JDA
Posted: Sun Jan 22, 2023 6:19 am Post subject: Flap rigging adjustment |
Hello. I suspect my flaps (mono) are slightly miss-rigged in the flaps up position. When flying in the cruise I need just a tad of right stick. When I did a flap and undercarriage retraction in the hangar this morning the right flap looked slightly lower by eyeball… which might explain the need for right roll input. I will check properly with an inclinometer, but is this something that can be easily adjusted? Many thanks.
peterz(at)zutrasoft.com Guest
Posted: Sun Jan 22, 2023 6:42 am Post subject: Flap rigging adjustment |
When flying solo? That would be normal. The passenger balances out a properly rigged plane fwiw.
Cheers,
PeteZ
| Quote: | On Jan 22, 2023, at 9:26 AM, JDA <johndavidamos(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=510000#510000
Duncan McFadyean
Posted: Sun Jan 22, 2023 6:52 am Post subject: Flap rigging adjustment |
The asymmetry of the flap operating (cross) tube means that the flaps will be asymmetrical. Unless they are configured to come up hard against some flap stops (in which case a degree or so of range is then sacrificed).
Duncan McF.
Cheers,
PeteZ
