wcm(at)tampabay.rr.com Guest
Posted: Sun Aug 13, 2006 4:03 pm Post subject: Fule tank vent |
You can use aquarium air diffusers for vent filters, they are cheap and disposable and plug right in to vent size tubing.
They come in a varity of sizes and styles (the glass bead ones work well).
Denny Rowe
Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
Posted: Sun Aug 13, 2006 6:00 pm Post subject: Fule tank vent |
How about the little fuel filters like the ones in chainsaw or weed whacker fuel tanks? I think they are called finger filters and they work perfectly for keeping insects out of the vent lines.
Denny Rowe,
Mk-3, PA
jindoguy(at)gmail.com Guest
Posted: Sun Aug 13, 2006 6:48 pm Post subject: Fule tank vent |
And then there is the option to use a cover with a "Remove Before Flight" streamer or even the little spring loaded cover that's used on some GA aircraft.
On 8/13/06, Denny Rowe <rowedl(at)highstream.net (rowedl(at)highstream.net)> wrote: | Quote: | How about the little fuel filters like the ones in chainsaw or weed whacker fuel tanks? I think they are called finger filters and they work perfectly for keeping insects out of the vent lines.
Denny Rowe,
Mk-3, PA
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
when you live at the airport.
