blackoaks(at)gmail.com Guest
Posted: Tue Aug 01, 2006 3:58 am Post subject: Installation Location of LR3C regulator |
Have any of you put the B & C regulator on the back side of the firewall as suggested on the installation sheet? Lancair mounted mine on the front side. They seem to operate just fine no matter where they are. How important to longevity is the location? Comments Bob??? or anyone! Thanks in advance...
John McMahon
Lancair Super ES, N9637M
Posted: Tue Aug 01, 2006 4:54 am Post subject: Installation Location of LR3C regulator |
I put both my primary and secondary regulators on the 'back' side of the firewall. I added a second rudder pedal support and built a shelf across the two to mount both of them.
It minimizes the length of the wiring runs.
It minimizes through firewall wiring penetrations (to one wire for each regulator).
It places them further aft for CG purposes.
It allows for inspection/replacement without removing the cowl.
Pictures if you want them - contact me directly,
Ralph Capen
RV6AQB N822AR (at) N06 Getting ready to close up fwd topskin.....
[quote]--
clouduster(at)austin.rr.c Guest
Posted: Tue Aug 01, 2006 8:24 am Post subject: Installation Location of LR3C regulator |
I am planning on mounting my Ford voltage regulator on the engine side of the firewall next to the battery. The regulator is temperature compensating so I felt it should be at the same temperature as the battery. I'm I incorrect?
Dennis H.
Ralph E. Capen wrote:
[quote]--> AeroElectric-List message posted by: "Ralph E. Capen" I put both my primary and secondary regulators on the 'back' side of the firewall. I added a second rudder pedal support and built a shelf across the two to mount both of them.
Ralph Capen
| Quote: | -----Original Message-----
Sent: Aug 1, 2006 7:53 AM
John McMahon
Posted: Tue Aug 01, 2006 9:27 am Post subject: Installation Location of LR3C regulator |
Yours might be better where you're planning it - for the reasons that you've indicated....
My battery happens to be behind the firewall - in roughly the traditional RV6(A) position. My regulators have a temp compensation option (connects to the battery) but I wasn't planning to use it.
Different configurations .....
[quote]--
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Aug 01, 2006 10:17 am Post subject: Installation Location of LR3C regulator |
On Aug 1, 2006, at 12:23 PM, Dennis Haverlah wrote:
| Quote: | I am planning on mounting my Ford voltage regulator on the engine
No.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Tue Aug 01, 2006 10:28 am Post subject: Installation Location of LR3C regulator |
In a message dated 08/01/2006 11:30:33 AM Central Daylight Time, clouduster(at)austin.rr.com writes:
| Quote: | | I am planning on mounting my Ford voltage regulator on the engine side of the firewall next to the battery. The regulator is temperature compensating so I felt it should be at the same temperature as the battery. I'm I incorrect? |
Pretty much what I did- original $10 unit from Advance Auto Parts has performed well here for 340 hrs & 2.5 yrs. See:
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=7264
Click on foto for larger view. "Battery box" is .063 angles attached to firewall, .040 side plates and front cover strap which is attached to side plates with hinges. Regulator is bolted to front cover with ground wire to firewall.
From The PossumWorks in TN
Mark Phillips
_________________ From The PossumWorks... |
nuckollsr(at)cox.net Guest
Posted: Tue Aug 01, 2006 8:52 pm Post subject: Installation Location of LR3C regulator |
At 04:53 AM 8/1/2006 -0700, you wrote:
| Quote: | Have any of you put the B & C regulator on the back side of the firewall
EVERY manufacturer would like to have you place THEIR product
in the most benign environment possible. But the bottom line is
that short of bolting the LR3 to an engine or exhaust part,
it will be fine on the forward side of the firewall also.
Of the gazillions of automotive regulators mounted under
the hoods of cars in some of the most stressful environments,
how many manufacturers would stay in business very long if
their particular electro-whizzie was ill-suited to compete?
< with experiment. >
< --Lawrence M. Krauss >
icubob(at)newnorth.net Guest
Posted: Wed Aug 02, 2006 2:42 am Post subject: Installation Location of LR3C regulator |
hi tom,
several months back i asked the same question and got about the same
answer. logic on that one was to keep the capicator forward of the metal
firewall and close to the regulator. atleast they are consistant.
bob n.
