Posted: Fri Aug 04, 2006 4:46 pm Post subject: Coolant Recovery Bottle and Mount |
Changed the subject line to reflect what we are talking about.
Forgot to mention, I used a couple 582 radiator shock mounts which
have 6mm studs on them, to screw into the rear of the gear box. Then
mounted my recovery bottle and mount on the two shock mounts.
Was it necessary to use the shock mounts? Not sure. But since I had
them, I used them. Also acts as a thermal barrier between gear box
and bottle.
Take care,
_________________ John Hauck
Titus, Alabama |
MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Sat Aug 05, 2006 6:20 am Post subject: Coolant Recovery Bottle and Mount |
To John H.&C.
Thats the kind of help that makes this list great! Thanks
Personally I love those large files, that way I can really check Johns
crappy workmanship. ( Ha, Ha, Ha)
Only problem is I already bought the stock Rotax gold plated platinum
overflow and it won't fit.
I was going to use those same screw holes in the gearbox for a bracket
to support the bottom of that type of exhast. I noticed a lot of wear at the
junction of muffler to pipes (used system low time).
Any comments on this from anyone?
Vic
MKIIIX 912UL
Maine
_________________ MKIIIX040
912UL |
