meat_ball
Posted: Thu Dec 21, 2023 3:08 pm Post subject: Twin Engine help Z-14 |
Hello all,
I am planning a twin velocity build and the logical choice is to incorporate the Z-14 drawing for electrics. I am stuck with how to incorporate the 2 engine start system into the schematic. Is there a way to add a rotary switch after the Starter/Crossfeed switch that will select respective engines to start? Is there a better way to do it while keeping the same architecture as the original drawing? I can follow schematics, I can physically build the systems, but I can't for the life of me conceptualize the ins and outs....
Any help would be appreciated!
Have a great day,
Rob
cluros(at)gmail.com Guest
Posted: Thu Dec 21, 2023 3:33 pm Post subject: Velocity V-Twin Z-14 |
I would follow the philosophy of every other twin on the planet and have separate LEFT starter switch for the left engine and RIGHT starter switch for the right engine.
Take everything engine related in Z-14 and have a second copy for the second engine.
| Quote: | On Dec 21, 2023, at 15:11, meat_ball <arjayefem(at)fastmail.net> wrote:
Hello all,
Have a great day,
Rob
http://forums.matronics.com/viewtopic.php?p=512830#512830
meat_ball
Posted: Thu Dec 21, 2023 4:25 pm Post subject: Velocity V-Twin Z-14 |
How many batteries and alternators are you planning? Electrically dependent engines?
On Thu, 21 Dec 2023, 15:43 meat_ball, <arjayefem(at)fastmail.net (arjayefem(at)fastmail.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: "meat_ball" <arjayefem(at)fastmail.net (arjayefem(at)fastmail.net)>
Thanks for the reply! That was my first inclination, but as I have said, I can't conceptualize how to make the tie-in to the crossfeed work. What wires would connect to where?
http://forums.matronics.com/viewtopic.php?p=512832#512832
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
-Matt Dralle, List Admin.
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
meat_ball
Posted: Thu Dec 21, 2023 5:07 pm Post subject: Re: Velocity V-Twin Z-14 |
2batts and 2 alts. Identical to Z-14 except adding the second engine. As far as electrically dependent engines, I haven’t decided yet if I’ll have completely dependent, but I will have at least one electronic ignition per engine.
| cluros(at)gmail.com wrote: | How many batteries and alternators are you planning? Electrically dependent engines?
On Thu, 21 Dec 2023, 15:43 meat_ball, <arjayefem> wrote:
| Quote: | --> AeroElectric-List message posted by: "meat_ball" <arjayefem>
FORUMS -
WIKI -
b Site -
Posted: Thu Dec 21, 2023 8:23 pm Post subject: Velocity V-Twin Z-14 |
I see the problem. Z-14 is one engine driving a primary and a backup alternator. You say your aircraft's electrical system will be identical except two engines instead of one. Does that mean you will have one engine with a 60A alternator and the other engine with only a small 20A backup? You're going to pull all your electrical power from one engine and if it (or the alternator) fails, most of your panel will go dark and you'll recover the aircraft to the nearest suitable airport using the backup alternator and the batteries?
I suggest it would be better to go with a more traditional setup of one battery, one full sized alternator on each engine, and some way to balance the load between the two alternators. Z-12 with everything engine related doubled and somewhere for them to meet in the middle.
On Thu, Dec 21, 2023 at 5:10 PM meat_ball <arjayefem(at)fastmail.net (arjayefem(at)fastmail.net)> wrote:
> > Read this topic online here:
> > http://forums.matronics.com/viewtopic.php?p=512832#512832 (http://forums.matronics.com/viewtopic.php?p=512832#512832)
> > FORUMS -
> > WIKI -
> > b Site -
http://forums.matronics.com/viewtopic.php?p=512834#512834
FORUMS -
WIKI -
b Site -
="noreferrer" target="_blank">https://matronics.com/contribution
meat_ball
Posted: Fri Dec 22, 2023 12:21 pm Post subject: Re: Twin Engine help Z-14 |
I appreciate the feedback. I know this may sound smug or offensive, but it see no other way to say it. I haven't asked for the moon. I have come here to ask for the help of the experts with my shortfalls which is the conceptualization.
Let's just say I have digested the diagrams and what each one of them offers. Let's also say that I have considered what it is what I am looking for in an aircraft and its systems. Let's further consider that I really want to go with dual batteries and dual alternators and that I see no other reason to go with anything other, except that I want to.
How would one incorporate the second engine starting system into the Z-14 diagram? The alternators will be one 40 amp per engine. Is there anyone who can help with this?
Posted: Fri Dec 22, 2023 2:06 pm Post subject: Twin Engine help Z-14 |
So you're going to replace the Aux Alternator in Z-14 with a regular alternator on a second engine and keep the main and aux batteries. Ok.
In that case the output of the aux battery contactor would then go to the second engine starter contactor the same way the main battery contactor has a 4awg wire going to the starter contactor in Z-14. Copy the starter equipment coming off the main battery contactor and paste it into the aux battery contactor between the aux battery contactor and the cross-feed contactor. Your starter/cross-feed switch now needs 4 positions (Cross-feed / Off / Start Eng 1 / Start Eng 2) (On / Off / (On) / (On)) which I'm not sure exists so maybe you want to replace it with 3 switches? Cross-feed (On / Off)/ Start Eng 1 ((On) / Off)/ Start Eng 2 ((On) / Off).
On Fri, Dec 22, 2023 at 12:24 PM meat_ball <arjayefem(at)fastmail.net (arjayefem(at)fastmail.net)> wrote:
http://forums.matronics.com/viewtopic.php?p=512843#512843
FORUMS -
WIKI -
b Site -
Posted: Fri Dec 22, 2023 6:16 pm Post subject: Twin Engine help Z-14 |
engine. Is there anyone who can help with this? |
Z14 illustrates TWO, independently
energized electrical systems . . .whether
driven by two alternators on one engine or
two alternators on two engines. Z14 was
originally crafted for single engine with
one large and one smaller alternator . . .
could just as easily be two engines with
one large alternator each . . . or one
large and one small alternator each.
A feature in the form of a cross-feed contactor
allows for (1)tying both systems together for engine
cranking and (2) sharing energy between systems
in case of loss of a main alternator on one
engine.
Fabricate two, essentially identical systems.
One on each engine. Then tie them together
as the situation dictates.
In your case, you have four alternators. So the
value/need for any elaborate bus switching
for load shedding seems unlikely.
That's why I suggested that you accomplish
the detailed load analysis on an accessory-by-
accessory basis with identification of
loads that can be dispensed with under
conditions defined my your failure modes
effects analysis.
How much output can be expected from your
smaller alternators?
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
