sales(at)6440autoparts.co Guest
Posted: Tue Aug 08, 2006 10:17 am Post subject: Wiring 2 radios w/o audio panel |
Got a friend that wants to install a second radio in his C150 but does
not want to install an audio panel. What kind of swicth or switches should
he use to switch between the radios to make this work ?
Randy
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Aug 08, 2006 1:32 pm Post subject: Wiring 2 radios w/o audio panel |
On Aug 8, 2006, at 2:16 PM, 6440 Auto Parts wrote:
<sales(at)6440autoparts.com>
but does not want to install an audio panel. What kind of swicth or
switches should he use to switch between the radios to make this
work ?
Does he want to use headphones, the loudspeaker, or both? Does he
want to be able to listen to both radios at the same time or does he
want to only hear the selected radio? Does he have an intercom? Once
I have that information I can answer your question.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Tue Aug 08, 2006 2:41 pm Post subject: Wiring 2 radios w/o audio panel |
Brian he wants to use headphones but no loudspeaker, he will
only use one radio at a time, and he has a 2 place in panel intercom (he
thinks it's Sigtronics but not sure without looking)
Thanks in advance Randy
brian
Posted: Tue Aug 08, 2006 3:18 pm Post subject: Wiring 2 radios w/o audio panel |
On Aug 8, 2006, at 6:39 PM, 6440 Auto Parts wrote:
will only use one radio at a time, and he has a 2 place in panel
intercom (he thinks it's Sigtronics but not sure without looking)
Hmm. If it were me I would want to be able listen to comm 2 while
using comm 1 to communicate. For example, I would want to listen to
comm 2 to hear ATIS while continuing to monitor and communicate with
ATC on comm 1.
And what about nav? Any of the radios have nav output?
bicyclop(at)pacbell.net Guest
Posted: Tue Aug 08, 2006 4:41 pm Post subject: Wiring 2 radios w/o audio panel |
Randy,
What I did was to use a DPST switch to move the mike and PTT leads (from
the intercom) between the 2 com radios. I labeled the switch XMIT and
put a Com 1 label on top and Com 2 underneath. I double check the switch
before transmitting to make sure I'm getting out on the radio I had
intended to use. If both Coms are at nearly the same frequency, I
sometimes get some weird feedback if I don't turn down the radio I'm not
transmitting on, but other than that it works fine.
I hooked the audio outputs together through 100 ohm resistors. I also
have a NAV radio hooked up the same way. Another guy I know didn't use
the resistors and it works fine for him. I use the individual volume
controls on the radios to listen to either or both. Very handy for
listening to ATIS or AWOS. I often leave Com 2 on guard or flight watch
on cross country flights and turn down if it interferes with flight
following and when entering the terminal area.
I hooked up a failsafe headset jack directly to Com 1 in case the
intercom fails. I don't know if I needed to do that, but it seemed like
a good idea at the time.
Pax,
Ed Holyoke
Posted: Wed Aug 09, 2006 6:27 am Post subject: Wiring 2 radios w/o audio panel |
Makes sense, let's set him up to listen both radio's. No NAV to be
switched.
Randy
brian
Posted: Wed Aug 09, 2006 10:29 am Post subject: Wiring 2 radios w/o audio panel |
On Aug 9, 2006, at 10:28 AM, 6440 Auto Parts wrote:
NAV to be switched.
Someone else already replied and gave you the answer I would have.
Use a DPDT switch to switch the mic and PTT output of the intercom
between com1 and com2. Take the headphone outputs from com1, com2,
nav1, and nav2 (if they exist) and route them to the intercom input
(the intercom should have a headphone level input that would
ordinarily come from the audio panel headphone output) each through a
100 ohm resistor. Now you can use the individual volume controls on
the radios to select audio source.
