TUBEFIT
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List
Hopperdhh(at)aol.com
PostPosted: Mon Aug 07, 2006 5:54 am    Post subject: TUBEFIT Reply with quote
Fellow tailwind enthusiasts:
I have written a template calculating program which is posted at
metalgeek.com. There is also a derivation of the math involved. Best of all it is
completely free. Scroll down about 1/3 of the way and click on "Dan Hopper's
TUBEFIT Program" on the left side of the screen. Its a very short and simple
program that you can download and run offline.
This program was originally written for building race car roll cages, but it
should apply very well to building metal tube fuselages.
There are a number of neat features about the program. You should be able
to calculate the length and angles (center-to-center on the longerons) of the
tube needed from your plans. You can then use the templates that you print
out to cut a piece of tubing that is exactly right, on both ends, the first
try. You can also use it to fit more than one tube at a time, such as occurs
at a cluster.
This program has been a hobby type project of mine for a number of years.
I'd like to see someone put it to good use.
Dan Hopper
hopperdhh(at)aol.com
Walton, IN
- The Matronics Tailwind-List Email Forum -
http://www.matronics.com/Navigator?Tailwind-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List All times are GMT - 8 Hours
