bertrv6(at)highstream.net Guest
Posted: Fri Aug 11, 2006 12:40 pm Post subject: Ammeter question |
Hi:
All you experts in electrical....here is the question..
when I turn the master switch, if I load any of the switches, such
as Taxi lights or Strobes anything at all, the Ammeter, shows Charge..
that is needle goes to Positive...should be to discharge, negative.
UP to last week,, everything was fine....since First flight....
It does same when Running engine... everything else seems to be fine/..
What say you....I should check...how to correct this.
Bert
rv6a
flying
jsflyrv(at)verizon.net Guest
Posted: Fri Aug 11, 2006 2:05 pm Post subject: Ammeter question |
bertrv6(at)highstream.net wrote:
Hi:
Bert
rv6a
flying
As I understand it an ammeter should go higher the more things you turn
on, it is measuring the amp load on the system.
Jerry
dbris200(at)sbcglobal.net Guest
Posted: Fri Aug 11, 2006 3:12 pm Post subject: Ammeter question |
If it's a meter with a "0" center and reads + and -, then it should go left or negative with stuff turned on and the engine not running. When the battery is fully charged and the engine is running it should read about zero or to the + side if the battery is low like just after a start. This kind of ammeter shows the current flowing in and out of the battery, the other kind that reads from 0 on the left and 80 or whatever your max is, is telling you what current is coming out of the alternator.
I don't see how it could have reversed it's reading unless someone changed something (like re-connected the shunt backwards) assuming that it's just a simple analog ammeter. If it's a digital device of some kind, then I don't have a clue.
Dave
Jerry Springer wrote:
| Quote: | --> RV-List message posted by: Jerry Springer <jsflyrv(at)verizon.net> (jsflyrv(at)verizon.net)
bertrv6(at)highstream.net (bertrv6(at)highstream.net) wrote:
| Quote: | --> RV-List message posted by: bertrv6(at)highstream.net (bertrv6(at)highstream.net)
Hi:
Bert
rv6a
flying
| As I understand it an ammeter should go higher the more things you turn on, it is measuring the amp load on the system.
Jerry
dan.beadle(at)inclinesoft Guest
Posted: Fri Aug 11, 2006 3:22 pm Post subject: Ammeter question |
It depends where you put the ammeter in the system.
If you put it between the ammeter and the buss, it is measuring the output
from the ammeter - should go higher with more things turned on. This style
never goes negative. But if it is on the b lead between the buss and the
main starter feed, it measures current into / out of the battery. In that
case, it should read negative when you turn on a load but don't have the
engine running. It should read positive after start as the alternator
recharges the battery, then it should go to zero as the battery stops taking
charge.
FLYaDIVE(at)aol.com Guest
Posted: Fri Aug 11, 2006 3:30 pm Post subject: Ammeter question |
In a message dated 8/11/06 4:41:55 PM Eastern Daylight Time,
bertrv6(at)highstream.net writes:
| Quote: | Hi:
Bert
Bert:
I'm guessing here but I would say that last week you had the same problem but
you missed it. Sounds like the problem is the ammeter is installed
backwards.
If it isn't they you are missing something or not telling us the entire story.
Engine OFF
Master ON
Lights ON
AMMETER should show a DISCHARGE
Turn the Lights OFF
Start the engine
Turn LIGHTS ON
AMMETER should show a CHARGE
Gots to ax a dumb question ... The Ammeter does show in BOTH directions ...
charge and discharge?
I know dumb, but had the same question asked about a meter that ONLY showed
CHARGED direction.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
dorante(at)juno.com Guest
Posted: Fri Aug 11, 2006 5:40 pm Post subject: Ammeter question |
Bert:
In order to diagnose your problem, it would be very helpful to
measure system voltage. Put a voltmeter across the battery. A fully
charged batter should measure 12.0 - 12.5 VDC. Without the engine
running, and some load, the voltage should start to drop. After
starting the engine, the voltage should go up to 13.5 to 14.5VDC. This
is the output voltage of the alternator (regulated). Increase the load
on the electrical system by turning on landing lights, and other large
loads, and the voltage should not change, maybe a slight drop.
I have had problems with automotive ammeters. Some use a shunt
resistor, and others pass the BATT wire through a coil. The latter
type I have found to be troublesome because they require a straight
length of wire going through the coil.
I have found two very useful, inexpensive tools for troubleshooting
charging system problems. First, a voltage/charging indicator using 3
LED's that plugs into a cigarette lighter. Radio Shack used to sell
these for about $10. The good thing about this is that you do not have
to be near the prop to record voltage. Second, a DC clamp on ammeter
that can be placed on a battery cable. This ammeter is not real
accurate, but it will show current direction and magnitude. I got
mine from Sears years ago.
When I finish my RV-6A, I will have only a Voltmeter in the panel.
Voltage is a much better indicator of battery health and charging
system operation than an ammeter. IMHO, ammeters are almost useless.
Hope this helps.
Tom
Posted: Sat Aug 12, 2006 8:29 am Post subject: Ammeter question |
Quoting "D.Bristol" <dbris200(at)sbcglobal.net>:
| Quote: | If it's a meter with a "0" center and reads + and -, then it should go
Dave
This is my surprise too...I got other e mails, some suggest that
the battery is the problem,, I do not know why this would be..
I will keep checking around, is a challenging mistery...
thanks
bert
>> Hi:
>> Thanks
>> Bert
>> rv6a
>> flying
>> do not archive
> Jerry
> do not archive
Posted: Sat Aug 12, 2006 8:39 pm Post subject: Ammeter question |
Bert,
The battery can't cause this kind of problem. If you're using a "standard" type of ammeter with an internal or external shunt, it almost has to be a wiring error. Maybe you just didn't notice it before.
Dave B. -6 So Cal
Eaa Technical Counselor
bertrv6(at)highstream.net (bertrv6(at)highstream.net) wrote: | Quote: | | Quote: | | Quote: |
thanks
bert
Hi:
Posted: Sun Aug 13, 2006 6:42 am Post subject: Ammeter question |
| Quote: | Bert,
Dave B. -6 So Cal
Thanks Dave:
Everything was working fine, since first flight, I will let you know when
the A &P come over to check.. If was working before. Is only 2 wires to
the ammeter a + land -..if you reverse them, tha is it for the gauge. I will
bes ruined...
So that is not the problem...
Bert
>thanks
>bert
>>>>Hi:
Posted: Sun Aug 13, 2006 7:43 am Post subject: Ammeter question |
Bert:
In your email, you said "Is only 2 wires to
will
bes ruined..."
Reversing the wires on the ammeter will not ruin it. It will only make
the ammeter indicate backwards.
A full current ammeter is wired in-line with the main load wire from
the battery. All current going into or out of the battery must go
through this wire,except the starter motor, which is wired in parallel.
The ammeter would be overloaded trying to measure the hundreds of amps
of starter current. I have seen some charging circuits that have the
ammeter leads connecting to the voltage regulator. This is used so
that full current is not going through the ammeter. If this is the
case in your RV, the regulator could be at fault. I recommended in an
earlier email checking system voltage, with and without engine running.
If you were able to do this, how were your readings?
I hope the A&P can help you. Let's us know how your problem was solved.
TOM
Posted: Sun Aug 13, 2006 7:45 am Post subject: Ammeter question |
Reversing the wires to the gauge (or the shunt) will not harm it, it will just read backwards.
Dave
bertrv6(at)highstream.net (bertrv6(at)highstream.net) wrote: | Quote: | | Quote: | --> RV-List message posted by: bertrv6(at)highstream.net (bertrv6(at)highstream.net)
Quoting "D.Bristol" <dbris200(at)sbcglobal.net> (dbris200(at)sbcglobal.net):
| Quote: | Bert,
Dave B. -6 So Cal
Thanks Dave:
bes ruined...
Bert
| Quote: | bertrv6(at)highstream.net (bertrv6(at)highstream.net) wrote:
| Quote: | | Quote: | This is my surprise too...I got other e mails, some suggest that
thanks
bert
| Quote: | | Quote: | | Quote: | Hi:
