Erich_Weaver(at)URSCorp.c Guest
Posted: Mon Jul 31, 2006 11:19 am Post subject: oil cooler and vernatherm |
I am considering purchasing the oil cooler shutter that Vans offers, but
dont exactly understand the need for this product. Shouldnt a correctly
operating vernatherm, which most of our engines come with, do the same
job, or am I missing something?
Erich Weaver
n223rv(at)wolflakeairport Guest
Posted: Mon Jul 31, 2006 3:32 pm Post subject: oil cooler and vernatherm |
Contrary to what I have read on some of the posts, the vernitherm always
lets a bit of oil through to the oil cooler. I know because I tested
it.
By blocking the airflow to the oil cooler, you will be able to raise the
oil temp. My concern with Van's set-up is that when their shutter is
open, it is also blocking 1/2 of the air to the oil cooler..... So when
your engine is running hot and you need to cool the oil real bad, you
are losing airflow. I know you could remove it in the summer, but that
would defeat the purpose.
-Mike Kraus
dbris200(at)sbcglobal.net Guest
Posted: Mon Jul 31, 2006 4:48 pm Post subject: oil cooler and vernatherm |
The vernatherm only bypasses the oil cooler, it does not restrict the flow to it, so you will always have some oil going to the cooler.
Dave
Mike Kraus wrote:
[quote] [quote]--> RV-List message posted by: "Mike Kraus" <n223rv(at)wolflakeairport.net> (n223rv(at)wolflakeairport.net) Contrary to what I have read on some of the posts, the vernitherm always lets a bit of oil through to the oil cooler. I know because I tested it. By blocking the airflow to the oil cooler, you will be able to raise the oil temp. My concern with Van's set-up is that when their shutter is open, it is also blocking 1/2 of the air to the oil cooler..... So when your engine is running hot and you need to cool the oil real bad, you are losing airflow. I know you could remove it in the summer, but that would defeat the purpose. -Mike Kraus --
