Kellym
Posted: Wed May 29, 2024 1:55 pm Post subject: ANL fuse 60 amp. |
My RV-10 has a 60 amp ANL fuse installed right below the shunt for the
ammeterr, The fuse has blown, and I cannot find where I got the fuse 10
years ago. Aircraft Spruce appear to be no help. I know they used to be
common on experimental airplanes.
I have a 60 amp Plane power alternator.
KCHD |
Tim Olson
Posted: Wed May 29, 2024 6:03 pm Post subject: ANL fuse 60 amp. |
Those things aren’t really aircraft parts. They’re more for car speakers and things like that. Not that they don’t work fine. I have them in my airplanes too. But you can buy them on Amazon, or eBay. I haven’t even ever looked at them in local stores before, but you might have luck if you have a high and car stereo store around you.
| Quote: | On May 29, 2024, at 5:01 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
My RV-10 has a 60 amp ANL fuse installed right below the shunt for the ammeterr, The fuse has blown, and I cannot find where I got the fuse 10 years ago. Aircraft Spruce appear to be no help. I know they used to be common on experimental airplanes.
Kellym
Posted: Wed May 29, 2024 6:36 pm Post subject: ANL fuse 60 amp. |
That is what I eventually found. Looks like Home Depot can get within a
day or two.
On 5/29/2024 7:02 PM, Tim Olson wrote:
KCHD |
Joined: 28 Mar 2008 Posts: 1972 Location: Riley TWP Michigan
Posted: Wed May 29, 2024 7:02 pm Post subject: Re: ANL fuse 60 amp. |
Make sure the connections are tight. A loose connection gets hot and could
cause a fuse to blow. Do you have a lithium battery?
_________________ Joe Gores |
Kellym
Posted: Wed May 29, 2024 7:14 pm Post subject: ANL fuse 60 amp. |
I'll make sure the connections are tight. I just has an Odyssey AGM battery
Kelly
KCHD |
Dave Saylor
Posted: Wed May 29, 2024 7:32 pm Post subject: ANL fuse 60 amp. |
B&C and SteinAir have them.
On Wed, May 29, 2024 at 7:06 PM Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
> On May 29, 2024, at 5:01 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
> --> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
="noreferrer" target="_blank">https://matronics.com/contribution
_________________ --Dave
KWVI |
jimkale(at)roadrunner.com Guest
Posted: Thu May 30, 2024 4:56 am Post subject: ANL fuse 60 amp. |
Large trucks use those fuses try a large truck shopSent from my iPhone
| Quote: | On May 29, 2024, at 22:41, Dave Saylor <saylor.dave(at)gmail.com> wrote:
N1921R
Posted: Thu May 30, 2024 6:46 am Post subject: Re: ANL fuse 60 amp. |
If you have Amazon Prime
Search "Blue Sea Systems 5123 ANL Fuse, 60A" within Amazon and select "All Prime"
$21.04
_________________ John Bright, RV-6A N1921R, working on FWF.
Single battery, alternator on main bus, Monkworkz generator on engine/essential bus.
My links here |
Posted: Thu May 30, 2024 9:29 am Post subject: Re: ANL fuse 60 amp. |
Read this thread:
http://forums.matronics.com/viewtopic.php?t=16778818
Especially the post by Charlie and his picture of fusible links.
Posted: Fri May 31, 2024 2:19 am Post subject: ANL fuse 60 amp. |
At 10:31 PM 5/29/2024, you wrote:
| Quote: | B&C and SteinAir have them.
Those things aren't really aircraft parts. They're more for
car speakers and things like that. Not that they don't work
fine. I have them in my airplanes too. |
Not sure there is ANY catalog part, fuses and
limiters included, that you might call an
'aircraft' part. Catalog components become
suited to task for aviation 'cause
they appear on the drawings for a certified
airplane, military vehicle, spacecraft, etc.
The ANL/ANN series devices have been used aboard
aircraft for about 100 years . . . lots of them
scattered about B17's, KingAirs, LearJets and the
like. I introduced them to OBAM aviation a few
decades ago after an abortive decision to try
the JNN series fuses as bolt-on, in-line fuses
for b-lead protection.
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/JNN_Specs.pdf
Bad idea, these critters didn't have the mechanical\
robustness needed for such service. Plan-B was
the ANL series devices and companion fuse-holders . . .
certainly ROBUST but rather huge for little
airplanes.
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/Limiter_FuseBlocks.pdf
Not too many years after that, the major players
in fusible protection (Bussman, Littlefuse, etc)
Brought out some hardened and more attractive
alternatives to the sheet-metal, limiters common
to some European cars. Those are illustrated on
the website as:
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Littlefuse/498.pdf
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Littlefuse/298.pdf
A visit to about any big automotive parts store
will provide sources for devices cited above
or very similar.
Holders for the modern devices are simple insulating
blocks drilled for fuse/wiring and attachment to the
airframe. I've made many of these things with a table
or band-saw and drill press. Phenolic, Delren, Lexan,
even kitchen cutting boards offer sufficiently
robust, non-conductive material for a base.
The car parts stores, amazon, ebay, et.als. will also
have manufactured holders.
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Littlefuse/0498-MIDIFuseholder.pdf
But I usually build 'em when I need one.
You could also consider a fusible link. If it were
my airplane, a 6AWG b-lead protected by a 10AWG
fusible link would be an attractive up-grade from
bolt-on current limiters.
The nagging question is, Why did your original
limiter open up? Electrical fault or mechanical
aging? I think I'd jumper across your original
ANL mounting space with a hung of 12AWG wire
and fire up the engine to see how the alternator
is performing. Without seeing the wiring diagram
for your airplane, I'm guessing that the ANL was
for alternator b-lead protection?
Inquiring minds would like to know . . .
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
for the-best-we-know-how-to-do based
on physics and repeatable experiment.
Kellym
Posted: Fri May 31, 2024 6:29 pm Post subject: ANL fuse 60 amp. |
I am procuring tomorrow the necessary pieces to test with a fusible link, as I have not found what caused the fuse to blow.
It is 10 years old so age could have been a factor I didn't have the pieces leftover from my build. I will test the system before installing a new fuse.
Kelly
On 5/31/2024 3:19 AM, Robert L. Nuckolls, III wrote:
| Quote: | The ANL/ANN series devices have been used aboard
Plan-B was
airplanes.
or very similar.
KCHD |
