22
PostPosted: Wed Jan 18, 2023 1:02 pm    Post subject: Re: Mod help please Reply with quote
thanks Jonathan thats what I needed ..
What a great response from the Europa group .
Cheers Darren
JonathanMilbank
PostPosted: Wed Jan 18, 2023 1:55 pm    Post subject: Re: Mod help please Reply with quote
The rubbing block ends should be well chamfered, to prevent the cables from snagging beyond the ends of the blocks. This can easily happen when the cables occasionally go slack; most likely on the ground.
daaza22
PostPosted: Wed Jan 18, 2023 2:02 pm    Post subject: Re: Mod help please Reply with quote
good advise ..cheers
