Lynn Matteson
Posted: Fri Aug 11, 2006 4:40 am Post subject: Flying without doors |
I have read of doors opening in flight and on takeoff....what type of
latches do those people have? I have the double-pin latches which
extend about a half-inch into a steel tube which is welded to the
fuselage tubing, both in front of and rear of, the door. I can't
conceive of these ever opening inadvertently. Has anyone with these
double-pin latches EVER had one open accidentally?
Lynn
Kitfox IV...Jabiru 2200
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Fri Aug 11, 2006 4:46 am Post subject: Flying without doors |
Mike, didn't you have the nylon material attached to the t'deck and to
the fuse member just below the flaperon control tube, which provides a
split bearing around the flap tube? Mine is also a IV Speedster, and it
came with the material...the nylon...and instructions for mounting it.
I recall that I was reluctant to use it at first, but thanks to this
group, I was convinced that it was necessary, so went ahead and
installed it.
Lynn
On Friday, August 11, 2006, at 04:11 AM, Michael Gibbs wrote:
Quote: |
Paul sez:
> By removing it you have just eliminated the top half of the bearing
> surfaces that hold your flaperon in place. That means your flaperon
> is now going to be able to move up and down in flight.
I don't know what model Kitfox you have, Paul, but that certainly
wasn't true of mine. My Model IV Speedster simply had a slot cut into
each side of the turtle deck to allow the flaperon horn to pass
through. The flaperons were completely supported by the wing brackets
and moved just fine with or without the turtle deck in place.
That said, there are plenty of other reasons not to attempt flight
Mike G.
N728KF
N369LM |
n981ms(at)yahoo.com Guest
Posted: Fri Aug 11, 2006 5:14 am Post subject: Flying without doors |
According to "Skystar" (and I think John Mcbean that told me this): There is no need for a bearing on the aileron horn. The S5 (I don't know about other models) had one for some controlling agency issues in Europe. I wanted one anyway on my 6 but was unable to fashion one easily. So eventually I figured that if I trusted them enough to design the rest of the airplane I would trust them on this issue. I have no inboard aileron horn support.
Maxwell S6/TD/IO240
Dave <dave(at)cfisher.com> wrote:
[quote] Paul,
I fly with left door open lots and here is what i find ( also for the record I have the bowed doors with lexan but no bubble windows)
I lose a few mph in cruise and I say alot cooler on hot days.
My ASI reads lower that with door shut as I have no external static port.
My Left door at times opens on take off and in flight but really no big deal - ( if you have not experienced this, than you should as if is the cause of a quite a few accidents yearly. )
I will slip with out issues with door open or shut although the door does come unlatched at times from the fully open position and will hang in wind and even close at times. I do not have gas struts.
I would like to add a few points on turtle decks that I have seen. And none have blown off but I think it would be possible. On some after market turtledecks that I have seen they have lacked an upper and lower bearing support for the flapperon horn (I hope this is the right word) I wold think that this bearing is very critical in ensuring that the horn is supported. With out that support could the flapperon horn come lose from the flapperon? If so a flutter " could result" and could cause alot of control issues as well as wing failure.
Dave
KF IV
lcfitt(at)sbcglobal.net Guest
Posted: Fri Aug 11, 2006 5:46 am Post subject: Flying without doors |
Mike, this surprises me as the IV manual calls for the nylon bearings, 1/2
mounted to the fuselage and 1/2 mounted to the turtle deck. I thought it
was the later models that eliminated the bearing. I talked to a later
builder and he was wondering how to close the slotted gap.
Lowell
fordm2003(at)yahoo.com Guest
Posted: Fri Aug 11, 2006 6:13 am Post subject: Flying without doors |
I have this type of door setup (pin in front and rear) My right door handle has to be fastened with velcro strap in order to keep it tight. The pins seem to be a little worn (and/or short) With the handle tightned down, it isn't an issue, but I have had it open in flight and on take off before.
It was a pretty exiting experience the first time it happened.
I agree that flying with doors open is a good thing to try att some point, just so that you feel better if it were to happen unexpectedly.
I might be a good idea to have a passanger handle the door operations for the first time.
- Mike
m4 speedster, winconsin
Lynn Matteson <lynnmatt(at)jps.net> wrote:[quote] --> Kitfox-List message posted by: Lynn Matteson
Lyle Persels
Posted: Fri Aug 11, 2006 6:35 am Post subject: Flying without doors |
A wonderful, if inadvertent, pun.
Lyle Persels
On 08 11, 06, at 9:13 AM, Mike Ford wrote:
Do not archive.
Float Flyr
Lynn:
I just went out and checked my aircraft for the use of those nylon bushings.
Quote: | From what I can see they will prevent some metal fatigue over a period of
years. I would say that if any one didn't install them they should consider
doing so.
I'm going to enclose a few pictures of the latching system on my plane. The
doors are the standard metal frame and the main latch is similar to what you
will find in a house. Each door also has a safety latch that I check as
part of my run up list. Last year I went to the local scrap yard and looked
through several hundred automotive gas struts . I came up with one that was
easy to install to the door and the support behind the seat. I
intentionally made part of the mount that attaches to the door with worm
clamps so the strut goes over centre to help close the door. What I've
found is that when I go to open the door in flight I actually have to push
to open it. Before installing the strut wind would open the door at least
halfway.
Noel
Quote: | 0
Mike, didn't you have the nylon material attached to the0
t'deck and to0
the fuse member just below the flaperon control tube, which0
provides a0
split bearing around the flap tube? Mine is also a IV0
Speedster, and it0
came with the material...the nylon...and instructions for0
mounting it.0
I recall that I was reluctant to use it at first, but thanks to this0
group, I was convinced that it was necessary, so went ahead and0
installed it.
Lynn
<MichaelGibbs(at)cox.net>
> Paul sez:
>> By removing it you have just eliminated the top half of0
the bearing0
>> surfaces that hold your flaperon in place. That means your0
flaperon0
> I don't know what model Kitfox you have, Paul, but that certainly0
> wasn't true of mine. My Model IV Speedster simply had a0
slot cut into0
> each side of the turtle deck to allow the flaperon horn to pass0
> through. The flaperons were completely supported by the0
wing brackets0
> That said, there are plenty of other reasons not to attempt flight0
> Mike G.
> N728KF
Description: |
Filesize: |
59.71 KB |
Viewed: |
478 Time(s) |
Description: |
Filesize: |
46.25 KB |
Viewed: |
496 Time(s) |
Description: |
Filesize: |
102.77 KB |
Viewed: |
437 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave(at)cfisher.com Guest
Posted: Fri Aug 11, 2006 7:02 am Post subject: Flying without doors |
I am talking about a Kitfox IV or prior models.
Maybe John could comment on the flapperon horn0 nylon bushing . Is it imperative to have ?
The 5 , 6 and 7 i have no idea.
Dave
wingnut
Posted: Fri Aug 11, 2006 8:42 am Post subject: Re: Flying without doors |
I have the same mechanism that you've described here. I had the right side door pop open on me on my solo flight . It was my fault really. When the instructor got out of the airplane, he couldn't see from the outside if the steel tube had captured the pin and not being familiar with it, he couldn't really 'feel' the difference. He even asked me to verify that the door was closed properly. But, the right door pin is difficult to see from the left side and I guess I was too nervous and saw what I wanted to see. As soon as the mains lifted, the right door popped open. Thankfully, I was in a Kitfox so I still had 90% of the runway in front of me. I just pulled power, landed strait ahead and stepped out of the plane to shake brick out of my pants. Next time, I made damn sure that thing was latched properly..
Quote: | I have read of doors opening in flight and on takeoff....what type of latches do those people have? I have the double-pin latches which
double-pin latches EVER had one open accidentally? |
FLIER(at)sbcglobal.net Guest
Posted: Fri Aug 11, 2006 9:14 am Post subject: Flying without doors |
Yep, they'll open up. Over the years the detent will
get worn and the handle can rotate and the door will
pop open. No big deal though. Doesn't affect flight
at all. Just that big blast of wind and noise will
get your attention. Just pull the door back down and
latch it. Not like you're gonna fall out or
anything! :^)
Ted
I can't
Quote: | > conceive of these ever opening inadvertently. Has
anyone with these
morid(at)northland.lib.mi Guest
Posted: Fri Aug 11, 2006 9:17 am Post subject: Flying without doors |
After my doors popping open a couple of times I added it to my checklist.
Deke
Quote: | > extend about a half-inch into a steel tube which is welded to the
http://forums.matronics.com/viewtopic.php?p=54147#54147
Posted: Fri Aug 11, 2006 9:21 am Post subject: Flying without doors |
I have a single slide at front of door frame.
Not really a big issue if door opens on takeoff or at anytime really but it
can get your attention.
Key is fly the plane and not wory about door open or closed until you can
give it atention.
Flying with doors open will give you less of a scare if and when it really
happens.
Practice will not make it perfect but will help you in realtime.-
ie door opening, engine failure, stalls, spins, etc.
Dave
av8rps(at)tznet.com Guest
Posted: Fri Aug 11, 2006 6:24 pm Post subject: Flying without doors |
Hi Noel,
That is a pretty nice Model III you have there as0 well. Yeah, the aerocets are a great float. Unfortunately my Model0 IV has everything but the kitchen sink in it, so the aerocet amphibs are a0 little underfloated for my needs. If I don't try to modify mine for more0 floatation I will definitely keep you in mind should I decide to do a different0 float. My aerocets are essentially brand new (In some regards they are0 better than new).
My prop is an IVO in-flight electric0 ultralight+ (higher pitch than the standard). Works good, but I0 should probably convert to the lower pitch blades as I can't get the rpms the0 engine needs to develop max horsepower. I'm convinced the other blades0 will increase my climb rate while reducing my takeoff time on the0 water. I have never been able to get to max power rpm of 5800. So0 even though I have an inflight prop, not developing max horsepower is reducing0 my climb and my cruise. But for now I am just going to enjoy it as is. Overall it works quite well just the way it is. 0
I've really been enjoying this Model IV-1200 Kitfox0 with the 912ul. It performs very well, especially considering it is0 only an 80 hp amphibian. It can get off the water in 8-10 seconds with0 just me and 1/2 tank of fuel (14 gallons). And with the same load I can0 climb out at around a thousand fpm average. Cruise speeds? Well0 that is the really fun part. For years all of the Rans S-7's in the area0 have been the fast floatplane to catch. Now they have to try and catch me0 <snicker> And I only have 80 hp vs their 100 hp. I tested0 max power cruise the other day with me and 7/8 tank of fuel (24 gallons) in dead0 air - 116 mph one way, and 117 the other. So this little bird cooks right0 along. I rarely run my engine that hard, but still typically see 1000 mph+ for groundspeeds pretty much wherever I go even at less than0 5000 rpm. And that little 80 hp 912 is a real fuel mizer. 0 Fourty hours of keeping track of my fuel shows an average of 3.3 gallons an0 hour. Isn't that something? This little floatplane is0 incredibly efficient. I wonder how it might perform if I ever get the0 prop pitch figured out? Although it's so good now I am almost afraid0 to touch anything.
Here are a few pictures in-flight showing0 my speeds. Note: I have been too busy flying to finish all the0 little things like instrument panel markings.... (chuckle)
Paul
Description: |
Filesize: |
235.55 KB |
Viewed: |
451 Time(s) |
Description: |
Filesize: |
249.03 KB |
Viewed: |
490 Time(s) |
Posted: Fri Aug 11, 2006 6:28 pm Post subject: Flying without doors |
Dave,
I have no idea if the NACA vents are affecting the0 instruments. I suspect they are not in my Fox as I have the static port on0 the rear fuselage. If you are running static off the back of your panel,0 then yes, I believe they will affect your instrument accuracy.
Paul
Float Flyr
Posted: Fri Aug 11, 2006 7:24 pm Post subject: Flying without doors |
I am running the Ivo in flight0 adjustable UL prop too. I guess I have the fine pitch blades as With the0 582 I have no problem going all the way to 6800 rpm. Last year I had a bit0 of a problem with my tach. On the last flight the rpm cranked up to 78000 rpm and the plane literally rocketed off the water. I was well over 2500 agl before I knew what was happening. I then tried to pull the throttle0 back slowly after all there are better ways of going than to hit a runway on0 floats tail first!.. When I got home I realized that it was possible to0 churn 7800 but not get any power out of it. I immediately bought and0 installed a Tiny Tach. It turns out that at 7800 on the original 'Fox tach0 the Tiny Tach was only registering 6400.
Due to a raft of federal red0 tape I haven't gotten the hours of flying this summer that I'd planned on0 getting. I'm certainly looking forward to a lot more air time in the near0 future.
Noel [quote]
Kitfox III-A
AMuller589(at)aol.com Guest
Posted: Fri Aug 11, 2006 7:29 pm Post subject: Flying without doors |
To assure that you have a good static port location watch your altimeter0 during takeoff, rotation, and lift off. if it fluctuates or shows anything but0 field elevation it is in error.
MichaelGibbs(at)cox.net Guest
Posted: Sat Aug 12, 2006 9:50 am Post subject: Flying without doors |
Lynn asks:
Quote: | Mike, didn't you have the nylon material attached to the t'deck and
to the fuse member just below the flaperon control tube, which
provides a split bearing around the flap tube?
No. My turtledeck simply had a slot cut into it for the flaperon
horn to pass through. The inboard flaperon hinge held the bearing
surface that the horn swiveled within (see attached).
Mike G.
N728KF
Description: |
Filesize: |
77.57 KB |
Viewed: |
431 Time(s) |
janderson412(at)hotmail.c Guest
Posted: Sat Aug 12, 2006 2:48 pm Post subject: Flying without doors |
In my mind a/c doors should have one easy action to open....in case of fire. One has to think of the unfamiliar passenger in the case of an emergency. Never matters to me much if a door comes open by mistake and if in the event of an accident it springs then all the better.
Quote: |
Subject: RE: Re: Flying without doors
Date: Fri, 11 Aug 2006 12:03:00 -0230
Lynn:
doing so.
halfway.
Noel
t'deck and to
provides a
Speedster, and it
mounting it.
installed it.
Lynn
> --> Kitfox-List message posted by: Michael Gibbs
> Paul sez:
the bearing
flaperon
slot cut into
wing brackets
> Mike G.
> N728KF
<< Safetylatch2.jpg >>
<< Mainlatch.jpg >>
<< DoorStrut.jpg >>
Find the coolest online games at XtraMSN Games
Posted: Sat Aug 12, 2006 3:19 pm Post subject: Flying without doors |
Take it from me, it's the same al over the globe. The world population is made up of 50% pick swingers and the other 1/2 ticket clickers to click the pick swingers tickets!!
[quote] From: "Paul Seehafer" <av8rps(at)tznet.com>
Subject: Re: Re: Flying without doors
Date: Fri, 11 Aug 2006 21:07:45 -0500
Dave,
I have no idea if the NACA vents are affecting the instruments. I suspect they are not in my Fox as I have the static port on the rear fuselage. If you are running static off the back of your panel, then yes, I believe they will affect your instrument accuracy.
Paul
