		Tim(at)MyRV10.com Guest
				 Posted: Wed Aug 09, 2006 8:37 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				So that "small nosewheel shimmy" I've mentioned for the past couple
 of weeks....
 Tonight I found that the old posts someone previously made on this
 subject REALLY need to be not only investigated fully, but I
 completely believe that basically EVERY RV-10 will have this
 problem if you do not plan ahead and do something about it before it
 happens to you.
 Check out this Front Axle and Fork wear write-up:
 http://www.myrv10.com/N104CD/maintenance/20060809/index.html
 If you read my write-up, you'll see that I previously even called
 Van's after someone else had the problem, trying to proactively
 "fix" the issue, even though I wasn't fully aware of exactly how
 the problem manifested itself.  What REALLY would be nice is if people
 find things like this, post some pictures and an explanation.
 A picture is worth 1000 words, and it makes it much easier to
 understand.  Had I known about this before, I would not be in this
 position today.  My front Fork is now worn with a groove, and my
 temper is lit.  Tomorrow I'll be calling again to find out if
 there is already a "fix" that is finally publicly known...and then
 I'll add it to the above page.
 Additionally, this has prompted me to stay up a little extra tonight
 and lay the groundwork for the "Maintenance Issue" section of the
 RV-10 Tips page at:
 http://www.myrv10.com/tips/index.html
 Hopefully I can get some good input from others about things that
 everyone really needs to watch for once they start flying.  Lets
 keep these planes in the air, and keep them safe.
		henkjan(at)zme.nl Guest
				 Posted: Wed Aug 09, 2006 10:51 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Hi Tim,
 I did not like the construction of the front wheel bearing and made a
 change even before putting my 10 on it's wheels because I had fear about
 exactly what happened to your front wheel.
 Van's provides two bushing made from thin wall stainless steel tubing
 for mounting at the outside of the bearings only, this will not prevent
 the bearing inner rings from rotating at the shaft, due to the heavy
 seals my inner rings were rotating at the shaft, I didn't like that,
 feared that the bushings would damage the fork, your experience proves
 that.
 Here's what I did, first I determined the distance between the bearing
 inner rings, then I made an aliminium bushing on the lathe just a little
 wider than the measured distance ( 0.1 to 0.2 mm) to give the bearings
 just that little play that they need.
 Then I made two aluminium bushings for the outside, dimensions just so
 that the total of the two outside bushings, the two bearing inner rings
 and the inside bushing are a little bit longer then the shaft, it all
 clamps together during assembly.
 I did not use the bushings supplied by Van's.
 Now it's assembled it's a very rigid construction that allows the
 bearings just to rotate at the point that they should as well as both
 seals.
 Need to say that the length of the bushing between the inner rings needs
 to be measured for every wheel separately due to tolerances of the
 wheels.
 I can disassemble it again and post pictures if you want.
 Henkjan van der Zouw
 #40355, sorry, still building.........
 -----Oorspronkelijk bericht-----
 Van: owner-rv10-list-server(at)matronics.com
 [mailto:owner-rv10-list-server(at)matronics.com] Namens Tim Olson
 Verzonden: donderdag 10 augustus 2006 6:36
 Aan: rv10-list(at)matronics.com
 Onderwerp: Serious Front Axle Maintenance Issue on the RV-10
 of weeks....
 happens to you.
 RV-10 Tips page at:
				 Posted: Thu Aug 10, 2006 3:40 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Thanks Henkjan, I only wish I had a mill handy again, but my friend
 who's I used moved away.  It sounds like you did exactly what needs
 to be done, but it's a 1-off solution.   I'd love to see photos
 of yours or anyone's assemblies that they've fixed, but I don't
 want to see you disassemble just for photos.  Thanks for the
 description of the fix though.  External photos would be nice.
 I'd love to see how big that piece is that fits next to the bearings.
 Henkjan van der Zouw wrote:
  Hi Tim,
  that.
  seals.
  wheels.
  of weeks....
  happens to you.
  RV-10 Tips page at:
		rvbuilder(at)sausen.net Guest
				 Posted: Thu Aug 10, 2006 6:19 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Man, someone didn't have their coffee yet when they designed that.
 Before even reading your write-up or looking at the pictures the first
 thing that popped into my head was a washer.  I can't believe they put
 in a SS bushing against an aluminum fork and didn't realize this would
 happen.  Duh.
   Simplest and quickest fix is exactly what you are thinking Tim.  Get a
 large SS fender washer to take up the force from the bushing and spread
 it out on the fork.  Check the usual suspects such as McMaster-Carr or
 worst case fabricate your own.
   Someone was asleep at the wheel on this one.
 Michael Sausen
 RV-10 #352 Buildus Interuptus due to moving
		Vern(at)teclabsinc.com Guest
				 Posted: Thu Aug 10, 2006 7:04 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Hi Tim,
 On my old Cessna 150 they used caps (in place of the bushing U-1023)
 that fits over the end of the shaft (U-1009). When the shaft is bolted
 to the fork the cap is held in place by the compression between the bolt
 head and the end of the shaft. I never really understood the why it was
 designed that way until looking at your pictures.
 If the shaft size is the same you may be able to pick up some used caps
 for a Cessna and use these to replace the bushings.
 Vern (#40324 wings) do not archive
		Ray.R.Doerr(at)sprint.com Guest
				 Posted: Thu Aug 10, 2006 7:28 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				I didn't have much luck with Van's on this issue as well.  My A
 & P caught this issue before I had the plane inspected and what we came
 up with is to shave .040 off the aluminum axle itself so the wheel won't
 slide side to side.  Once I did this the wheel was solidly in the middle
 in the axle with enough force on the bearings so as to create a slight
 drag on the tire when trying to turn it by hand.
 	I will check on mine tonight and report back.  I currently have
 106 hours on my plane.
 Thank You
 Ray Doerr
 40250
 N519RV (Flying)
				 Posted: Thu Aug 10, 2006 7:43 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				I have some new info on the Axle issue.   I'll post the text here,
 but I updated the web page for better readability.
 Refer to page 46-06 on your plans for visual information
 I both figured out an idea, and just got off the phone with Gus at
 Van's.  Yes, they are aware of the issue.  Apparently they did change
 the U-1023 spacers that are delivered with the kits and now instead of
 thin stainless steel, they're thick aluminum spacers, that should spin
 less easily, especially stuck against the similar aluminum, as it might
 tend to gall and stick.  He didn't know why they didn't make it an S.B.
 and send out new parts.  So, this is DEFINITELY something to address for
 anyone who hasn't yet, and these parts should be available free.  This
 isn't to say that the new fix is ideal, but certainly better than what I
 had to fly with for 100+ hours.
 The NOSE FORK ASSY part is somewhere around $160, for those who are
 interested.  I may end up doing that, depending on how paranoid I
 am....which remains to be seen.
 I am getting the new spacers via UPS ground, instead of overnight,
 because I also have one other thing that I'd like to try and accomplish.
    Personally, I think I know what needs to be done to protect those
 forks.  Today at fastenal I found 3/8" ID x 1.5" OD stainless fender
 washers and they're .050" thick.  A very similar Aviation hardware
 washer would be the AN970-6, which are only 12 cents at Van's and are
 1-5/8" diameter and .063 thick.   The idea is that if that U-1009 axle
 is cut down in length by the same thickness as 2 of those washer, you
 could then install a large-area flat washer against the fork, and that
 would prevent EVER having that fork wear.  You never want to
 unnecessarily wear an expensive part.   So, on my order is a few
 AN970-6's, -7's, and a new U-1009 axle.  The axle was about $15, and I
 ordered it so that I could allow these parts to ship UPS ground, and
 still feel good about chopping up my old U-1009 and shortening it at a
 local machine shop so I can put these washers in for the weekend.  If
 the new spacers work fine with my shortened axle and washers, then I
 will just leave it that way permanently.  Small price to pay to fix the
 issue fast....less than an hours' flight time.  The bigger problem is
 until I either get over it, or buy a new fork assy, I'm going to have
 that nagging thought of the fork damage.  There's still about .290-.300
 thickness to that fork, which should be good, especially if you hold
 that nosewheel off well on landing.
 More photos to come as things come together...
  If you read my write-up, you'll see that I previously even called Van's
  after someone else had the problem, trying to proactively "fix" the
  issue, even though I wasn't fully aware of exactly how the problem
  manifested itself.  What REALLY would be nice is if people find things
  position today.  My front Fork is now worn with a groove, and my temper
  is lit.  Tomorrow I'll be calling again to find out if there is already
  a "fix" that is finally publicly known...and then I'll add it to the
  above page.
  Additionally, this has prompted me to stay up a little extra tonight and
  lay the groundwork for the "Maintenance Issue" section of the RV-10 Tips
  page at:
  everyone really needs to watch for once they start flying.  Lets keep
		jack.lockamy(at)navy.mil Guest
				 Posted: Thu Aug 10, 2006 7:54 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Why not just drill a single hole in each side of the fork and into the spacers just forward or aft of the axle bolt?  Counter sink the hole(s) on the outside of the fork (both sides), tap the hole in the spacer for a #8 screw, insert a #8 countersunk/flush screw in each hole and you're done!  No way that spacer is gonna rotate...
 I did this on my RV-7A before this was ever even mentioned as I could see that the spacer could easily rotate and cause the fork to be 'grooved'.  So far the 'preventive measure' taken above has proved to work, took less than 10 minutes and I didn't even need a lathe...
 Jack Lockamy
 N174JL RV-7A 210 hrs
 Camarillo, CA
 www.jacklockamy.com
		mike(at)cleavelandtool.co Guest
				 Posted: Thu Aug 10, 2006 8:03 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Back in the 80's and early 90's before the full swivel tail wheel all the
 tail dragger RVs had a similar problem with the tail wheel.  We made a kit
 to fix it using the same idea as Henkjan.  I don't know if it would be
 possible to make a kit for this if the wheels vary in thickness, but if
 someone finds a solution I would be happy to make a kit of the parts.
 Mike Lauritsen
 Cleaveland Aircraft Tool
 2225 First St.
 Boone, Iowa 50036
 515-432-6794
 mike(at)cleavelandtool.com
				 Posted: Thu Aug 10, 2006 8:12 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Ray,
 You may still want to protect that fork.
 I've got you beat on hours, but only by 1 hour....107.4.
 Man, you're flying the pi$$ out of that thing!  Good job!
 Doerr, Ray R [NTK] wrote:
  	  | Quote: | 	 		   	I will check on mine tonight and report back.  I currently have
				 Posted: Thu Aug 10, 2006 8:19 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Yep, in my write-up, that's actually my proposed method of fixing
 the rotation.  I think this stuff should be done during the initial
 build, and nobody even have a problem to talk about...especially
 now that they'll have a thicker spacer, it would be easy to do.
 Lockamy, Jack L wrote:
  	  | Quote: | 	 		   Why not just drill a single hole in each side of the fork and into the
  Jack Lockamy
  Camarillo, CA
  www.jacklockamy.com
		bhughes(at)qnsi.net Guest
				 Posted: Thu Aug 10, 2006 8:54 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Mike,
 This is one problem Van's should fix and very soon. This is be a Service
 Bulletin.
 Bobby
 (40116)
		acs(at)acspropeller.com.a Guest
				 Posted: Thu Aug 10, 2006 2:28 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Tim, fantastic idea. I'm glad someone like yourself is taking the time to
 help the rest of us out with these information issues.
 Following is an extract from an email sent to me a few days ago,
 "returned the nosewheel to Matco to have it replaced with WHLNW511.25 which
 is correct for the valve stem on the tube and avoids the clearance problem
 with the supplies WHLNW501.25."
 As I'm no where near my plans at the moment I don't know if it is relevant
 to your findings, is an issue or can even help.
 I'd also suggest adding to your maint issues, the clearance issue with the
 elevator trim motor and as someone has mentioned in the last few days the
 co-pilot left rudder pedal clearance on the tunnel wall. Both could pose
 safety issues down the track.
 John 40315
		wayne.e(at)grandecom.net Guest
				 Posted: Thu Aug 10, 2006 4:37 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				I'm currently building in Justin, TX in George0 Orndorff's hangar, he's the one that makes the RV building videos and is also a0 Van's tech center, and I was talking to him about this problem, wondering if I0 needed to take some type of action on mine. His response to me on this issue was0 that this was a quite common occurrence on the RV's. He said the reason he0 believes it happens is that when the builder tightens down the bolt holding on0 the bushing and tire that they tighten it down too much. He said I should just0 tighten it down just until it's snug. Then after flying it for 5 or 10 hours0 check it and retighten it. Do this over the first 20 or 30 hours.
  I have a friend who is an A&P and also a DAR0 and I called him and ask him the same question. He agreed with George. He said0 to tighten the bolt down until a little grease comes out of the bearing and then0 back it off a little and then keep an eye on it for awhile.
  This may not be the case on Tim's plane though?0
  For what ever it's worth.
  Wayne Edgerton #40336
				 Posted: Thu Aug 10, 2006 5:39 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				They are basically correct.  However I disagree with their solution.  When you have two metals of this dissimilar of a hardness rubbing together with such a small surface area something is going to give eventually.  You need to spread that across a more substantial area.  Even my cheap wheelbarrow has this provision.
 Michael
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
  Sent: Thursday, August 10, 2006 7:36 PM
  Subject: Re: Serious Front Axle Maintenance Issue on the RV-10
 I'm currently building in Justin, TX in George Orndorff's hangar, he's the one that makes the RV building videos and is also a Van's tech center, and I was talking to him about this problem, wondering if I needed to take some type of action on mine. His response to me on this issue was that this was a quite common occurrence on the RV's. He said the reason he believes it happens is that when the builder tightens down the bolt holding on the bushing and tire that they tighten it down too much. He said I should just tighten it down just until it's snug. Then after flying it for 5 or 10 hours check it and retighten it. Do this over the first 20 or 30 hours.
 I have a friend who is an A&P and also a DAR and I called him and ask him the same question. He agreed with George. He said to tighten the bolt down until a little grease comes out of the bearing and then back it off a little and then keep an eye on it for awhile.
		toaster73(at)earthlink.ne Guest
				 Posted: Thu Aug 10, 2006 6:22 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Here is a link where one can learn a lot about0 tapered roller bearings, and the proper design intent. Granted our nosewheels0 won't see as many miles or speeds as a BMW motorcyle, but I found the article0 very informative. I don't have the nosewheel yet so I don't know exactly how it0 all goes together , but from Tim's pictures it looks pretty cheesy.
  -Chris Lucas
  #40072
  R75/5
				 Posted: Thu Aug 10, 2006 8:41 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Wayne, for what it's worth, I really don't think this will work
 that way on the RV-10.  I may be wrong, but I think you really need
 to tighten that thing well on this plane or you'll REALLY have problems.
 I'm betting that the assembly those guys are familiar with isn't the
 same thing as what we have.  If you have any looseness, you're going
 to really screw up your axle.   I just updated that page....scroll
 to the bottom to read tonights update.  I got a little long winded again
 (surprise surprise), but I explained the axle and rotation and other
 things in a bit of depth.  For you -10 builders, that page is really
 worth understanding, just so you can ponder it and know what's going
 on there....even if you come to some other conclusion.  (if you do,
 let me know...I'd love to hear it, or hear exactly what the mechanics
 are that George thinks would be better if it were looser)
 I'll post the text of tonights update here again, but you would be
 much better served to just read it on the page, and see the latest
 photos.  This is just for the archive's sake.
 Here's the link again.
 Today I stopped by a machine shop and had them take off about .115" off
 my axle, to accomodate 2 AN970-6 washers on the outer edge.  Yes, they
 are .063 each, so .126" would have been the standard, but I wanted the
 axle to be even just a little more snug than before, because any flexing
 inward will bring that valve cap closer to the fork.    As a side note,
 this from John D. today...a note someone sent him:
 which is correct for the valve stem on the tube and avoids the clearance
 problem with the supplies WHLNW501.25."
 In other words, Van's is sending out the wrong wheel for the application
 on this plane...because they use this wheel for the RV-7's and such, and
 didn't want to have to stock 2 parts.  So we get to receive the one that
 isn't made for the application, and therefore unless you swap wheels,
 you're going to have minimal valve stem clearance.....pretty nice, huh?
   <not>
 Anyway, I had the axle cut shorter at a machine shop, and then I just
 had to guesstimate how much to take off the 2 spacers.  Knowing they had
 worn into a taper on the inside, to fit against the bearing, I had them
 only cut down by .085" total.  I did .035" on one side, and .050" on the
 other.  That way I could have a slightly longer sleeve on the left side,
 so my valve stem had just that little extra clearance from the fork.
 This brought forth a small problem...  Tonight when I assembled it as in
 the first photo below, it looked great.  VERY much better than original.
   Then, when I put the whole wheel together, I found that the spacers
 had worn probably at least .120" because there was tons of slop in the
 spacers yet, even though they now had a nice flat surface to sit
 between, and had been cut less than the axle, and the washers were in
 there to fill in some space.  The spacers just spun.  So, I decided
 since I already ordered another axle, I'd take my bandsaw and VERY
 carefully trim off some more axle, and just use one more washer on the
 left side.  That should keep that valve stem even FURTHER away.  If I
 was right, I could get it so there would be plenty of pressure on the
 bearings and spacers to hold them in place so they don't spin.  Sure
 enough, it worked just great.  I could now torque that bolt down tight
 and keep the spacers from spinning, and the bearing too.  Just to be
 totally sure they never spun again, I drilled a couple of holes in the
 stainless spacers, and remounted it all.  Then I made a pilot hole in
 the aluminum axle shaft, and took it all apart and tapped it for an 8-32
 screw on each spacer.  Then I cleaned it up, regreased, and put it all
 together.  Now it is very solid, and should never wear the fork
 again....I just am left with a crappy fork...so I'll probably just get a
 new one.   Once my new spacers and axle come in, I may tear it all apart
 and use those pieces, but I'll still probably cut the axle and spacers
 down and use the washers on the outer ends.  It will prevent your forks
 from being the sacrificial component.  The bearing, for future
 reference, is a Timken LM-6700-LA (I think that's right, but I'll
 re-check tomorrow)
 A note about tightening the axle nut...   Tonight on the RV-10 list,
 someone said that George Orndorff (A Van's tech center place), says that
 the bolt should only be snugged, and then rechecked often in the first
 few hours.  I don't personally believe this is true on the RV-10, but
 perhaps it is on the other models.  Here's why.   I studied this long
 and hard, and now I fully understand why this is such a huge freaking
 issue.  It didn't make sense at first, having worked on dozens and
 dozens of automotive bearings in the past.  You see, on automotive apps,
 the bearings are pressed in on the backside, and a nut and washer holds
 the bearing tight.   But it pushes against a different area of the
 bearing.  And the grease seal is usually a seal that is pressed into the
 hub, with a seal around the shaft on the ID of the seal.   This is NOT
 how these bearings are on this application.   On THIS application, you
 are expecting that the sleeves, the axle, the bolt, AND the inner race
 area of the bearing do not ever rotate.  The problem is, if these
 bearings were a tight knurled, or press fit onto that axle shaft, it
 might be easy to keep them from rotating by just not letting the shaft
 spin.  But, what happens here is that the grease seal is a large seal
 that the wheel spins around....so the seal is on the OD of the bearing
 in this case.  That's why my stinking seals were so torn when the wheel
 wobbled.   The kicker to the problem is, if you don't have the spacers
 very tight against the bearing, there's not enough force to keep the
 bearing from turning on the shaft.  If the bearing spins on the axle
 shaft, then it's becoming USELESS as a bearing.  At that point, you're
 using the aluminum axle as the bushing, and the wheel is rolling by
 spinning the hard steel bearing race against your soft aluminum axle
 shaft.....instead of turning the roller bearings inside of the wheel's
 outer race.  The seal itself has a lot of drag against the wheel as it
 spins, and this drag will make it so that the wheel tries REALLY hard to
 make the bearing spin.  As it turns out, if you don't have tight
 spacers, it's really easy to get that bearing spinning.  And once the
 bearing is spinning, the spacers stuffed right up against it will spin
 too.  And once they start spinning, they'll spin against the fork.  If
 you have the stainless ones like me, they'll ABSOLUTELY then start
 carving into your forks.  If you have the new and improved thick
 aluminum ones (that I can't comment firmly on because I haven't seen
 them), then they would have more surface area against both the bearing
 and the fork....so on one hand the bearing will try to turn it harder,
 but the fork will prevent it harder as well.   To me, this is STILL
 going to be a less than ideal situation until you PREVENT the spacers
 from turning, and you PROTECT the forks from being worn if they do turn.
    The lock screws I put in should keep the spacers still.  The washers
 will protect the forks.   The one further improvement that would be
 simple would be to drill a tiny hole in the fork on one side, that
 drills into the aluminum axle, and then tap for a small hex head
 internal setscrew lock, so that you could pin the axle from rotating at
 all too.   Beyond that, the only real improvement I could think of is if
 you could find a way to either press-fit, or hold that inner bearing
 from turning on the axle.  Perhaps knurling it, epoxy, a small keyway
 and shear key, or something like that would be the ticket.  If you've
 done all of the other steps, and have tight spacers, you probably
 wouldn't have any huge issues from that point.
 The worst thing about it is that no matter what you do, you really don't
 have independent control over how tight the bearings are
 seated...separate from how tight the axle bolts are and how long the
 spacers are.  Just to let you know how this all ends up the way I have
 it tonight, the wheel will not continue rolling if you spin it by hand.
   I don't think it's too tight from a bearing perspective, but the
 grease seals against the wheel hub provide a lot of drag, so they don't
 let the wheel spin real freely.
 A couple other tips, while I'm at it.  By the time you get to 25 hours
 on your plane, re-check that large nut that holds the fork on.  Mine
 needed to be tightened almost one full flat to the next castle stop, to
 retorque it after it took it's set.  I think the spec is about 24lbs.
 pull of breakout force to rotate the nose at an angle.
 The second tip that I can't yet verify is fairing balance.  To prevent
 shimmy, I've heard that a good idea is to balance your fairing.  Since I
 had a little lead shot around, and I wanted this all to be perfect now,
 tonight I weighed out a little lead and taped it to the nose of the
 nosewheel fairing.  I got it so that I could hold it where it mounts, in
 the centers of those 4 screw areas, and get it to be about neutrally
 balanced.   Then I just took a little shot away, poured the rest into
 the nose of the fairing, and mixed a couple of squirts of epoxy.  I
 poured the epoxy into the nose over the shot, put down one layer of
 cloth, and then a little more epoxy.  By tomorrow that stuff won't be
 going anywhere, and I already re-checked the balance and it's now much
 less tail heavy, so maybe that will improve things too.
 Tim Olson - RV-10 N104CD - 107 hours Flying
 Wayne Edgerton wrote:
  	  | Quote: | 	 		   I'm currently building in Justin, TX in George Orndorff's hangar, he's
		ddddsp1(at)juno.com Guest
				 Posted: Thu Aug 10, 2006 10:03 pm    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Tim,
 Are you planning to drill thru the fork into the axle and TAP it with a contersunk screw to keep the axle from turning like you did to the spacer?  I am thinking it would be easy to do and would eliminate the axle from turning even if the wheel got loose.
 Dean
 Getting engine today.
 ________________________________________________________________________
  Try Juno Platinum for Free! Then, only $9.95/month!
  Visit http://www.juno.com/value to sign up today!
				 Posted: Fri Aug 11, 2006 3:42 am    Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
				Yeah, but not until I get all the new parts and see them.
 That's one hole I'll "drill once".
 ddddsp1(at)juno.com wrote:
  	  | Quote: | 	 		   Tim,
  Dean
