Burrilla
Posted: Mon Apr 01, 2024 10:11 pm Post subject: Baggage area tie downs |
I have four “u” bolts at each corner of the baggage bay. They are bolted to hard points made by floxing a ply layer under the bay floor..
You can get a cargo net from any motorcycle dealer as the are used to tie luggage to a bike.
Alan
Sent from my iPad
| Quote: | On 9 Mar 2024, at 13:01, JonathanMilbank <jdmilbank(at)yahoo.co.uk> wrote:
I use a smallish net which came with my Skoda car i.e. a VW made in the Czech Republic, with four hooks, one at each corner. The anchor points for each hook are medium / small cable tie wraps.
Four small holes, similar diameter to the width of the tie wraps, are drilled through the baggage bay bulkhead at about the same level as the "headrests" and through each "headrest". A cable tie is passed through each hole from the opposite side to where the net hook will attach and then pushed back through the same hole. Each cable tie then gets zipped, leaving four loops as anchors on the headrests and rear bulkhead.
http://forums.matronics.com/viewtopic.php?p=513369#513369
