Re-tip-up
alfolavf(at)online.no
PostPosted: Sat Aug 05, 2006 10:40 pm    Post subject: Re-tip-up Reply with quote
Hi fellow builders.
I saw a builder who had solved the problem with rain entering behind the panel when you open the canopy:
He had used waterproof lightweight fabric (almost like the fabric a spinaker for a sailboat is made of) and he had mounted this with velcro across and over the avionics bay, i.e over the backside of the panel.
The avionis bay was completely protected underneath the cover and the water poured off to the sides, flowing along the top of fabric and down to the ground.
I'll post a couple of pics on the photoshare-section, but I think it'll take a few days before it's published.
Best regards Alf Olav Frog /Norway
sa300(at)uniserve.com
PostPosted: Sun Aug 06, 2006 7:04 am    Post subject: Re-tip-up Reply with quote
I put a small eves trough along the top of the sub-panel and that cured the problem of water on the avionics.
Alf Olav Frog wrote:
Hi fellow builders.
