Dennis Johnson
Posted: Thu Aug 10, 2006 6:28 pm Post subject: Question for Brian Lloyd |
Hi Brian (and others),
A couple of weeks ago you posted a suggestion for connecting a stereo0 IPod-type device to a mono audio panel. You said to insert a 100 ohm0 resistor in series in each of the left and right channels, at the stereo jack,0 before combining the left and right channels together.
I'm now wiring my panel and I have a stereo jack that0 I'll connect to my mono audio panel. I was planning to just jumper0 the left and right (high) terminals together at the stereo jack so I can0 listen to my IPod in flight. Can you expand a little on the need for the0 resistors? I actually have two concerns: One is that I'd like to0 understand the issue a little bit, and the other is that I've heard that people0 don't get enough volume from portable entertainment devices, and the resistors0 might make that problem worse.
Thanks so much for your help,
Dennis Johnson
Legacy #257, hoping to fly in three months
bob(at)bob-white.com Guest
Posted: Thu Aug 10, 2006 6:47 pm Post subject: Question for Brian Lloyd |
On Thu, 10 Aug 2006 19:25:59 -0700
"Dennis Johnson" <pinetownd(at)volcano.net> wrote:
| Quote: | Hi Brian (and others),
A couple of weeks ago you posted a suggestion for connecting a stereo IPod-type device to a mono audio panel. You said to insert a 100 ohm resistor in series in each of the left and right channels, at the stereo jack, before combining the left and right channels together.
I'm now wiring my panel and I have a stereo jack that I'll connect to my mono audio panel. I was planning to just jumper the left and right (high) terminals together at the stereo jack so I can listen to my IPod in flight. Can you expand a little on the need for the resistors? I actually have two concerns: One is that I'd like to understand the issue a little bit, and the other is that I've heard that people don't get enough volume from portable entertainment devices, and the resistors might make that problem worse.
Dennis Johnson
Hi Dennis,
The resistors are needed to isolate the two outputs from each other.
Basically you want to add the voltages from the left and right
channels. The input to the audio panel will be a high impedance, so
the 100 ohm resistors won't have much effect on the volume.
Bob W.
http://www.bob-white.com
N93BD - Rotary Powered BD-4 (first engine start 1/7/06)
Custom Cables for your rotary installation -
http://www.roblinphoto.com/shop/
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu Aug 10, 2006 7:26 pm Post subject: Question for Brian Lloyd |
channels together.
Well, it gets to the way solid-state audio amplifier output stages
are built. They are designed to have very low output impedance. This
way they can generate a voltage output that isn't much affected by
the thing receiving the voltage (a speaker or earspeaker in this
case). In addition they use negative feedback, i.e. part of the the
output signal is inverted (flipped over) and fed back to the input in
order to cancel out errors (distortion) generated within the amp
itself. This further reduces the output impedance. So if you tie one
output to the other, the output that is NOT generating the signal you
want will look almost like a dead short to the output that is.
Now many of you have tied the left and right outputs together and you
get sound. That is because most of the audio is in-phase and a lot of
the signal is identical in both the left and right channels. You hear
sound. The problem comes when there is something on the left channel
that doesn't appear on the right. The right output will then act as
almost a short to that part of the signal. Very little of what is on
the left channel will make it to your audio panel or intercom.
So we add the 100 ohm resistors. These keep one output from loading
down the other. The two signals, left and right, then mix and you get
the best possible output with less distortion and less load on the
two amplifier outputs.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
nuckollsr(at)cox.net Guest
Posted: Fri Aug 11, 2006 5:28 am Post subject: Question for Brian Lloyd |
At 04:59 AM 8/11/2006 -0400, you wrote:
>channels together.
Brian's most lucid explanation is illustrated and further
supported in the audio chapter of the 'Connection which one
may presently access at:
http://aeroelectric.com/articles/Rev11/18Audio_R11.pdf
Hopperdhh(at)aol.com Guest
Posted: Sun Aug 13, 2006 6:03 am Post subject: Question for Brian Lloyd |
There have been some excellent replies to this thread.
The only thing that I can add is that due to the extremely low output impedance of some amplifier circuits, the result is OVERHEATING of the output devices of both sources as they each attempt to drive the output node to their own desired voltage -- instant by instant. This is accompanied of course by increased current drawn by each amplifier. In some cases the output devices could fail. The 100 ohm resistors limit the current that can flow between the two amplifiers.
Dan Hopper
RV-7A
