gerf(at)gerf.com Guest
Posted: Wed Aug 09, 2006 2:22 pm Post subject: Looking for high quality signal level in-line connector |
I'm installing the LightSpeed Plasma II+ ignition in my RV-9.
The wiring loom from LSE comes pre-fabricated from the crank
sensor in the flywheel all the way to the DB25 that connects to
the ignition module.
I want to put a disconnect in the crank sensor cable forward of
the firewall so that if I ever have to remove the engine, I
don't have to rip up the wiring inside the panel aft of the
firewall which, is where the ignition module will be housed.
Can anyone suggest a good quality in line connector that can
serve ? It needs to have six wires, 2 of which are for the
separate shields on the two separate channels.
I guess the requirement is that the connector should be capable
of resisting the typical heat within the cowling, cable of
mechanically isolating "pin" connections from any vibration in
the cable sheathing, have good shielding capabilities (since
its a sensor cable).
Thanks in advance ...
__g__
Gerry Filby gerf(at)gerf.com
Tel: 415 203 9177
Hopperdhh(at)aol.com Guest
Posted: Wed Aug 09, 2006 7:42 pm Post subject: Looking for high quality signal level in-line connector |
In a message dated 8/9/2006 6:26:41 P.M. Eastern Daylight Time,0 gerf(at)gerf.com writes:
Can0 anyone suggest a good quality in line connector that can
serve ? It0 needs to have six wires, 2 of which are for the
separate shields on the0 two separate channels.
[/quote]
Gerry,
The DE-9 (usually called DB-9) is a good choice. Some do come0 with Teflon insulation, but I can't give you a part number. Those0 should be good for under cowl temperatures. If any of the wires carry0 significant average current, I would parallel 2 or more pins. Whatever is0 done in the DB-25 should work going thru the firewall too. FWIW I have0 used these connectors for 70 amps peak on a single pin in CD ignition systems0 with no problems. This was a prototype of an Indy car system.
Dan Hopper
RV-7A
