AV8ORJWC
Posted: Thu Aug 03, 2006 9:00 am Post subject: [LML] Re: 51% rule discussion |
Here is more on the sensitive subject.
John Cox
Do not Archive
On Thu, 03 Aug 2006 14:41:09 -0000
"rob_schalk" <schalkr(at)fuse.net> wrote:
Some discussion recently about the 51% rule, this FAA order (hopefully
links work below) is more geared toward commercial assistance, but the
51% rule as well as other experimental rules will probably see some
changes coming about (possibly more good than bad); or at least more
oversight by the FAA. Our local FSDO, as well as others, are staffing
up their offices to accommodate the experimental market.
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0
/efe4866385f304a0862571b800535d7a/$FILE/Order1110.143.pdf
(or)
/EFE4866385F304A0862571B800535D7A?OpenDocument
Robert Schalk
Fleet Maintenance Airworthiness Inspector
Executive Jet(r) Management
-A Netjets Company
513-979-6793 Office
513-324-1531 Cell
513-979-6677 Fax
For archives and unsub http://mail.lancaironline.net/lists/lml/
