MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Wed Aug 02, 2006 7:33 am Post subject: Flaps uneven- Gas cap |
David I noticed fabric rivets in your ailerons. I don't see any reference to
that in my plans. (2003) We have the same engine exhast but I have flaperons
and no prop extention.
Also does anyone know if I to will need aileron counter balance also. Kit
came without.
I have two new 5 gal. TNK plastic gas cans with caps. They want to be
together. Make an offer Ed.
Vic
MKIIIX 912
Maine
_________________ MKIIIX040
912UL |
jindoguy(at)gmail.com Guest
Posted: Wed Aug 02, 2006 9:20 am Post subject: Flaps uneven- Gas cap |
Vic, My MkIII got aileron flutter at about 70 mph without the aileron counterbalances. I took it out to 110 mph after I put them on and the flutter was gone. Up to you, but they're pretty cheap insurance and only take a couple of hours to retrofit.
Rick
On 8/2/06, Vic Peters <vicsvinyl(at)verizon.net (vicsvinyl(at)verizon.net)> wrote: | Quote: | --> Kolb-List message posted by: "Vic Peters" <vicsvinyl(at)verizon.net (vicsvinyl(at)verizon.net)>
came without.
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
when you live at the airport.
APilot(at)webtv.net Guest
Posted: Wed Aug 02, 2006 9:40 am Post subject: Flaps uneven- Gas cap |
What do some Mark III pilot use for fuel tanks? I was thinking of a
fuel cell. Any suggestions? Also, do you have an idea of how long the
plastic tanks will last?
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Wed Aug 02, 2006 5:08 pm Post subject: Re: Flaps uneven- Gas cap |
Per the "how long do they last", On the bottom of almost all blow molded products is a molded in date stamp of some form. Even if the manufacturer's name is not apparent, you should at least see a year and month in small boxes. Mine on the Firestar was produced in June of 1990. It has seen better days. However if you use the proper epoxy for a small crack or hole as a temp fix, it will bond and hold. THe key is finding a epoxy that will attack the poly material, adhering while not breaking down from fuel additives or the different gas configurations.
Ohio Ralph
