coop85(at)bellsouth.net Guest
Posted: Thu Aug 03, 2006 2:43 pm Post subject: Window overspray |
Some time ago there were some great responses on how to remove overspray
from the windows. At the time I was scoffing the idea and didn't save what
would now be some extremely valuable information. Any reposting, or at
least the proper search words (no luck on my part), would be deeply
appreciated.
Marcus
40286 - engine running, dangerously close to inspection time! If I can just
get all the Gucci panels programmed I'll be in business.
jesse(at)itecusa.org Guest
Posted: Thu Aug 03, 2006 3:16 pm Post subject: Window overspray |
I have it on fairly good authority that acetone can remove overspray from
the windows without leaving any marks or damaging the plexi. Other than
that, MicroMesh from Spruce for PolyCarb should do the trick, but is very
labor-intensive.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Tim(at)MyRV10.com Guest
Posted: Thu Aug 03, 2006 6:35 pm Post subject: Window overspray |
I think I was the one, Marcus, who put out that post you're thinking
of. I've now had the occasion on 2 planes, at 2 times, to use
a product called "scratch off".
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1154658472-328-402&browse=airframe&product=scratch-off
http://www.aircraftspruce.com/catalog/cspages/menus/ncs18.php
I even took the time to swing by and thank them again at OSH because
it truly is a fantastic kit. I had overspray and scratching on
an old plane since I bought it, and it cleaned up the windows
great. Then, I got paint overspray under the tape on my -10 and
it took all of that off and polished them up good. You won't
be disappointed if you use as directed. Very nice, and doesn't
really take a lot of work or time. I only used I think the
2 finest grits on the -10, or worst case I used 3 of the 4.
You just use an electric drill and it takes almost no time.
[quote] --
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Tue Aug 15, 2006 6:48 pm Post subject: Window overspray |
Marcus,
Read the reply from John Cox in this thread before you use any solvents:
http://forums.matronics.com/viewtopic.php?t=5024
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
Vern(at)teclabsinc.com Guest
Posted: Tue Aug 22, 2006 1:54 pm Post subject: Window overspray |
Hi,
A product I had recommended to me by an A&P was DuPont's PrepSol ("5
Star" brand has the similar product called Wax and Grease Remover.) It
should be available in the local car paint shop in quarts and gallons. I
used it on a Cessna to clean some overspray off and it worked well
without harming the Plexiglas. I have not used it on Van's windows so if
you go this way try it on a scrap first.
Vern (#40324 wings)
[quote] --
KiloPapa
Posted: Tue Aug 22, 2006 8:04 pm Post subject: Window overspray |
Kevin
40494
tail/empennage
40494
do not archive |
