Tablet & Laptop PC Use in Aircraft
jschroeder(at)perigee.net
PostPosted: Sun Aug 06, 2006 12:06 pm    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
Brian -
I have a Motion 1400 Tablet and plan to fly above the company's max
altitude of 10,000 ft. Do you have a source for these boxes?
John
On Sun, 6 Aug 2006 15:27:03 -0400, Brian Lloyd <brian-yak(at)lloyd.com> wrote:
Put the drive(s) in a sealed box that will hold sea-level pressure. A
USB or firewire interface will ensure youdon't have too many wires to
route out of your box.
Brian Lloyd
N6030X(at)DaveMorris.com
PostPosted: Sun Aug 06, 2006 12:19 pm    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
I'm trying to make a USB flash drive work for everything on a TC10000
single-board computer. So far, it's been difficult to get the OS to
boot from a flash drive, but if we can get that working, you won't
need a conventional disk drive at all.
Dave Morris
At 03:05 PM 8/6/2006, you wrote:
<jschroeder(at)perigee.net>
Brian -
John
> Brian Lloyd
PostPosted: Sun Aug 06, 2006 12:44 pm    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
Dave -
What software and OS are you using? Mine is Windows XP Tablet and Voyager
- both are the all-time memory hogs.
John Schroeder
On Sun, 06 Aug 2006 15:18:39 -0500, Dave N6030X <N6030X(at)DaveMorris.com>
PostPosted: Sun Aug 06, 2006 1:28 pm    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
There are something like 500 guys on a Yahoo eGroup
http://groups.yahoo.com/group/MyGlassCockpit/ that started in 2001
discussing ideas for open source EFIS and other glass cockpit
instruments. We sort of let things go recently, but the archives
there have a lot of interesting stuff.
I've tried Win98 and WinXP. I'm sure there's a way to make either a
CompactFlash or USB Jumpdrive based system with no moving parts with
the tiny Epia computers, but have not gotten it to work yet. The
Fujitsu 1200 and 2300 Stylistic tablet computer radiated too much
into the aircraft band to be usable.
Dave Morris
Dave -
John Schroeder
brian
PostPosted: Sun Aug 06, 2006 2:05 pm    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
Brian -
I think that Pomona has machined boxes with gaskets that may be sealed.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
PostPosted: Sun Aug 06, 2006 2:10 pm    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
Dave -
So far, the Motion Tablet does not radiate in any way that I can see in a
C172. It might be a different story in the Lancair ES when we start
flying. I have an article from a magazine on how to make a thumb drive for
booting on any XP computer. I might get some time to see if I can make it
work on a 2 gb drive. I have two USB ports and with two 2 gb drives it may
work - if I can slim down Windows XP & Voyager. Voyager need access to the
internet for planning, but I can do that on the internal hard drive,
transfer the file to the thumb drive and fly it that way. Any
ideas/thoughts would help.
John Schroeder
On Sun, 06 Aug 2006 16:25:30 -0500, Dave N6030X <N6030X(at)DaveMorris.com>
instruments. We sort of let things go recently, but the archives there
CompactFlash or USB Jumpdrive based system with no moving parts with the
tiny Epia computers, but have not gotten it to work yet. The Fujitsu
1200 and 2300 Stylistic tablet computer radiated too much into the
Dave Morris
bicyclop(at)pacbell.net
PostPosted: Sun Aug 06, 2006 4:40 pm    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
John,
How's that Motion in daylight? Have you used Voyager in flight? How is
it?
Pax,
Ed Holyoke
LloydDR(at)wernerco.com
PostPosted: Mon Aug 07, 2006 8:01 am    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
Use an underwater photography box and install a valve to pump up the pressure to the required amount. The camera boxes seal well, and should be rated to several hundred feet, which should allow for significant pressure, but in the reverse direction, so testing will need to be done.
Dan
PostPosted: Mon Aug 07, 2006 8:36 am    Post subject: Tablet & Laptop PC Use in Aircraft Reply with quote
U/W photography equipment is designed to take
high pressure on the outside. They use O-rings,
and the pressure differential acts to seat the
o-ring better the higher the pressure. I imagine
if the high pressure were on the inside instead,
they might not work as well, unless you could
make the exterior clamps really tight.
You might also try a Pelican case. Those already
have a rotating valve to equalize or seal off pressure differentials.
Dave Morris
At 10:59 AM 8/7/2006, you wrote:
Daniel R." <LloydDR(at)wernerco.com>
Dan
n395v
PostPosted: Tue Aug 08, 2006 10:17 am    Post subject: Re: Tablet & Laptop PC Use in Aircraft Reply with quote
For several years I have played with several computers and computer based programs in the cockpit to replace charts, approach plates, portable GPS and in cockpit weather.
There are some truths that cannot be violated. Unless you bluetooth and have a really big battery there will be too many wires no matter what you do. Blue tooth presents its own problems and does not totally eliminate wiring.
No current tablet/portable has excellent sunlight readability.
All the programs are resource hogs and often move slowly when you badly need fast.
They are windows based and prone to crash at the worst possible moment.
If you frequently go high ( . (low teens and above)you will gork the drive. Ask me how I know.
I have used Flitesoft, Vista, Truemap, Chartcase on HP TC 1100s, Motion M1300, and Sony U750.
While all are great programs and great machines they all suffer from the aformentioned problems.
If you put it in a pressurised case you still have the other problems plus a bulky case and more wiring and expense. Solid state hard drives are expensive if you want to run your computer as a computer in addition to it's flight duties.
My need was for weather, moving map, charts and plates. After all the above gyrations I settled on a Flight Cheetah 210 with a solid state drive.
It is a windows 2000 based unit that is skinnied down to only run the Truemap Software. It is fast and reliable and immune to altitude. It is readable in direct sunlight. It still has lots of wires but since it only runs aviation programs I hardwired it into the plane.
An alternative would be a 396/496 with a card reader tablet for plates.
Building a computer system into a pressurised case wil in the end cost as musc as a dedicated unit in the plane plus your notebook. It will just not work as well an will be a real PITA to set up and remove.
Milt
