Cat36Fly(at)aol.com Guest
Posted: Sat Jan 07, 2006 6:03 am Post subject: Speaking of GPS |
Any opinions out there (silly question) on the best overall GPS unit for our
type flying? I like the Garmin pilot lll but they are hard to come by now.
Looking at the Garmin 96 and Lowrance 500 but have not been able to see actual
units yet. Any one using either?
wcm(at)tampabay.rr.com Guest
Posted: Sat Jan 07, 2006 6:21 am Post subject: Speaking of GPS |
Check out the Garmin 296 it pretty much does it all.
Same size as the 196 great for any type of flying in any type aircraft.
Chrsi Mallory
captainron1(at)cox.net Guest
Posted: Thu Jan 19, 2006 12:32 pm Post subject: Speaking of GPS |
I've used the Lowrance 2000 for a few months. Best value for a GPS under 1K
(by 1 dollar) great graphics and quick draw rate. I shot a few IFR
approaches with it in heavy stuff (of course having real steam gages ILS
an-all as back up). Big screen nothing but good about it.
You can add terrain avoidance features to it. It may be over kill for flying
a Kolb, but like extra HP, if you need it its there.
Ron
Arizona
dhkey(at)msn.com Guest
Posted: Thu Jan 19, 2006 1:30 pm Post subject: Speaking of GPS |
You are shooting IFR approachs in a Kolb in heavy IMC conditions? Wow that's
bold.
[quote]From: "Ron" <captainron1(at)cox.net>
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: RE: Speaking of GPS
Date: Thu, 19 Jan 2006 13:31:32 -0700
flying
Ron
Arizona
John Jung
Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
Posted: Thu Jan 19, 2006 2:36 pm Post subject: Re: Speaking of GPS |
For our type of flying, an aviation GPS is not really necessary. I use a Garmin 76, and before that the 12XL and the 45. Each was designed for Marine and recreation, and cost in the $150 range. The main thing we need is to not get lost and know how long it will take us to get to the next gas station, for fuel planning. These simpler unit do that very well. Nothing wrong with spending more money, if you really want to, or if you really teavel a lot, it just isn't necessary for the flying that most of us do.
_________________ John Jung
Firestar II N6163J
Surprise, AZ |
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Thu Jan 19, 2006 2:56 pm Post subject: Re: Speaking of GPS |
I use an old Magellan GPS with an aviation database... Unfortunately, Magellan doesn't update the database, so I cross-check it to a current chart before I rely on the airspace depiction... So far, so good...
DVD
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
flht99reh(at)netzero.net Guest
Posted: Thu Jan 19, 2006 3:33 pm Post subject: Speaking of GPS |
John, well put and thank you. I use a Garmin e-map. I was looking seriously
at the Garmin GPSMAP 172 for around $349 on the internet, new from several
sites. The screen is much larger than the e-map or 96 units and does the job
quite well for a grey shade unit. When you think about it, we as fliers
don't need the complexity of road by road guidance. As a matter of fact,
like the boating community we go "rubber band". Cookies still get laid down,
satellites still give us our position and if you have a map system, roads
and references still exist. As with my no longer produced unit, the Map
source "Roads and Recreation" include ALL airports private or otherwise. Are
they current? I don't know, but for my purposes, this unit should work
exactly like a boat in the air with a road map below that includes altitude
and airports and compass. Go figure! Now, this unit also comes with a mount,
a power cable, a waterproof case, data card capability, WAAS enabled, 3000
waypoints, 10,000 active track points, 50 routes, sends with receives and
displays positioning data with DSC-equipped VHF radio's, Tracks back with
the touch of a button, and (drum roll please) comes complete with a external
antenna!!! (P.S. Garmin, if your monitoring, please send check and new 172
unit for free to me).
I know that John H. and his travels (and they are many) suggests the Garmin
96 or above. They aren't in the budget for most mortal common man. I also
don't know if flying the way I will be flying would need such
sophistication. Maybe in time I will change my thinking but for now, most of
my flying will be within 100 mile range and the terrain, as well as altitude
would be more critical to me when I fly low. Through a mountainous region,
I'm not sure.
Ralph "the other Ralph" Hoover
Kolb Firestar KXP
gtb(at)commspeed.net Guest
Posted: Thu Jan 19, 2006 5:40 pm Post subject: Speaking of GPS |
To David Lehman;
Depending on which version of the Magellan GPS
that you are using, you may find a very good, very
current database to upload into your Magellan at:
http://home.stny.rr.com/bkw/315/
I've been using this website for a couple years &
I think this guy deserves a medal. Totally free.
And lots of choices about the data you want to
have in your GPS.
Good Luck,
George Bass
David.Lehman
Posted: Thu Jan 19, 2006 6:07 pm Post subject: Re: Speaking of GPS |
| gtb(at)commspeed.net wrote: | To David Lehman;
have in your GPS.
Good Luck,
George Bass
Do Not Archive |
Thanx George...
I do know about Brian's site and yes, he does deserve a medal... Unfortunately for me, he states; "As far as I know, my database does not fit any other Magellan receivers, such as the Skyblazer, Skystar, Skystar Plus, 330, or anything in the Meridian series." and I'm the lucky recipient of a Skystar Plus... Woe is me...
Thanx again...
DVD
JetPilot
Posted: Thu Jan 19, 2006 7:49 pm Post subject: Re: Speaking of GPS |
I would get an aviation GPS lilke the Garmin 196 , or even the 195 can be had for about 250 bucks on ebay. The advantages to these moving map GPS units is that you know where the airports are, and can also see the boundries of airspace. If you fly in new or congested areas, being able to see those airspace boundries can save you from getting into a lot of trouble
Michael A. Bigelow
Kolb MK-III Xtra, 912-S |
ElleryWeld(at)aol.com Guest
Posted: Fri Jan 20, 2006 3:52 pm Post subject: Speaking of GPS |
I use a 195 Garmin I purchased on ebay cheap just for that reason becaues I
am right on the border of an international Airport and really like to know if
I am where I should be or not Be and for cross country trips its great to know
where other airports are so If I need Fuel or just a bit of security to be
able to find another airport quick
Ellery
