MPJA motion detector for gear up warning
echristley(at)nc.rr.com
PostPosted: Tue Aug 08, 2006 8:47 am    Post subject: MPJA motion detector for gear up warning Reply with quote
OK, I've been bit. I bought an MPJA motor controller kit to dim lights
with, and they sent me a catalogue. The thing is full of cheap little
kits to make circuit boards to do all sorts of neat projects.
What I have in mind now is there motion detector kit. It's effective
to about 15ft. That is justs about the right distance for the gear up
warning to start screeching. What I have now is a normally open micro
push-button switch that my locking pin depresses when it's fully
seated. Another normally open push-button on the retraction handle and
in series with the first will let me light an LED on the panel when the
gear are down and locked and I push the button. (Drop gear and
verify). So, now I'm thinking a more automated system would be to
replace the normally open switch at the gear lock-pin with a normally
closed, and let it power the motion detector, which will raise a ruckuss
if it senses anything, be it another plane (I'm building a low wing) or
the ground.
Has anyone tried this? At only $15 or so, the thing is just begging to
be tried.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
