dreel(at)cox.net Guest
Posted: Sat Aug 12, 2006 4:01 am Post subject: Effect of paint on weight & balance |
I reweighed my RV8A today because I thought the paint job might make a
significant change. Not only did the aircraft seem faster after being
painted but the pitch control forces seemed lighter when flying single
pilot. In previous posts, I have reported a significant increase in cruise
speed when moving the moment arm aft, probably due to reduced pitch
stability drag. Thinking about it, I realized that a lot more of the
surface area of the aircraft is behind the balance point near the wing spar
than in front of it, so it would make sense that the empty aircraft moment
arm would be further aft once it was painted. Here are the actual numbers:
Weight unpainted: 1051
Weight painted: 1077
Paint weight added: 26 lb
Unpainted CG: 77.46
Painted CG: 78.53 inches aft of datum
If you haven't weighed your airplane since painting and have occasion to
load it near the aft limit, beware! You might loose pitch control.
Dave Reel - RV8A
Gary.A.Sobek
Posted: Sat Aug 12, 2006 6:05 am Post subject: Effect of paint on weight & balance |
Using the same CALIBRATED scales:
Unpainted: 1086
Painted: 1094
Weight gain from paint equal 8 pounds.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
1,932 + Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
----Original Message Follows----
Reply-To: rv-list(at)matronics.com
To: "rvlist" <rv-list(at)matronics.com>
Subject: Effect of paint on weight & balance
Date: Sat, 12 Aug 2006 08:01:22 -0400
Unpainted CG: 77.46
Dave Reel - RV8A
DOUGPFLYRV(at)aol.com Guest
Posted: Sat Aug 12, 2006 6:56 am Post subject: Effect of paint on weight & balance |
We gained 10# on our RV8
DO NOT ARCHIVE
D. Preston
khorton01(at)rogers.com Guest
Posted: Sat Aug 12, 2006 7:30 am Post subject: Effect of paint on weight & balance |
On 12 Aug 2006, at 08:01, DAVID REEL wrote:
Unpainted CG: 77.46
These numbers suggest that the average arm of the added weight would
be about 122.8", which is about 3.5" aft of the nominal passenger
position. Given that most of the large surface area of the wing is
ahead of this, I would have expected the average arm of the added
paint to be a bit further ahead.
Could it be that one of the weighings had an error? Either a scale
error, a levelling error, or a calculation error? Or, have other
things been added to the aircraft since the first weighing? Were the
same scales used for both weighings? Have the scales been
calibrated? If not, is it possible that a different scale was used
on the nose gear for the two weighings?
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Sat Aug 12, 2006 10:34 am Post subject: Effect of paint on weight & balance |
On 12 Aug 2006, at 11:28, Kevin Horton wrote:
> Unpainted CG: 77.46
would be about 122.8", which is about 3.5" aft of the nominal
passenger position. Given that most of the large surface area of
the wing is ahead of this, I would have expected the average arm of
the added paint to be a bit further ahead.
the same scales used for both weighings? Have the scales been
Ottawa, Canada
Typo - that should have been 121.8" arm for the added paint. But it
still looks strange.
Kevin
Larry Bowen
Posted: Sat Aug 12, 2006 10:59 am Post subject: Effect of paint on weight & balance |
I noticed the same thing, and my paint weighed the same 26#. The paint shop
did the second weighing -- different scales, personnel, etc.
Yours is a light plane.
http://www.rvproject.com/wab/wab.jsp?id=96
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
[quote] --
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Posted: Sat Aug 12, 2006 11:35 am Post subject: Effect of paint on weight & balance |
Larry,
Just curious - what is your empty weight and CG, and how much did the
empty CG move aft with the paint job?
Kevin
paint shop
Larry Bowen
HCRV6(at)comcast.net Guest
Posted: Sat Aug 12, 2006 5:20 pm Post subject: Effect of paint on weight & balance |
FWIW, using the same calibrated electronic scales my RV-6 gained 17 pounds with paint (Jet Glo, not clear coated.)
Harry Crosby
RV-6 N16CX, 250hours
[quote] --> RV-List message posted by: "RV6 Flyer"
Unpainted: 1086
Painted: 1094
Gary A. Sobek
To: "rvlist"
--> RV-List message posted by: "DAVID REEL"
Unpainted CG: 77.46
If you haven't weighed your airplane since o avai
Larry Bowen
Posted: Sat Aug 12, 2006 6:43 pm Post subject: Effect of paint on weight & balance |
Before paint: 1106 and 77.08.
After paint: 1130 and 79.11.
That's obviously a 24 pound gain after paint, not 26 as I said before. Mine
is a PPG base-coat/clear coat.
Cheers,
Larry Bowen
[quote] --
RV-8 SOLD,
Posted: Sat Aug 12, 2006 8:02 pm Post subject: Effect of paint on weight & balance |
Both weights were taken with the same set of certified digital scales
borrowed from my local EAA chapter. Same procedure was used in each case
though 5 months intervened. I believe the results to be quite accurate.
It's good to see that Larry got similar results. I had bare metal &
fiberglass surfaces in the initial weight. Alan Woodson's Texas Aero Color
provided pinhole filling and all the rest. I'm quite satisfied with the
paint job & enjoyed working with Alan, but I envy you guys with 8 lb paint
jobs.
Dave Reel - RV8A
Posted: Sun Aug 13, 2006 2:23 am Post subject: Effect of paint on weight & balance |
Very strange.
Before paint moment = 1106 * 77.08 = 85,250.48
After paint moment = 1130 * 79.11 = 89,394.3
A moment change of 4,143.82 for a weight change of 24 lb implies an
arm of 172.66" for the added paint. There is no way the centre of
the paint is that far aft (well aft of the rear baggage compartment),
so one of the weighings must be wrong.
Be careful on your weighings guys.
Kevin Horton
before. Mine
Cheers,
Larry Bowen
Larry Bowen
Posted: Sun Aug 13, 2006 6:03 am Post subject: Effect of paint on weight & balance |
Sounds like *perhaps* the second group of wieghers left the tail down,
despite my explicit directions to raise it. Sigh. Not surprising.
The virtual averages for RV-8's here reinforce what you are saying:
http://www.rvproject.com/wab/index.jsp
Thanks for pointing it out.
Larry Bowen
Kevin Horton wrote:
Very strange.
Kevin Horton
> before. Mine
> Cheers,
> Larry Bowen
RV-8 SOLD,
gmcjetpilot(at)yahoo.com Guest
Posted: Mon Aug 14, 2006 3:14 am Post subject: Effect of paint on weight & balance |
Well I can't certify the W&B measurement, but paint will move the CG aft quite a bit.
Look at how much surface area is aft of the CG. Most of the paint is aft. The centroid of the paint if you will will be at or aft the baggage area. The aft fuselage and tail is a lot of area. Forward of the CG there's not that much paint. I agree that 2" shift is a lot. G
>From: Kevin Horton <khorton01(at)rogers.com>
| Quote: | Subject: Re: Effect of paint on weight & balance
posted by: Kevin Horton <khorton01(at)rogers.com>
Very strange.
so one of the weightings must be wrong.
Get your email and more, right on the [url=http://us.rd.yahoo.com/evt=42973/*http://www.yahoo.com/preview] new Yahoo.com[/url] [quote][b]
