nuckollsr(at)cox.net Guest
Posted: Tue Aug 01, 2006 8:59 pm Post subject: STC for standby generator on a |
Talk to B&C. The Mooney's were the first TC'd aircraft to get the
SD-20 style alternator on a production aircraft. I'm certain that by
now MANY Mooney owners have installed this system on older airplanes
under a one-time field approval (Form 337 or perhaps the limited
applicability STC). If anyone knows, they'd be the first to ask,
then go to Mooney Type Clubs.
At 02:11 PM 7/31/2006 -0500, you wrote:
What do you mean it would cost a fortune? Whom would I be paying money
to, and for what?
Dave Morris
At 09:48 PM 7/30/2006, you wrote:
>AFAIK, no one has STC'd a standby alternator for early Mooneys. The only
>place to put one would be on the vacuum pump pad. Unless one has been
>STC'd for the O-360, you would spend a fortune getting it approved.
-- incoming mail is certified Virus Free.
Checked by AVG Anti-Virus.
< with experiment. >
< --Lawrence M. Krauss >
Kellym
Posted: Wed Aug 02, 2006 4:57 am Post subject: STC for standby generator on a |
I've been on the Mooney email list for the last 8 years. No mention of
anyone retrofitting a standby alternator that I recall, on anything but
the late model planes as a replacement for the standby vacuum pump on
late models. The earlier models would require approval for removal of
the vacuum pump and installation of a dual electric system.
<nuckollsr(at)cox.net>
> <N6030X(at)DaveMorris.com>
> money to, and for what?
> Dave Morris
>> <kellym(at)aviating.com>
>> only place to put one would be on the vacuum pump pad. Unless one has
>> been STC'd for the O-360, you would spend a fortune getting it approved.
> No virus found in this incoming message.
http://wiki.matronics.com
KCHD |
oldbob(at)BeechOwners.com Guest
Posted: Wed Aug 02, 2006 5:29 am Post subject: STC for standby generator on a |
Good Morning Kelly,
Are you sure about having to get "approval" to remove
that vacuum pump? I agree that you need approval to
add the standby alternator, (Though B&C may already
have it STC'd) but on the Bonanza, all that is
required is a log book entry that the pump and
associated plumbing was removed.
You might check the Mooney TCDSs to see if the pump is
listed as required or as optional equipment. If it is
not listed as required, get rid of it!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Stearman N3977A
--- Kelly McMullen <kellym(at)aviating.com> wrote:
system.
L. Nuckolls, III"
aircraft to get the
I'm certain that by
on older airplanes
perhaps the limited
first to ask,
> Bob . . .
N6030X
would I be paying
>> Dave Morris
McMullen
early Mooneys. The
> Bob . . .
| Quote: | > < What is so wonderful about scientific
truth...is that >
there can be >
fraternity of >
rests >
> < with experiment.
> < --Lawrence M.
Krauss >
Kellym
Posted: Wed Aug 02, 2006 10:50 am Post subject: STC for standby generator on a |
Bob, I couldn't tell you about the pre-1965 models, but on the '65-75
models it was required to operate the wing leveler, which was
standard, not optional, equipment. I suspect that it would be
questionable on the later 4-cyl Lycoming models because they were all
sold as IFR certified, with standard IFR equipment.
AFAIK, the Porsche powered model was the 1st Mooney to be all
electric, and probably the only model until the GX series with G1000
panels came out.
I still think it is a whole lot simpler to install an electric AI like
Sporty's, either as additional instrument, or as replacement for T&B,
than to screw with changing whole systems in a certified plane. Both
easier and cheaper.
Quoting OldBob Siegfried <oldbob(at)BeechOwners.com>:
<oldbob(at)beechowners.com>
Good Morning Kelly,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Stearman N3977A
> system.
> L. Nuckolls, III"
> aircraft to get the
> I'm certain that by
> on older airplanes
> perhaps the limited
> first to ask,
> > Bob . . .
> N6030X
> would I be paying
> >> Dave Morris
> McMullen
> early Mooneys. The
> > Bob . . .
> truth...is that >
> there can be >
> fraternity of >
> rests >
> > < with experiment.
> > < --Lawrence M.
> Krauss >
> browse
> Subscriptions page,
> FAQ,
> Admin.
KCHD |
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Wed Aug 02, 2006 11:17 am Post subject: STC for standby generator on a |
Would it be possible to just put in an electric AI and DG, and leave the
vacuum system in place, but not connected to anything?
N6030X(at)DaveMorris.com Guest
Posted: Wed Aug 02, 2006 11:43 am Post subject: STC for standby generator on a |
The downside to that is that you've got an all-electric airplane
then, with no vacuum backup, and only the battery to save you in the
event of an alternator failure. That's what I was hoping the backup
alternator would solve. Although maybe a second battery would be
easier to manage.
Dave Morris
ornerycuss2001(at)yahoo.c Guest
Posted: Wed Aug 02, 2006 12:55 pm Post subject: STC for standby generator on a |
Here's a link to the FAA's site for Type Certificate Data Sheets if anyone wants to do the research:
http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGMAKEMODEL.NSF/MAINFRAMENETSCAPE4X?OpenFrameSet
Greg
Dave N6030X <N6030X(at)DaveMorris.com> wrote:[quote] --> AeroElectric-List message posted by: Dave N6030X
easier to manage.
Dave Morris
[quote]--> AeroElectric-List message posted by: "Bill Denton"
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Wed Aug 02, 2006 1:32 pm Post subject: STC for standby generator on a |
On Aug 2, 2006, at 3:39 PM, Dave N6030X wrote:
the event of an alternator failure. That's what I was hoping the
backup alternator would solve. Although maybe a second battery
would be easier to manage.
The problem with vacuum power is that, if you lose your vacuum
source, all your vacuum-driven devices go away. Providing backup
power for your vacuum devices is a challenge. Also, your vacuum
system has several single-points of failure, among them:
1. vacuum pump,
2. vacuum lines,
3. vacuum regulator.
If any of those fail you lose your vacuum system.
If you have a properly designed electrical system you will have no
single point of failure for electrical power. If the alternator fails
your battery will continue to power your instruments. If you are
worried about that, install a dynamo or alternator on the vacuum pump
pad and now you have three power sources for your gyro instruments,
i.e. alternator, backup alternator, and then battery if both
alternators fail. And not only will that power your gyros but it will
provide backup power for other electrical devices, like navigational
instruments and radios.
And as for wiring, if your vacuum hose to one gyro fails you will
lose the vacuum to the other gyro(s). If the wire fails to one gyro,
the others run just fine.
We could go on and on here but there is just no way to make a system
that uses vacuum-powered gyros as reliable as a system that uses
electrically-powered gyros.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
brian
Posted: Wed Aug 02, 2006 1:36 pm Post subject: STC for standby generator on a |
On Aug 2, 2006, at 3:13 PM, Bill Denton wrote:
<bdenton(at)bdenton.com>
leave the
We can talk about the details but let's look at the spirit of the
thing. The FAA wants to see that there are two power sources for the
gyros so that no single failure will cause all the gyros to stop
working at once.
Since it is a type certified airplane, you are going to want FAA buy-
in. They are going to want to see the following:
1. no single point of failure;
2. a second source of power (battery probably OK, second alternator
better);
3. justification for a claim that a failure to one gyro will not
affect the others.
Keep that in mind when crafting a system to put in your TC aircraft.
Bill Denton
Posted: Wed Aug 02, 2006 1:55 pm Post subject: STC for standby generator on a |
I was thinking more of staying in compliance with the Type Certificate...
Posted: Wed Aug 02, 2006 2:24 pm Post subject: STC for standby generator on a |
Good Evening Bill, Brian and All,
I note that Brian has stated that the FAA would like
us to have redundancy of power for our instruments
used for inflight reference.
It is true that they are requiring redundancy for
newly certificated flying machines and for anyone who
wants to replace a turn coordinator or turn and bank
with an attitude gyro, but the basic FARs do NOT
require that we have any redundancy at all for our
older certificated flying machines.
It is up to us to decide just how much risk we wish to
take.
We can still fly with only one engine, one alternator,
one radio, one pilot and one power source for our
instruments!
The choice of redundant systems is up to us.
I think that is the way it should be and I do not feel
that the FAA's recent foray into mandating redundancy
has improved safety at all.
Once they designate what we must have for redundancy
of flight instruments, how much longer will it be
before they try to tell us under what conditions we
can fly single pilot? How long will it take them to
require an autopilot? When will they decide we need
two engines at night or over water?
All of those ideas have merit, but statistics do not
support the need.
Back to the FAA ideas of redundancy.
By the time they decide something meets their
interpretation of redundancy, there are many forms of
redundancy available that are far superior to the
devices finally approved by the FEDs. The beauty of
the way it was is that we had almost as much
flexibility to evaluate risk for our certificated
airplanes as do those folks who build and fly OBAM
aircraft.
Lets not add difficulties beyond those that the FAA
has already foisted upon us.
Happy Skies,
Old Bob
Stearman N3977A
--- Bill Denton <bdenton(at)bdenton.com> wrote:
Denton" <bdenton(at)bdenton.com>
Posted: Wed Aug 02, 2006 2:41 pm Post subject: STC for standby generator on a |
Thanks to all of you who have commented, some
also privately. I'm just a rebel who spends most of his time outside the box.
Dave Morris
At 04:35 PM 8/2/2006, you wrote:
>leave the
working at once.
going to want FAA buy- in. They are going to want to see the following:
better);
affect the others.
brian
Posted: Wed Aug 02, 2006 2:43 pm Post subject: STC for standby generator on a |
On Aug 2, 2006, at 5:52 PM, Bill Denton wrote:
Certificate...
Old Bob made a good point. Many of these aircraft were certified
without gyro instruments and the regs covering IFR instrumentation
are pretty loose. You should be able to drop in an electric AI.
But the points I made were correct. The FAA (and you if you aren't
stupid) want to see that there is no way that all your gyros can fail
at the same time. They want to not have to bother with yet more
"wrecked airplane, dead pilot, dead passengers, new lawsuit" paperwork.
So rather than argue the number of angels needed to keep your vacuum
pump running, talk to the FSDO and get started on a 337 for a well-
designed electrical source for your all-electric gyros. There are
still some not-stupids at the FAA who will help you do what you want.
So just remember, the goal is a system that is more reliable and will
be less likely to fail when you need it most. And if it does fail, it
fails softly, i.e. without the wholesale loss of big chunks of your
gyro panel.
So don't argue, think. This is not rocket science. This is common
sense. If you can really show the FAA guys (the smart ones - work on
finding the smart ones) that you have a better way, they will
probably go along with you and grant their blessings.
And a Mooney that has the old vacuum-powered wing leveler will
probably have to keep that vacuum-powered wing leveler as it was
specifically part of the TC. But that doesn't preclude making things
better for everything else.
Heck, my 1960 Comanche has an e-bus with a second battery. There were
no hassles getting that approved. Work on it.
Kellym
Posted: Wed Aug 02, 2006 3:00 pm Post subject: STC for standby generator on a |
You ASSUME two totally separate electrical systems available to each
gyro, which is a physical impossiblity, and that the battery will be
available if that fails. Each master switch you have is a single point
of failure, as well as the relay it operates. Any place one system
interconnects with the other is also a single point of failure that
can take out both systems. Smoke from the electrical system will have
you killing all electrics. Now where are you??? Turn system back on
and risk cockpit fire? I don't think so. Truly independent...AI on one
system, DG and TC on the other? You still lose pitch if that side fails.
Vacuum regulators fail about 0.5 times in the life of an airframe.
About the most reliable mechanical device on the airframe. Hoses, if
they are replaced with the pump never fail. Pumps are your only real
point of failure. If you equip the aircraft with one vacuum and one
electric AI you will have far better redundancy and reliability than
all electric.
Quoting Brian Lloyd <brian-yak(at)lloyd.com>:
| Quote: | We could go on and on here but there is just no way to make a system
KCHD |
Bill Denton
Posted: Wed Aug 02, 2006 3:20 pm Post subject: STC for standby generator on a |
Again allow me to point out that the Sporty's and the Mid-Continent "backup" attitude indicators have an internal battery backup; they can operate without any ship's power whatsoever.
And while they were originally designed for backup purposes, couldn't they also be used in place of the primary attitude indicators in cases where an electric unit is permitted?
brian
Posted: Wed Aug 02, 2006 3:51 pm Post subject: STC for standby generator on a |
On Aug 2, 2006, at 6:58 PM, Kelly McMullen wrote:
each gyro, which is a physical impossiblity, and that the battery
will be available if that fails. Each master switch you have is a
single point of failure, as well as the relay it operates. Any
place one system interconnects with the other is also a single
point of failure that can take out both systems. Smoke from the
electrical system will have you killing all electrics. Now where
are you??? Turn system back on and risk cockpit fire? I don't think
so. Truly independent...AI on one system, DG and TC on the other?
if they are replaced with the pump never fail. Pumps are your only
real point of failure. If you equip the aircraft with one vacuum
and one electric AI you will have far better redundancy and
reliability than all electric.
I see we have reached an impasse. Clearly you have not worked with
electrical systems nor have you read Bob's book.
But I will address your point about switches. Yes if the battery
master switch fails and/or the battery contactor fails, you lose the
main bus. That is why there is a second path from the battery to your
e-bus which drives your gyros. You can feed the e-bus from either the
main bus or the battery directly. You would now need a chain of
failures to cause your gyros to go away.
The e-bus is simplicity itself. In my Comanche it started out as an
avionics bus but became the e-bus by virtue of adding a second
battery, a separate charging path from primary battery to backup
battery, a separate path from backup battery to e-bus, and separate
circuits from e-bus to each load, each with its own current limiter.
It even has a backup switch to connect to the e-bus to the main bus
should the main switch fail. (I didn't want to add that but the FAA
wanted it and it was cheaper and faster to add it than to argue.
What's the cost of one switch and two wires.) A failure of a single
circuit causes that current limiter to open and protect the wiring
for that circuit without taking out everything else. The only common
point is the e-bus itself and that was just a piece of bus bar. I
trust a piece of bus bar a lot more than I trust a vacuum pump.
As a suggestion, perhaps you ought to look at the current crop of
airlines plying our skies. I think that, no matter how hard you look,
you won't find a single vacuum pump or air-driven gyro in the lot.
That might suggest something to you.
But you are sold on having a vacuum pump. More power to you. I have
owned many, many airplanes and my experience is that the vacuum pump
and its related components were less reliable than electrical
systems. That is my experience. When I finish restoring my Nanchang
CJ6A there will be no air-powered gyros in it. When I build my F1
Rocket there will be no vacuum pumps and no air-powered gyros. I am
willing to bet my life on an all-electric panel in hard IFR. You
should do what makes you most comfortable.
