Float Flyr
Posted: Tue Aug 08, 2006 4:50 am Post subject: Kitfox III-A W&B, Preflight report |
I did up0 this X-Cell file to make flight planning a little easier... it works for0 my plane on Aerocet 1100 straight floats.
to use0 this calculator; First unprotect the sheet and change cell [B10] to the0 magnetic variation for your part of the world, [C16] and [D16] to your empty0 weight and CG. Then re-protect the sheet to avoid making input0 errors.
When you0 are ready to fly all you have to do is input the correct data, in black bold in0 cells [B4 to B12] except [B10] the excel does the rest for you.0
To0 update all the Performance data change the contents of E29 and E30 ( Launch0 location and altitude) then excel will calculate the cross wind effects and0 pressure altitude.
the0 sheet is easily changed for conventional and tri gear too.
I0 usually print one copy to staple to a flight itinerary and up load a copy0 to my PDA for reference. Note: the cell protection doesn't work on the0 PDA... The advantages of using the PDA are in case I take on more fuel or0 weight at a remote location.
Fly0 Fish, Fly Floats, Fly Safe!
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
kirkhull(at)sbcglobal.net Guest
Posted: Tue Aug 08, 2006 5:46 am Post subject: Kitfox III-A W&B, Preflight report |
Sounds like a usefull file but I did not get0 the attachment for some reason
[quote] --
Wilson(at)REinfo.org Guest
Posted: Tue Aug 08, 2006 6:53 am Post subject: Kitfox III-A W&B, Preflight report |
This info would be interesting to review, but there was no0 attachment.
Steve Wilson
Float Flyr
Posted: Wed Aug 09, 2006 4:40 am Post subject: Kitfox III-A W&B, Preflight report |
My mistake....This should get the file to0 you.
Sorry 'bout that.
Noel [quote]
 Download |
| Filename: |
KitfoxW&BFloats.xls |
24 KB |
| Downloaded: |
280 Time(s) |
Kitfox III-A
