		jcohen@post.com
				 Posted: Fri Feb 10, 2023 2:10 pm    Post subject: Building fusible links for FAT wires |
				In order to reduce the number of studs with nuts that could loosen in my Z101, I decided to use Fusible links 12AWG and 14AWG for my Pri and Aux Alternator Fault wires, 8AWG and 10AWG respectively. The AeroElectric Connection Article "How to Build Fusible Links" states this is for 22AWG and 24 AWG Fuse links only.
 So my question is, what is different in constructing larger FAT wire fusible links? And where can I purchase short lengths of Silicone covered Fiberglass Sleeving? It seems that is not sold by Spruce or B&C....
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Jeff |
		Eric Page
				 Posted: Fri Feb 10, 2023 2:22 pm    Post subject: Re: Building fusible links for FAT wires |
				Search eBay for "silicone fiberglass sleeve". It's similar to fire sleeve, but available in thin-wall versions and small diameters.
		Ceengland
				 Posted: Fri Feb 10, 2023 2:28 pm    Post subject: Building fusible links for FAT wires |
				On 2/10/2023 4:10 PM, jcohen(at)post.com wrote:
  Jeff
 Primary difference is the energy (heat) released if they 'blow'. This
 makes containing the event a lot harder with big links. The ideal
 solution is to just use off-the-shelf fusible link wire to make the
 links. Amazon has vendors with a good selection.
 https://smile.amazon.com/s?k=fusible+link+wire&crid=2RG3WCVSNEZWS&sprefix=fusible+link+wire%2Caps%2C219&ref=nb_sb_noss_1
 You can solder and heatshrink, or just use quality crimp terminals to
 join the link to the regular wire.
 www.avast.com
  _________________ Charlie |
		johnbright
  Joined: 14 Dec 2011 Posts: 166 Location: Newport News, VA
				 Posted: Fri Feb 10, 2023 2:39 pm    Post subject: Re: Building fusible links for FAT wires |
				FLW 6" long and 4 awg smaller than the B lead, PICO brand is common; available from 10 to 20 awg.
 Is the main alternator 60A... if so I would go with 6 awg B lead.
  _________________ John Bright, RV-6A, at FWF, O-360
Z-101 single batt dual alt SDS EM-5-F.
john_s_bright@yahoo.com, Newport News, Va
N1921R links |
		jcohen@post.com
				 Posted: Fri Feb 17, 2023 11:48 am    Post subject: Re: Building fusible links for FAT wires |
				Now that I am having fun building fusible links for my Pri and Aux Alternator wires, I am using off the shelf Pico fusible link wire (12AWG and 14AWG) to build my FAT wire  links, should I still cover the wire with Fiberglass Sleeving? How does the off-the shelf FAT wire fusible link normally respond when it operates/ burns?  If the link can flame and is not covered by fiberglass sleeve, shouldn't the physical routing be considered, like not routing near/below the battery or other components?
 My thought is, if one event causes the fusible link to operate ( burn), couldn't a flame from a FAT wire take out a nearby critical component (like the Master in Z101) and cause a second failure?
		Ceengland
				 Posted: Fri Feb 17, 2023 1:41 pm    Post subject: Building fusible links for FAT wires |
				On 2/17/2023 1:49 PM, jcohen(at)post.com wrote:
  Jeff
 Hi Jeff,
 If you're buying purpose-built fuse-link wire, the insulation should be
 designed to contain the 'event'. Look at the difference in both material
 and thickness of the insulation. It's probably good practice to avoid
 bundling the short segment of fuselink wire into a larger bundle, but
 there usually wouldn't be any need to do that, anyway. If you have
 serious doubts/questions, then make yourself a test rig and test a
 segment (common sense protections for yourself and other stuff obviously
 applies).
 The fiberglass sleeving trick is typically used for the small gauge
 links that are user-fabbed from regular small gauge wire that has
 typical aircraft insulation.
 www.avast.com
		jcohen@post.com
				 Posted: Fri Feb 17, 2023 2:08 pm    Post subject: Re: Building fusible links for FAT wires |
				 	  | Ceengland wrote: | 	 		  On 2/17/2023 1:49 PM, jcohen(at)post.com wrote:
  Jeff
 Hi Jeff,
 applies).
 www.avast.com |
 Thank you Charlie. I will bench test  the link to understand more of how the link reacts.  Would there be any downside to attaching the 6” link at the B terminal of the pri alternator , rather than at the terminal on the starter contactor as depicted on Z101? That could help with fire proximity issues with contactors and/or battery. That implementation still protects the entire wire the same way, even when the protection is on the other “end” , right?
		Ceengland
				 Posted: Fri Feb 17, 2023 2:30 pm    Post subject: Building fusible links for FAT wires |
				On 2/17/2023 4:08 PM, jcohen(at)post.com wrote:
 >>   Jeff
 >> Hi Jeff,
 > applies).
 > Charlie
 > This email has been checked for viruses by Avast antivirus software.
 > www.avast.com
  Thank you Charlie. I will bench test  the link to understand more of how the link reacts.  Would there be any downside to attaching the 6†link at the B terminal of the pri alternator , rather than at the terminal on the starter contactor as depicted on Z101? That could help with fire proximity issues with contactors and/or battery. That implementation still protects the entire wire the same way, even when the protection is on the other “end†, right?
 There is a downside to placing it at the alternator. Remember, the fuse
 (whether CB, link, or actual fuse) is there to protect the wire. The
 alternator B lead wire should be big enough to handle the highest
 current the alternator can create (usually a small percentage higher
 than its 'rated' output), so there's no need to protect the wire from
 the alternator. The danger to the B lead is from the *battery*. So the
 fusing device should be on the 'dangerous' end, to protect the wire. (It
 is confusing, when you have devices at both ends that are both capable
 of producing current.)
		johnbright
				 Posted: Fri Feb 17, 2023 3:54 pm    Post subject: Re: Building fusible links for FAT wires |
				 	  | jcohen(at)post.com wrote: | 	 		  | ... I will bench test  the link to understand more of how the link reacts.  Would there be any downside to attaching the 6” link at the B terminal of the pri alternator , rather than at the terminal on the starter contactor as depicted on Z101? That could help with fire proximity issues with contactors and/or battery. That implementation still protects the entire wire the same way, even when the protection is on the other “end” , right? |
 The way I express it is the protection (relay, contactor, fuse, current limiter, CB, fusible link) should be as close as possible to the power source which in this case is the battery. The battery can put out hundreds of amps and the alternator can only put out its rating (plus a little more if it's cold) so it is not capable of damaging itself or the B lead.
 Suppose the alternator B leads gets pinched to ground somehow... one wants the fuselink to open before the battery self-destructs.
 I don't imagine a melted B lead fuselink will create enough fire to burn the contactor case. Bob Nuckolls shows the fuselink at the contactor for a reason. I look forward to your experiment of burning one. A 12 awg wire will burn at ~235A and a 14 awg at ~166A.
 BTW, what is the rating of your alternator?
N1921R links |
				 Posted: Fri Feb 17, 2023 4:52 pm    Post subject: Building fusible links for FAT wires |
				 	  | Quote: | 	 		  | Suppose the alternator B leads gets pinched to ground somehow... one wants the fuselink to open before the battery self-destructs. |
     Wire damage is unlikely. Shorted diodes in alternator
     is more likely but still rare.
   	  | Quote: | 	 		  | I don't imagine a melted B lead fuselink will create enough fire to burn the contactor case. |
     The definition of any fusible circuit protection is
     "a means by which a conductor can be protected
      from catastrophic failure due to hard fault
      down stream of a potentially hazardous energy
      source."
     In our cases, potentially hazardous energy sources
     start with a battery (1000 amps) joined in relatively
     minor concert with alternator(s) (40 to 125A?).
     Circuit protection should function to clear the
     faulted feeder with MINIMAL damage to adjacent
     hardware and zero propagation to other systems.
     Oh yeah, any by-products of fault clearance activity
     should not become a hazard to occupants of the
     machine (smoke).  This applies to all vehicles
     including but not limited to rail locomotives,
     trucks and yeah, airplanes.
   	  | Quote: | 	 		  |  Bob Nuckolls shows the fuselink at the contactor for a reason. I look forward to your experiment of burning one. A 12 awg wire will burn at ~235A and a 14 awg at ~166A. |
     The wire to be protected in this instance
     is the alternator b-lead itself. The energy
     source is the battery. The fault will most
     likely be failed rectifier in the alternator.
     I've 'smoked' a number of COTS (commercial off
     the shelf) fusible link wires. Those current
     'ratings' are irrelevant in the face of probable
     fault conditions probably exceeding 1000 amps.
     The smoke generated was not 'pleasant' but not
     debilitating and short lived. Damage to said insulation
     was remarkably minor. Fusible link insulation
     is intended to contain the effects of a fused
     wire such that damage to materials and components
     outside that insulation is minimized. See "Hypalon"
     insulation history.
   	  | Quote: | 	 		  | BTW, what is the rating of your alternator? |
     Relevant only to the extent of sizing b-lead
     wire conductor size to limit voltage drop
     to design goals . . . generally on the order
     of a few hundred millivolts at full load.
     I've got some videos of fusible link burns
     that I'll try to dig up . . . or perhaps
     duplicate.
    out of that stuff?"
				 Posted: Fri Feb 17, 2023 4:55 pm    Post subject: Building fusible links for FAT wires |
				 	  | Quote: | 	 		  | There is a downside to placing it at the alternator. Remember, the fuse (whether CB, link, or actual fuse) is there to protect the wire. The alternator B lead wire should be big enough to handle the highest current the alternator can create (usually a small percentage higher than its 'rated' output), so there's no need to protect the wire from the alternator. The danger to the B lead is from the *battery*. So the fusing device should be on the 'dangerous' end, to protect the wire. (It is confusing, when you have devices at both ends that are both capable of producing current.) |
     B-lead protection is ALWAYS designed to deal
     with BATTERY faults as the potentially hazardous
     condition. An alternator is physically incapable
     of opening its own b-lead protection.
     BATTERIES are always the driving consideration for
     placement and sizing of fusible links and/or current
     limiters (ANL, ANN, MANL, etc).
    out of that stuff?"
		johnbright
				 Posted: Fri Feb 17, 2023 6:26 pm    Post subject: Re: Building fusible links for FAT wires |
				 	  | nuckolls.bob(at)aeroelect wrote: |
    Bob . . . |
 I’m just curious the OP chose 8 awg main alternator B lead. I have the impression main alternators are usually 60A with 6 awg B lead. This is an RV-7 with SDS EFI+I so current demands are higher than without EFI+I. I understand conductor sizing is not an exact science and the smaller wire will just get a little warmer and drop a little more voltage without being a safety issue.
 My notes show 8 awg rated 40A and 6 awg 54A for the 10C rise criteria. I understand this is conservative when not in a bundle.
 My load analysis for four cylinder SDS EFI+I ship shows 44A with both pumps running in addition to pitot heat, seat heat, lambda sensor, landing nav and strobe lights, dual Skyview and its accessories… so in reality 8 awg is not a problem.
N1921R links |
				 Posted: Sat Feb 18, 2023 10:23 am    Post subject: Building fusible links for FAT wires |
				 	  | Quote: | 	 		  My load analysis for four cylinder SDS EFI+I ship shows 44A with both
  so in reality 8 awg is not a problem. |
    8AWG wire has 0.63 milliOhms/ft. At 60A full alternator
    load, this would drop 60 x 0.00063 = 0.038 or 38 milliVolts
    per foot of b-lead. A trivial significance even if you
    were able to achieve this unlikely operating load.
    You are correct, this single conductor hanging out in the air
    would not be at risk for compromise in your proposed
    configuration.
    My drawings tend to show 4AWG throughout the FAT wire
    matrix because it works in the full constellation of
    situations. It minimizes the need to scrounge up
    little chunks of assorted wire sizes, terminals and
    crimp tools just to satisfy some design goal for
    'optimizing' wire sizes . . . especially since 'optimal'
    has no industry wide definition. The weight penalties
    for a slightly oversized wire are very small
    while the fabrication and procurement benefits for
    'one size fits all' are significant.
    My '87 pick-em-up truck has an 10AWG b-lead feeder.
    Alternators for that truck could be as beefy as 90A!
    Hmmmm . . . 90A x 0.001 ohms/ft x 2 feet is 0.180
    volts . . . ho hum. The wire is hanging out in a big
    breeze.
    Speaking of crimp tools . . .
    A few years ago I snapped up a Harbor Freight
    offering for a hand-held, hydraulic crimping
    tool that came with a set of hex dies. The
    dies proved to be next to useless . . . too
    large of step between the graduation of sizes.
    Took the thing back to HF.
    A new kid on the block has appeared on Amazon,
    et. als. with a more granular selection of hex
    dimensions. I'm doing some test crimps on various
    combinations of materials and developing a
    process by which the OBAM aircraft builder's
    probability of reliable crimps is very high.
    Here's one of many examples:
   https://tinyurl.com/2e8evels
    There are offerings with more than 9 die
    sets but these tend to add big honk'n
    dies for wire that your airplane could
    could not lift!
    Watch this space . . .
    out of that stuff?"
		Ceengland
