Speedy11(at)aol.com Guest
Posted: Tue Aug 01, 2006 11:25 pm Post subject: Is this solder okay? |
I'm wondering if common auto parts store solder is acceptable to use for connecting airplane wires. Yes, I know about using fastons. The soldering I need to do is on small rotary switches and using fastons is not feasible.
So, is Rosin Flux Core 3/32" 40/60 tin-lead acceptable?
Stan Sutterfield
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Wed Aug 02, 2006 3:35 am Post subject: Is this solder okay? |
On Aug 2, 2006, at 3:22 AM, Speedy11(at)aol.com wrote:
| Quote: | I'm wondering if common auto parts store solder is acceptable to
Normally the tin content is listed first and the stuff you want is
very close to 60% tin and 40% lead. This is known as 60/40 solder. If
what you are looking at is 40/60 you definitely don't want it.
The ideal solder for electrical connections is actually 63% tin 37%
lead (63/37). This is also known as eutectic solder. It has the
characteristic that, as it cools, it goes directly from liquid to
solid without passing through a pasty "plastic" phase. I also just
found out that it has the highest tensile strength of all the tin/
lead solder alloys.
http://www.efunda.com/materials/solders/tin_lead.cfm
The top solder manufacturers used to be Kester and Ersin. Kester
still seems to be around but I can't find a link to Ersin.
http://www.kester.com
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
FLYaDIVE(at)aol.com Guest
Posted: Wed Aug 02, 2006 6:22 am Post subject: Is this solder okay? |
| Quote: | use for connecting airplane wires. Yes, I know about using
Stan:
40/60 NO! But, I think you have the numbers mixed up, it is probably 60/40.
If it is 60/40 that is acceptable but not the best. See if you can find 63/37 it is know as Eutectic Solder.
It does a great job especially at low soldering temperatures. No0need to burn the wire or damage the components.
The solder thickness is OK but again not the best, see if you can find0.063" For electronic work thin solder is better since it requires less heat and time duration to melt. Also it fits into many a small solder pin connector.
As for the Flux ... Does it say anything such as NA or RMA or RA? Here is where longevity of the connection is concerned.
The abbreviations stand for: NA = Non-Activated, RMA = Rosin Mildly Activated and RA = Rosin Activated. The ACTIVATED part is ACID or how corrosive the flux is. Most Rosin is of the RMA type and works quite well. As with ALL solder joints make sure you finish by cleaning the joint with isopropyl alcohol, use a soft toothbrush. Failure to do so will bring about corrosion.
Barry
"Chop'd Liver"
Bob McC
Posted: Wed Aug 02, 2006 6:25 am Post subject: Is this solder okay? |
Hi Brian;
_________________ Bob McC
Falco #908
(just starting) |
don.honabach(at)pcperfect Guest
Posted: Wed Aug 02, 2006 10:49 am Post subject: Is this solder okay? |
For larger diameter solder and switch work, you probably won’t need this, but it’s helpful if you are working with small diameter solder (which has limited amounts of flux) or doing any sort of PCB re-work. I keep a small bottle of Flux at my bench and will add a small amount to the joint/connection in some cases – mostly when doing de-soldering or if I need to ‘re-wet’ a joint to remove or add a component. The only catch is that you absolutely must clean up the joint with a cleaner afterwards to get rid of the acid left over. However, it does seem to really help in those cases where the solder doesn’t have enough flux or you need to de-solder/re-solder a joint.
Don
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of FLYaDIVE(at)aol.com
Sent: Wednesday, August 02, 2006 7:17 AM
Subject: Re: Is this solder okay?
Stan:
It does a great job especially at low soldering temperatures. No need to burn the wire or damage the components.
The solder thickness is OK but again not the best, see if you can find .063" For electronic work thin solder is better since it requires less heat and time duration to melt. Also it fits into many a small solder pin connector.
Barry
"Chop'd Liver"
brian
Posted: Wed Aug 02, 2006 1:22 pm Post subject: Is this solder okay? |
On Aug 2, 2006, at 2:44 PM, Don Honabach wrote:
| Quote: | For larger diameter solder and switch work, you probably won’t need
a joint.
Rosin flux is all you should ever use on electrical connections. It
is not acid. While not particularly pretty, it will do no damage to
your circuitry if you leave it on there.
If you are using acid flux, stop.
Posted: Thu Aug 03, 2006 6:38 am Post subject: Is this solder okay? |
Brian,
Thank you for your prompt and informative reply.
Stan Sutterfield
| Quote: | Normally the tin content is listed first and the stuff you want is
what you are looking at is 40/60 you definitely don't want it. |
Posted: Thu Aug 03, 2006 6:44 am Post subject: Is this solder okay? |
Barry,
Excellent info for an ignorant pilot. Thank you. I checked0the package and it does say 40/60 tin-lead, so I won't use it. I'll locate the Eutectic solder.
Stan Sutterfield
| Quote: | 40/60 NO! But, I think you have the numbers mixed up, it is probably 60/40.
63/37 it is know as Eutectic Solder. |
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Sat Aug 05, 2006 12:40 pm Post subject: Re: Is this solder okay? |
---The Final Word on 63Sn/37Pb or 60Sn/40Pb
I posted a post a couple years ago that said you could solder for a million years and never know the dfference.
The 63Sn/37Pb solidifies all at once and has no "mushy" range. For some purposes, often more decorative than practical, this is attractive. Since it melts at a slightly lower temperature and solidifies all at once, it solders faster. Wave soldering is done with 63/37 as it also tends to wet most untinned surfaces slightly better.
The 60/40 is more common, slightly cheaper, and has a small "mushy" range. While this makes it less shiny, the slight increase in mushiness makes it slightly easier to work with especially with bigger gaps.
Most experts on the matter tend to make no distinction between the two. Indeed, The quality of the solder itself and the temperature control of the iron, as well as the flux and the materials to be soldered are far more important to the overall quality of the joint.
Final advice--Here's where Brian and I agree--Ersin (now Henkel) Multicore is very good solder. You can get trashy solder that uses recycled materials from Radio Shack, and I hate to point fingers...but...they do have the worst solder on the planet!
"Future, n. That period of time in which our affairs prosper, our friends are true, and all happiness is assured."
- Ambrose Bierce
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Eric M. Jones
Posted: Sat Aug 05, 2006 6:12 pm Post subject: Re: Is this solder okay? |
PS--
"Ersin" Multicore (R) is now Henkel/Loctite Multicore and they only list 60/40 in their new catalog...
113 Brentwood Drive
(508) 764-2072
