toggle switches better than Carling?
N1921R
PostPosted: Sat Feb 03, 2024 4:54 pm    Post subject: toggle switches better than Carling? Reply with quote
After reading on VAF about failures of Carling toggle switches with faston tabs attached with hollow rivets I was planning to use Honeywell TS but they have been discontinued.
One VAF thread: https://vansairforce.net/threads/failing-intermittent-toggle-switch.172765/
I'd like to find good quality toggle switches that use faston tabs and come in configurations like 2-10... any thoughts here on AEL?
I find APEM on Newark, part number 644H/2 for instance seems to be 2-10 configuration. It has tabs called solder lug/quick-connect which have a larger thru hole compared to what APEM calls normalized quick-connect tabs which have the smaller through hole I am used to seeing. APEMs with normalized quick-connect tabs are not stocked that I can find. The switch description says "terminal and contact support is manufactured from a single piece of metal. The contacts are resistance-welded to the terminal for increased mechanical strength". Bushing dia is 12 mm which is practically the same, 0.004" larger, compared to the 15/32" I am used to.
Newark page for APEM 644H/2: https://www.newark.com/apem/644h-2/switch-dp3t-10a-250vac/dp/96C7308
APEM 600H data sheet: https://www.farnell.com/datasheets/1697794.pdf
John Bright, RV-6A N1921R, working on FWF.
Single battery, alternator on main bus, Monkworkz generator on engine/essential bus.
My links here
kenryan
PostPosted: Sun Feb 04, 2024 6:29 am    Post subject: toggle switches better than Carling? Reply with quote
Nikkai (NKK) switches seem good to me and they are available in fast on configuration.
On Sat, Feb 3, 2024 at 3:58 PM N1921R <RV.6A.N1921R(at)gmail.com (RV.6A.N1921R(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "N1921R" <RV.6A.N1921R(at)gmail.com (RV.6A.N1921R(at)gmail.com)>
My links <a href="https://docs.google.com/document/d/1YOtPiA3AdUsQEYR4nodBESNAo21rxdnx4pFs7VxXfuI/edit?pli=1">here</a>
http://forums.matronics.com/viewtopic.php?p=513195#513195
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
Ceengland
PostPosted: Sun Feb 04, 2024 9:16 am    Post subject: toggle switches better than Carling? Reply with quote
On Sat, Feb 3, 2024 at 6:58 PM N1921R <RV.6A.N1921R(at)gmail.com (RV.6A.N1921R(at)gmail.com)> wrote:
Hi John,
Did you read the entirety of that VAF thread? Might be worth your time to go back and re-read it, assigning weight to what's significant. Your takeaway about hollow rivets might be the most insignificant thing in the thread. Wink There are also some criticisms of supposed failure points where the responder got the failure point wrong. Only one responder mentioned multiple failures; that could have been a bad batch of switches, or 'pilot error'. Consider that quite a few of us have seen failures of milspec circuit breakers; does that mean *everyone* should find a different circuit breaker?
(I was the 1st responder to that VAF thread.)
Virus-free.www.avast.com[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
Charlie
Voyager
PostPosted: Sun Feb 04, 2024 9:54 am    Post subject: toggle switches better than Carling? Reply with quote
Sent from my iPad
On Feb 4, 2024, at 12:18 PM, Charlie England <ceengland7(at)gmail.com> wrote:
Hi John,
I was thinking the same thing. A well set hollow rivet will withstand a hundred pounds of force easily. My S-21 is almost entirely made of essentially hollow rivets. Sure, they still have the mandrel in place, but this only helps in shear force. Tensile strength is pretty much entirely from the hollow rivet body.
If rivets on the contacts are failing, that is either due to a bad manufacturing batch (it happens to the best of companies) or poor installation where the wires lack proper strain relief.
I plan to use switches from B & C and they may be Carling or a similar brand and I have no concern with longevity. I use relays for any circuit that draws more than a couple amps just as most modern cars use. And the risk of a switch going bad due to too little current being switched can happen, but that is largely an OWT today. And generally this only affects switches that are switching logic level currents with computers, PLCs, etc, where the current is measured in micro amps or small mA numbers. Even a typical auto relay coil flows enough current (30 mA or more) for most switches to live a pretty long life.
Matt
PostPosted: Sun Feb 04, 2024 12:07 pm    Post subject: toggle switches better than Carling? Reply with quote
At 11:15 AM 2/4/2024, you wrote:
On Sat, Feb 3, 2024 at 6:58 PM N1921R <RV.6A.N1921R(at)gmail.com (RV.6A.N1921R(at)gmail.com) > wrote:
--> AeroElectric-List message posted by: "N1921R" <RV.6A.N1921R(at)gmail.com (RV.6A.N1921R(at)gmail.com) >
After reading on VAF about failures of Carling toggle switches with faston tabs attached with hollow rivets I was planning to use Honeywell TS but they have been� discontinued.
Failed after 660 hrs??? How many years of service and
under what manner of environmental/service stress? Was
root cause for the failure skillfully diagnosed?
I've studied and resolved dozens of 'contact failures'
in a constellation of relays and switches that
ranged from hardware-store to mil-spec devices.
There were very few instances wherein
studies were the basis for 'upgrading' a
failed device.
The Carling switch configuration under discussion
has been used in very high volumes in aircraft
for decades. We're just making the change-over
to those switches (with rocker actuators)
at Cessna when I worked there in 1965.
Yes, there were field failures but relatively
rare in the grand scheme of things with majority
of failures attributable to conditions external
to the switch . . . moisture, bad
terminal crimp, poor fast-on-grip, etc.
So what's the benchmark for satisfactory
service life? Is the failure of any switch
a potential for uncomfortable termination
of flight? If so, what about the myriad
of peripheral components of that system?
Had a reader many moons ago who was worried
about the quality of his landing light
switch . . . I had to remind him, "You do
know those bulbs burn out sometime."
Do your FMEA and strive to have no single
failure become a hazard to comfortable
completion of flight.
Did a study on roll trim relays on Beechjets
way back when where contacts were sticking
shut causing the occasional hard-over runaway
in roll trim.
After much study and bench tests I discovered
a design consideration that didn't manifest
until a redesign of the trim system replaced
legacy 10A relays (mil-spec no less) with
a 5A relay (also mil-spec). I discovered
that arcing during contact bounce was
exacerbated by reflections of energy
from the far end of a shielded wire
bypassed with a fat capacitor. Clip
the shield ground or eliminate the
capacitor (neither one of which was
needed) and the problem resolved.
During the investigation of some 2+
years, I did discover that one brand
of relay was a bit more tolerant of
the abuse. Management in their infinite
wisdom purged stock of the 'bad' relay
and banned them from future purchase.
The 'good' relay was substituted and
life went on . . . that way nobody
had to change any drawings.
Yeah, that's a short story made long but
I hope it illustrates the value in having
good data as to cause/effect and cost/benefit
before changing course from a well worn pathway.
� (o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
N1921R
PostPosted: Sun Feb 04, 2024 2:44 pm    Post subject: Re: toggle switches better than Carling? Reply with quote
Thanks guys for bringing me back to reality.
My links here
