spudnuts
Posted: Mon Aug 07, 2006 5:32 am Post subject: Broken Fox |
I am thinking of buying a used series V that was ground looped (it ended up inverted on a grass strip). The tail was crunched a little, the prop was broken and some fabric torn, but the repairs look pretty good from the pictures (I have not seen it in person yet). It has a fresh annual (july) I am planning on making a visit soon, any particular things I should look for? I know thats a really broad question, but any help is appreciated.
occom(at)ns.sympatico.ca Guest
Posted: Mon Aug 07, 2006 6:05 am Post subject: Broken Fox |
Yup, look for bent and dented spars, particularly the rear. It's a time
consuming repair.
smokey_bear_40220(at)yaho Guest
Posted: Mon Aug 07, 2006 6:09 am Post subject: Broken Fox |
I would do a by-the-book rigging check on it before
purchase. That would help tell you if anything was
bent that wasn't obvious.
Kurt S.
--- spudnuts <martan(at)cstone.net> wrote:
| Quote: | I am thinking of buying a used series V that was
spudnuts
Posted: Mon Aug 07, 2006 8:11 am Post subject: Re: Broken Fox |
Forgive my obvious ignorance, but what is a 'by the book' rigging check? Where do I get this book?
pulsair(at)mindspring.com Guest
Posted: Mon Aug 07, 2006 9:04 am Post subject: Broken Fox |
Look at the matrix of tubing in front of the seat for bending. Talk to the
pilot who dinged it. There is a big difference between letting it get away
from you a little and stomping on the brakes rather than a hard landing out
of control. Find out if there was a "sudden stoppage" on the engine. Good
luck! Sounds like a good project. Jeff Classic IV
spaghettiohead(at)hotmail Guest
Posted: Mon Aug 07, 2006 10:31 am Post subject: Broken Fox |
It wouldn't happen to have been ground-looped sometimes last year in
Florida, would it?
Andrew
| Quote: | From: "spudnuts" <martan(at)cstone.net>
Subject: Broken Fox
Date: Mon, 7 Aug 2006 06:32:08 -0700
http://forums.matronics.com/viewtopic.php?p=53031#53031
toolowterrain(at)gmail.co Guest
Posted: Mon Aug 07, 2006 11:30 am Post subject: Broken Fox |
Yes it was one and the same... N704LS... I was the builder but not the guy
that crashed it. I had sold it the day prior!
It wasn't a ground loop but a landing in mud followed by a nose over with a
prop strike. Ended up inverted. Poor judgment on the pilot's part for
landing on a muddy grass strip.
It was just up recently on eBay but didn't sell.
Len Shorethose
Posted: Mon Aug 07, 2006 1:37 pm Post subject: Broken Fox |
Yep - I know the err...pilot. We had been looking at Fox's at about the same
time when I found mine here and he found his down in Texas (you!) and told
me he was going to fly it to Sun N Fun...He sent me the picture the day it
happened and after calling me - I could not believe it!!
First, he punched in bad coordinates and relied solely on his GPS, and then
he saw this field w/mud in the middle-third and then he landed not short,
not long, but right into the mud and flipped her end over end!! He's a nice
guy, I've flown into his strip a few times now (he has a Super Cub now), but
poor, poor judgement on his part!
Oh well...There are those that learn the hard way
Andrew
[quote]From: "Len Shorethose" <toolowterrain(at)gmail.com>
Subject: Re: Broken Fox
Date: Mon, 7 Aug 2006 14:28:16 -0500
Len Shorethose
spudnuts
Posted: Mon Aug 07, 2006 1:49 pm Post subject: Re: Broken Fox |
Yeah, that plane is getting famous now isn't it ? ha. I am going to take a long drive and go look at it this weekend. Probably too good to be true. I don't know if thats so or if the owner just wants to get rid of it. It still has a few things wrong, cosmetic so he says, only one way to find out I guess. Len gave me some great info, talked to Cliff too (the guy that flipped it), but I figure only a hands on will tell me what I need to know. Like I said, any suggestions on what to look for appreciated. Here is the infamous pic of it:
http://www.eaa1257.org/cliff.jpg
Posted: Mon Aug 07, 2006 2:55 pm Post subject: Broken Fox |
I see some worry points in the picture:
Bent left lift and jury struts means some possible
wing damage.
An awful lot of up elevator would seem to indicate
broken flight control linkage.
Of course there is the stuff you all expected with the
engine/prop damage. But I just thought whoever gets
it should look closely for hidden damage.
Kurt S.
| Quote: | Yeah, that plane is getting famous now isn't it ?
http://forums.matronics.com/viewtopic.php?p=53189#53189
Posted: Mon Aug 07, 2006 3:10 pm Post subject: Broken Fox |
I hope that is the wash out I see on the right wing. The support struts
appear to be intact. I assume you remove the wings before you flip it? Good
luck! Jeff Classic IV
Posted: Mon Aug 07, 2006 3:17 pm Post subject: Broken Fox |
I meant by the builder's manual. The distance from
the (undamaged) tailpost to each wing tip should be
equal, the wing washout measured on a leveled plane,
the dihedrial, sweep, etc. If anything hidden got
bent, you might find it this way.
Kurt S.
| Quote: | Forgive my obvious ignorance, but what is a 'by the
7suds(at)Chartermi.net Guest
Posted: Tue Aug 08, 2006 7:12 pm Post subject: Broken Fox |
Looking at the Pic it appears the right wing strut was flexed if not bent in
the incident judging by the condition of the fairing material and the jury
strut, I would ask if it was replaced or just straightened, If straightened
I would strongly consider replacing it (hard to know what they look like
under the fairing material). You will want to inspect the heim joints at the
outboard end of all the wing strut attach points for bending / stress. I
would be looking for dented or kinked tubing anywhere on the fuselage
especially where the tail section intersects the fuselage lattice, and the
top and bottom where the main longeron stringers intersect the large cluster
weld at the base of the baggage compartment area. The aft vertical tube in
the vertical fin is square tube and kinks very easily compared to round
tube, seeing it landed on it's tail I would be looking. Ask to remove the
seat, inspection panels, baggage bag, wing tips or anything else that will
afford you a good look inside the fabric. Take an eyeball down the aft
fuselage longerons, they should have a nice symmetrical bow in 2 directions
on the bottoms and in one on the tops, either way they should be symmetrical
and even from side to side, if not I would look a little deeper. Also be
looking at the motor mount and the tubing inboard of the firewall in that
area. All can be fixed but it takes time & money, I am rebuilding a 5 that
was ground looped, I will have 1 year into it this fall. Good luck
Lloyd
