MichaelGibbs(at)cox.net Guest
Posted: Wed Aug 02, 2006 12:23 am Post subject: Flaps. |
Michel sez:
| Quote: | I have the flat bottomed flaperons but I guess, in you model IV, you
had the symetrical ones, isn't it?
Yes, I had the symmetrical flaperons.
| Quote: | But if I can't pull the nose down without gaining speed, I don't see
the point because - and as your instructor said - don't side slip
with the flaps on. So, it's either one or the other, but not both.
Do you agree?
Not necessarily. Cessna prohibits slips with flaps extended in the
Cessna 172 because the flaps interfere with airflow over the tail
surfaces making pitch control difficult. There is no such
prohibition in my Piper Arrow. I can put the flaps down and slip to
my heart's content. I can't remember if I tried to slip the Kitfox
with flaps extended.
Given the common use of flaperons for pitch trim in the pre-Model IV
'foxes, their application as traditional flaps may be less useful.
And, of course, the Model IV and later use a different flaperon mixer
that provides differential movement (aileron down travel is less than
up travel).
Mike G.
N728KF
janderson412(at)hotmail.c Guest
Posted: Wed Aug 02, 2006 1:38 am Post subject: Flaps. |
The Cessna 188, I've slipped many times with flap and never notice any loss of tail/elevator authority either, it is a low wing of course..
Subject: Re: Flaps.
Date: Wed, 2 Aug 2006 01:21:23 -0700
--> Kitfox-List message posted by: Michael Gibbs <MichaelGibbs(at)cox.net>
Michel sez:
Do you agree?
Michel
Posted: Wed Aug 02, 2006 12:45 pm Post subject: Flaps. |
On Aug 2, 2006, at 10:21 AM, Michael Gibbs wrote:
| Quote: | Given the common use of flaperons for pitch trim in the pre-Model IV
Ok, Mike. I will try to increase the maximum angle of my flaps to say,
15 degrees and I'll let you know. BTW, this evening, I flew with an
American from Austin, Texas. He has been flying since 1965 and owns now
a Citabria. It was a short flight because we were surrounded by Cb and
between thunder storms. But it was great and, needless to say, he flew
the Kitfox like a pro.
Cheers,
Michel
manceliller(at)hotmail.co Guest
Posted: Wed Aug 02, 2006 7:33 pm Post subject: Flaps. |
hey people i have the 3 blade ground adjustable prop,my pitch on each blade is good ,but i guess i dont understand how to correct the tracking, i can rotate each blade down,and scribe it on a table ,they are the same angle,but a little forward and back of each other.HELP
LANCE
Subject: Re: Flaps.
[quote]--> Kitfox-List message posted by: Michael Gibbs
Michel sez:
>you had the symetrical ones, isn't it?
>see the point because - and as your instructor said - don't side
>slip with the flaps on. So, it's either one or the other, but not
>both. Do you agree?
mixer that provides differential movement (aileron down travel is
less than up travel).
Mike
debrun26(at)juno.com Guest
Posted: Sat Aug 05, 2006 3:20 pm Post subject: Flaps. |
Hi All, I'm looking at buying a KF5 and would like to know what the usual empty weight is with a NSI 100hp engine. The plane has it's tail # but no cetified weight. Also, is the gross wt 1550 lbs? I've only seen a model 4 and would like to know if the baggage area is larger in the KF5. Also how do I find out what the CG range is? Thanks much, Layne
________________________________________________________________________
Try Juno Platinum for Free! Then, only $9.95/month!
Visit http://www.juno.com/value to sign up today!
Posted: Sat Aug 05, 2006 4:52 pm Post subject: Flaps. |
Is it already signed off and flying? Or not certified
yet and so no certified weight?
Most should weigh 870-950 empty. Gear type and
add-ons make the biggest difference.
If I remember correctly, the early -5's were 1400
gross? 1550 gross is standard for the later -5's, but
you can set your own gross as a builder.
My FAA inspector recommended I set my gross above
anything I would ever use. Then license and insure it
to that so you are never at risk for going over and
losing your license or insurance coverage. Politics!
Fly under the real gross and if you go a few pounds
over, it is not a violation. (Bad that we should fear
violations more than performance)
Yes the baggage area is larger for -5's and beyond.
Weight limit dictated by CG with 150 lbs tops.
The CG is in the builder's manual. Don't have mine
here, or I could pass it on.
Kurt S. S-5/NSI turbo
Only 437 e-mails to catch up on since I went on
vacation.....
--- "debrun26(at)juno.com" <debrun26(at)juno.com> wrote:
| Quote: | Hi All, I'm looking at buying a KF5 and would
Layne
morid(at)northland.lib.mi Guest
Posted: Sun Aug 06, 2006 10:23 am Post subject: Flaps. |
Layne, my S5 with NSI engine and prop weighed0 in at 870. The CAP prop weighed about 23 lbs all by itself. I could0 have built it lighter, but wanted to have lots of goodies for cross0 country. If I were to do it over I probably could easily eliminate 300 lbs. The gross weight goes by serial number so perhaps somebody can give0 you the breakdown on that.
Deke
