DAquaNut(at)aol.com Guest
Posted: Tue Aug 01, 2006 10:16 pm Post subject: Gas cap |
Anyone Know of a source for the gas0 cap that fits the standard 5- gallon tank other than TNK?
0 Ed
John Cooley
Joined: 10 Jan 2006 Posts: 17 Location: Lucedale, Ms.
Posted: Tue Aug 01, 2006 10:32 pm Post subject: Gas cap |
Hi Ed,
Would you be interested in a used one or two? I have two old tanks that came out of the Twinstar I sold that has the standard cap with screwed in plug and small vent hole.
Later,
John Cooley
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of DAquaNut(at)aol.com
Sent: Wednesday, August 02, 2006 1:05 AM
Subject: Re: Re: Gas cap
Anyone Know of a source for the gas cap that fits the standard 5- gallon tank other than TNK?
Ed
_________________ Be Safe,
John Cooley |
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Wed Aug 02, 2006 4:55 pm Post subject: Re: Gas cap |
John, If Ed isn't, I sure would be, including the gas tanks. how much would you want for them? Mine is origional 1990 production as dated by mfgr on molded bottom.
I epoxied a small crack near the right rear corner up near the 5 gal. level. It appears to hold well but I have not been able to find a 10 x 10 x 14 inch heavy walled poly tank as used in the Forestar.
Ohio Ralph
John Cooley
Posted: Thu Aug 03, 2006 3:36 am Post subject: Gas cap |
Hi Ralph/Gang,
I know one of the tanks is busted. The other may be ok, I'd just have to
check. They came out of a Twinstar and have holes in the bottom for the fuel
lines.
I would give them to whoever wants them. I would be willing to just ship the
caps to Ed or whoever if Ed doesn’t want them. If someone wanted the tank,
if it's any good, I might ask for some shipping cost.
Later,
John Cooley
John Cooley |
Ralph Hoover
Posted: Thu Aug 03, 2006 6:56 am Post subject: Re: Gas cap |
John, Sounds like the aged problem I have also, if one of the tanks is busted. Once they breakdown, there they are. That UV lasts a long time but on mine having the upper area exposed for 16 years does take it's toll.
I have an aduquate cap right now. It's not in bad shape. I have found some other tanks, even a 10 x 10 x 24 that would do the job, but the manufacturer doesn't make it with the proper "skin" coating and therefore recoments that it not be used for lawn mower gas tank (wink, wink). I'm not sure how long a life it would have. At $74.00 plus shipping and fill hole kit, I'm not about to experiment.
Thanks for your offer,
Ohio Ralph
